Rcd lift ??
Discussion in 'North East' started by K1992f, Jan 2, 2011.
  1. Jan 2, 2011 at 12:28 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I just want to say something here, why is there no rcd lift for the 1st gen? F*CK!
    the rcd is better than most db lifts, because it doesn't use a spacer on the top of the coilover, it uses a custom shocks. for the amount that a lot of us wheel, it's a pretty sweet set up!
  2. Jan 2, 2011 at 12:33 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    another thing, some of you seem to be pretty against db lifts because you don't gain ground clearance with it, but the point of a lift isn't just to measure how tall of a stick you can drive over. with a good driver, it's not all about ground clearance, but getting better approach and departure angles, which this kit does. it also get's your rocker panels up higher, so you can in fact, drive over bigger things.
    (bored at work, nothing else to do but BS with you guys)
  3. Jan 2, 2011 at 12:35 PM
    K1992f
    K1992f [OP] Well-Known Member
    Kanon
    Dirty Hanover pa ...
    2012 tacoma TRD sport fully loaded
    6" fabteck 20" fuel hostage 33" nitto MTs
    Agree I can't see doing this cheap ... I'm getting the rcd .. Now with that being said dose anybody no if I need to order any other parts for this lift or dose it come with everything I need ???? Beside tools or just finding somebody that no what there doing ... Anybody from gettyburg PA area that can help me ???
  4. Jan 2, 2011 at 12:37 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    From what I know, it comes with everything you need... besides maybe new springs?
  5. Jan 2, 2011 at 12:38 PM
    K1992f
    Kanon
    Rab89 is that ur boxer dog ???
  6. Jan 2, 2011 at 12:39 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    it'll come with everything you need, you'll have to swap coils, or get new coills for the front coilover shock. that will take a spring compressor, or bring it to a shop, which is highly reccommended because it's dangerous!
  7. Jan 2, 2011 at 12:39 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    yes sir it is! :D
  8. Jan 2, 2011 at 12:40 PM
    K1992f
    Kanon
    Ok like said I'm new to all this should I buy new springs door this lift ??? One more thing how on the rcd lift dose it raise the rear ??? Blocks between the leaves ???
  9. Jan 2, 2011 at 12:41 PM
    98tacoma27
    Ben
    Not Beech Creek
  10. Jan 2, 2011 at 12:42 PM
    98tacoma27
    Ben
    Not Beech Creek
    Use the stock springs and the blocks go between the leaf and the axle.
  11. Jan 2, 2011 at 12:42 PM
    K1992f
    Kanon
    Ok what coils should I buy then ??
  12. Jan 2, 2011 at 12:43 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    looks like a block in the rear, IMO, ditch the block and get a new leaf pack, if you can afford it.
    with your truck being new, you could stick with the stock coils, they should be in good shape.
  13. Jan 2, 2011 at 12:48 PM
    K1992f
    Kanon
    Ok thanks to you all I got more help today from you guys then I did sense I started on this forum ... Now where do find a guy in pa to put this thing lift on ???????!?? Rab89 I got boxer looks just like him I'll post a pic of him but don't no how lol
  14. Jan 2, 2011 at 12:49 PM
    98tacoma27
    Ben
    Not Beech Creek
    Applehill4x4.com
  15. Jan 2, 2011 at 12:51 PM
    #35
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
  16. Jan 2, 2011 at 12:55 PM
    #36
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I shouldve went with the RCD lift. But Instead did a 3" coilover set-up.
    But I just hate the fact that you gotta cut the frame. But atleast with the RCD kit you will have straight CV angles.
    The only thing I would change with the RCD lift, is the rear 4" blocks, and just do a 3" lift in the rear for a more leveled truck. Either a new leaf pack or a 2" AAL and a 1" tapered block.
  17. Jan 2, 2011 at 12:56 PM
    #37
    K1992f
    Kanon
    I'm on a iphone I do I do that lol sorry
  18. Jan 2, 2011 at 12:59 PM
    #38
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    thats the same reason I want something like the rcd for a first gen, i have the idea of blowing a cv...
  19. Jan 2, 2011 at 3:07 PM
    #39
    ETaco23
    Evan
    PNW
    yep! well on my 1st. gen. I couldve ran a 3.5" lift with the cv drop kit and I wouldve been fine on cv angles.
    The 2nd. gens are a different story.
  20. Jan 2, 2011 at 5:04 PM
    #40
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    No need to worry about CV boots blowing again with an RCD kit. Thats why I ditched the Ultimate kit I had originally installed. My CV's are perfectally parallel now. With the RCD you will easily fit the wheels and tire combo you want without rubbing. You could not do that with the Toytec Ultimate kit. I'm running 285-70-17's and even with the Toytec kit cranked all the way up, it still rubbed off road or even backing out of the driveway. That is one thing that really annoys me. Beside the rubbing, the truck rode way too stiff as well. Just spend the money and do it right the first time. I wish I would have. RCD kits totally rock!
