RCD 4.5" Suspension: The best lift available?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by freedomriding, Nov 15, 2014.
  1. Apr 25, 2015 at 4:10 PM
    #81
    Superwhitetaco10
    Superwhitetaco10 Member
    Georgetown, MA
    TRD DCSB
    285/70/17 Duratracs, Camburg Ball joint UCA's, Moog ball joints, Icon ext coilovers, Alcan triple AAL, Grillcraft, Tint, K&N filter
    Truck looks nasty! I have had my lift on my 2010, and now my 2012. (Icon 3" with rear (3) pack add leafs, 285/75/17, wheel spacers, stock rims)Has like 110k miles on it. Icons leaking a little. Time for a new setup. Lol my question is do you need new rims on the RCD lift? If not are she'll spacers necessary? Every aftermarket rim I have purchased in the past has been less than satisfying on the longevity. I like the stock rims anyhow.
  2. Apr 25, 2015 at 4:20 PM
    #82
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    DB and blocks? Meh
    agunday21 likes this.
  3. Nov 10, 2015 at 11:12 PM
    #83
    TOYsport23
    TOYsport23 Member
    Hawaii
    20134x4Taco & 20084x4Taco TRD Off-Road
    Im thinking of having the same setup but worried about the recon. you passed? and where you got for safety check after the lifting?
  4. Dec 1, 2015 at 11:57 PM
    #84
    freedomriding
    freedomriding [OP] FREEDOMEDIA
    Nate
    Oahu, Hawaii
    '20 TRDOR w/KDSS
    Eibach 2.0, STT PROs, Summit Dakars, JBA
    You'll have no problem with recon and safety. Just get the alignment done, then recon and safety can be done anywhere once you pass recon. Make sure tires are under the fender flares. If not, then temporarily install those ugly extend-a-fender ones then take them off after safety check.
  5. Jan 21, 2016 at 1:46 PM
    #85
    codename607
    codename607 Well-Known Member
    Baltimore, MD
    Not trying to take anything away from RCD but how to they compare to the BDS kit? I'm working with a local dealer in my area and they carry the BDS kit. Since they understand this kit and they claim it comes with a warranty I wanted to go this route. Just not sure if the RCD kit is significantly better. Other than the steering struts it seems to be the same kit.
    freedomriding, I saw the video on youtube after searching for 6" lifts and your truck sold me on the 4.5 kits. Great rig!
  6. Jan 21, 2016 at 4:39 PM
    #86
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    The one difference between the bds / zone and the rcd is the basic kit uses a spacer on top of your factory strut assy to make up the difference from the drop bracket. On the rcd kit they don't use the spacer but give you a longer bilstein shock to use with your factory coil and top hat. With that said you can however buy the longer bilstein shocks and use them on bds,zone,pro comp etc db lifts. The bds and zone kits which are basically the same do have a lil bit heavier duty crossmembers and spindle assys versus the rcd. The rcd is a great kit and not taking anything away from it at all.
  7. Jan 21, 2016 at 5:17 PM
    #87
    codename607
    Baltimore, MD
    Thanks! This is exactly the kind of info I was looking for. The person at the local shop I was working with had no idea. I told him I could ask you all on here and find out in a few hours. I was right. I think I will end up going with the BDS kit only because they warranty there products. I'll see how smooth the ride is with the spacers and if it's to stiff I'll buy the longer bilstein shocks.
    Thanks again.
  8. Feb 1, 2016 at 12:51 AM
    #88
    baditz
    baditz Active Member
    FBI or From Big Island HI
    06 Tacoma Access Cab 4x4 TRD 6spd V6
    just wondering what kind of MPG's everyone is getting since installing the RCD lift?
  9. Nov 26, 2016 at 4:01 PM
    #89
    BlackOxen
    BlackOxen New Member
    Keaton
    2013 White DCLB TRD Sport
    3" Bilstein 5100's, 285/70r17 Duratracs, 17" KMC Wheels, Rigid Industries grille, Rigid Industries 30" LED Bar
    Also wondering what kind of mpg's everyone is getting? Right now I'm on 285's on a 3" kit but I'd potentially like to step up to a 4.5" RCD kit with 305's. I'm getting 15-17ish mpg's right now and that's where I'd love to stay if I could.
  10. Nov 29, 2016 at 3:20 PM
    #90
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    I average 16 - 17, mostly city running 315/70R17. I use a GPS to get correct mileage for calculation.
