RCI vs CBI vs SOS skid plates
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chuam, Mar 2, 2021.
  1. Mar 2, 2021 at 8:04 PM
    chuam
    chuam [OP] Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
  2. Mar 2, 2021 at 8:07 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  3. Mar 2, 2021 at 8:43 PM
    tommygs3
    tommygs3 Well-Known Member
    tommy
    18 tacoma limited
    Fox 2.0 - KDmax tune - 5.29 revolution
    i went trd skid and rci tran skid and it matches up.. im in the process of powder coating the trd matte black to match the rci...
    Norsemanvike, whatstcp and BangosTaco like this.
  4. Mar 2, 2021 at 10:44 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Buy local.
  5. Mar 3, 2021 at 10:02 AM
    chuam
    Marcus
    San Diego
    Is the aluminum weight savings worth the potential loss of strength than the steel in the RCI?
  6. Mar 3, 2021 at 11:01 AM
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    What are you going to be doing?
    Overland oopsie protection & infrequent sliding = aluminum
    Actual rock crawling = steel
  7. Mar 3, 2021 at 11:04 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Not in my opinion. The weight is down low and over a large area. Plus it helps lower the center of gravity. The only time I recommend AL skids is if you're in a place that is super prone to rusting, i.e. the northeast AND you don't really do much wheeling/are buying them "for insurance".
  8. Mar 3, 2021 at 11:10 AM
    chuam
    Marcus
    San Diego
    No heavy rock crawling at this time. Plenty of places I'll be going where I may need the protection but also want the piece of mind that they're there when I do need them.
    Norsemanvike likes this.
  9. Mar 3, 2021 at 11:12 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    120 lbs vs 68 lbs. $765 vs $965. I'd save the $200 because you're not going to notice the 52lb weight difference. Plus they're stronger.
    71tattooguy and Spare Parts like this.
  10. Mar 3, 2021 at 11:27 AM
    vecdran
    Jeremy
    Kirkland, WA
    52 lbs on the skids, then you add sliders, then you add a canopy, then you add a winch mount and winch...
    It all adds up, and if you have a PRO and you're trying to keep the stock Fox suspension within its proper operating stroke length and not screw up the valving zones, you have to care.
    "Spread out and low" doesn't negate the fact that you're adding 52lbs you didn't have to if you're not expecting to be putting them to hard use.
  11. Mar 3, 2021 at 11:29 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    There's more weight to be saved in other areas for less money. I'm just stating my opinion and experience, OP can listen to it if he wants to.
    71tattooguy, OG_Tacoma and whatstcp like this.
  12. Mar 3, 2021 at 11:32 AM
    vecdran
    Jeremy
    Kirkland, WA
    I guess I'm coming from the point of view of a Pro owner. OP has a SR5, so fuckit, throw steel on, higher spring rate front, AAL in the rear, but then you've far exceeded the $200 you "saved"...
    Back on topic, I'm very happy with my RCI alu skids I bought on sale. The crossmember design looks solid, doesn't require drilling, and is compatible with RCI and BAMF sliders at least. I believe it interferes with CBI.
  13. Mar 3, 2021 at 11:33 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This may come as a surprise, but adding skids, sliders, bumper, winch, and a canopy, you're already outside of what the pro suspension was designed to do. Then you've got to swap it. So much for that $8k pro "upgrade".
  14. Mar 3, 2021 at 11:35 AM
    vecdran
    Jeremy
    Kirkland, WA
    You and I are both making wild assumptions here about what the OP is planning to do with the rest of their truck, so I think we should leave it at that.
  15. Mar 3, 2021 at 11:43 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm not assuming anything. You're the one that brought sliders, bumper, winch, and a canopy into the chat. Then also brought in Pro suspension, upgrading his coils and an AAL.
    My opinion and statement stand based on what he told us.
    vvvvvvvvvvvvvvvvvvvvvv
    pwmullen3 and whatstcp like this.
  16. Mar 3, 2021 at 11:49 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    :ohsnap::popcorn:
    this one line is really funny...
  17. Mar 3, 2021 at 11:54 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Pro owners at SR5 owners houses.
  18. Mar 3, 2021 at 11:58 AM
    FIRE74
    FIRE74 Well-Known Member
    Corey
    St.Leonard, MD
    2012 DCSB
    I have SOS steel, I wanted piece of mind out on the trail, I chose strength over aluminum because it only takes one rock to ruin a good day. I don’t really know what’s going on with SOS now, I purchased mine back in 2013. I agree with @EatSleepTacos, I didn’t build my truck for the gas mileage or weight, just durable and dependable on the trail
    71tattooguy and EatSleepTacos like this.
  19. Mar 3, 2021 at 12:11 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    pro owners when they find out that the cost of their stock truck compared to a moderately "built" tacoma without pro badges
  20. Mar 3, 2021 at 12:24 PM
    chuam
    Marcus
    San Diego
    Easy guys, I know this is a forum and everyone has an opinion but let's be civil (and yes I know tone doesn't always come across correctly on screen).
    Yes, I am upgrading the suspension as well. 6112 in the front 5160 in the rear plus new leafs and UCAs. 4Runner TRD Pro wheels are being delivered tomorrow and I'll be putting some 265/70R17s on them.
    RSI cap going on when it gets here. Not doing bumpers or a winch yet but may in the future.
    max_o, Taco_Craig and OG_Tacoma like this.
