RCI Skid Plates
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YotaMan, Jul 27, 2015.
  1. Jul 27, 2015 at 7:11 PM
    YotaMan
    YotaMan [OP] TTC #0091
    Austin, Texas
    2020 Tacoma TRD Pro 4x4
    De-Badge,UltraGauge,Westcott Designs fox lift, 18” fuel rebels, Nitto Ridge Grapplers, interior led lights.
    Does anyone have any experience with RCI Metalworks Skid Plates? If not-suggestions on what's best? I'm looking to install the front, transmission and transfer case skids. Thanks
  2. Jul 27, 2015 at 9:04 PM
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    There may be skid plates as good as RCI Metalworks, but I don't think there are any better, fit & finish perfect. Great people to do business With. jmop
  3. Jul 27, 2015 at 10:02 PM
    YotaMan
    Austin, Texas
    Thanks for the info! Looks like you got the aluminum one? How sturdy/tough do you feel it would be against a rock etc..
    Also did you purchase the little valve that installs into the oil pan to avoid a spill when changing the oil ?
  4. Jul 27, 2015 at 10:20 PM
    DocD
    Mn./SoCal
    09 access cab
    Aluminum? Yes, This is 1/4" Aluminum, I am not what anyone would consider an "off roader" but I do travel some remote roads, I am very confident it will take about as much punishment one could throw at it, (a quality piece). No I haven't purchased the "Fumoto"Valve, but I plan to, I have been just a little skeptical of them, but after doing a lot of reading & with the protection of the skid plate I am going to install one, even though the skid plate drops very easily, I think the valve will make it very simple, jmop
  5. Jul 27, 2015 at 10:24 PM
    YotaMan
    Austin, Texas
    Thanks for the info! I was skeptical of both the aluminum and the valve but like you I won't hardcore off road my truck as I want it to last but I will use the truck when the need arises!
  6. Jul 27, 2015 at 11:27 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    Haven't used any of their products, but am friends with one of their fabricators. I can say their products wont fail due to lack of quality in production.
  7. Jul 27, 2015 at 11:49 PM
    TOY4JMEBOOZE
    TOY4JMEBOOZE Well-Known Member
    Winchester, CA
    2018 Chevy Tahoe
    I have the front and tranny skids on. Great, sturdy product. Just did an oil change with the skid on, no problems, no mess.
  8. Jul 28, 2015 at 2:26 PM
    YotaMan
    Austin, Texas
    Did you purchase the steel or aluminum?
  9. Jul 28, 2015 at 2:47 PM
    TOY4JMEBOOZE
    Winchester, CA
    2018 Chevy Tahoe
    Steel. 3/16" I believe.
  10. Jul 28, 2015 at 2:52 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Another +1 for RCI. I have their sliders and they are incredibly well built. They are bolt-on and all the holes, hardware and angles fit perfectly.
  11. Jul 28, 2015 at 7:47 PM
    YotaMan
    Austin, Texas
    Awesome info guys! I'm looking to install their full skid system and sliders ( when my bank account recovers , lol
    Do the sliders have any flex to them? Or are they solid enough that you comfortable resting the weight of the truck on them without any damage?
  12. Jul 28, 2015 at 7:49 PM
    YotaMan
    Austin, Texas
    I want the aluminum but I'm worried that they may not be as durable as the steel??
  13. Jul 28, 2015 at 7:54 PM
    skootx
    Erie, CO
    I have the steel ones. Without drilling holes in the frame, RCI says the sliders work well as moderate protection and steps. With a couple holes drilled, they can be used as hi-lift jack points. They have pics showing it, and I believe it. I'd trust it as a jack point as is, without the extra holes drilled. If you want to go a step further, you can have the sliders stitch-welded to the frame, which makes it easy to remove them and seriously lessens any potential damage to the frame.
    Not sure if you could stitch weld aluminum to steel though...
  14. Jul 28, 2015 at 7:59 PM
    YotaMan
    Austin, Texas
    Good deal! I'm leaning towards the steel skids all the way back- are the lower control arm skids needed? I'm not off roading very much mainly mud- but some trails with rocks few and far between. Since I think they're only around $100 or so dollars I may just go ahead and pick them up.
  15. Jul 28, 2015 at 8:07 PM
    skootx
    Erie, CO
    All depends on what you do. Sure, the more protection the better provided weight and expense aren't an issue. If you're looking at ordering a lot of stuff, give them a call. I live nearby and bought the sliders in person, they're great guys and easy to work with.
  16. Jul 28, 2015 at 11:30 PM
    YotaMan
    Austin, Texas
    That's good to hear! Lots o
    i will give them a call, since so many of you have recommended them highly! Anyone have the contact info? Thanks again guys! You have been a huge help in trying to figure out what works best for taco!
  17. Jul 29, 2015 at 8:04 AM
    skootx
    Erie, CO
  18. Jul 29, 2015 at 8:28 AM
    YotaMan
    Austin, Texas
  19. Jul 29, 2015 at 9:45 AM
    PHTaco
    PHTaco Well-Known Member
    Brooks
    TX Panhandle
    '13 Trail Limo
    Kings-Dakars-Dirty Fives RCI Skids Demello front bumper BAMF Sliders HC Rear bumper Snug top 4.56 Nitros Engo 9000# Winch w/ syn rope ARB comp & rear locker Home built roof racks Expo trailer w/ RTT
    I have the IFS, tranny & Tcase skids in 1/4" aluminum and would go that route again if I was to rebuild my taco. I was concerned with strength as well. I have beat on them pretty good in the rocks and they have held up fine. I have lots of gouges and a couple of dents that are an inch deep. Besides reduced weight, it is nice not to worry about rust and repainting.
  20. Jul 29, 2015 at 9:51 AM
    PHTaco
    Brooks
    TX Panhandle
    '13 Trail Limo
    I forgot the add that there is a cut out that allows access to the oil drain plug. You can drop the IFS skid and leave the other two on to service the front diff & Tcase
