RCLT HD 2.75" - Travel Numbers and Notes
Discussion in 'Long Travel Suspension' started by Tacoma1192, Jul 13, 2022.
  1. Oct 15, 2022 at 10:06 AM
    #321
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    I'll keep it in mind! Trying to avoid re working full skids with the jd pivot. Not sure what everyone's doing to accommodate trans/tcase skids
    xweslingx[QUOTED] and ovrlndkull like this.
  2. Oct 15, 2022 at 10:38 AM
    #322
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Weld a little tab on the back of the JD skd that attaches to the skids you have. Only thing if you want would be making an angled skid up to the front crossmember area
    NCtaco914[QUOTED] and xweslingx like this.
  3. Oct 15, 2022 at 11:02 AM
    #323
    CGoss
    CGoss Well-Known Member
    Las vegas
    2006 rad red offroad
    Make your own skids, the options currently available suck and eat up alot of clearance.
    Im not recommending this, but i run without a tcase and trans skid and have only touched my trans pan once.
    My plan is to remake the crossmember to achive a flat belly.
    T.Barn likes this.
  4. Oct 15, 2022 at 11:41 AM
    #324
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Agreed. Front skid and t case skid takes all the abuse. T case skid by nature hangs way low and never had issues not running one in the past with 35's. It's a false sense of security for me! Crawl box is sitting on go whenever I've got time. So already going to be relocating exhaust again...
  5. Oct 15, 2022 at 11:45 AM
    #325
    Tac05
    Tac05 Unknown Member
    2005 Tacoma DCLB
    Why you not running the lower pivot? I am wondering if this would have much benefit with RCLT if all the cams and pivot points have been gusseted.
  6. Oct 15, 2022 at 1:33 PM
    #326
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    im just gonna gusset the lower pivots and run some btf (stock length lower arms) wheel hard for a while then sell the lower arms and solid axle swap the truck. The jd lower pivot kit is awesome and if I use it I can’t just cut it off later and it still be guaranteed to be useable.
    I did see one install on Instagram using the JD kit and RCLT. Can’t remember where.
  7. Oct 15, 2022 at 2:09 PM
    #327
    CGoss
    Las vegas
    The OP installed a JD pivot kit, jd fenders and RCLT on a customer vehicle
    https://www.instagram.com/p/Cf-4R-Sub9p/?igshid=MDJmNzVkMjY=
    TacoEspecial likes this.
  8. Oct 15, 2022 at 2:36 PM
    #328
    xweslingx
    Wes
    Durham, NC
  9. Oct 15, 2022 at 5:14 PM
    #329
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Man and he still pushed the arms forward with the lower pivot kit. That's pretty crazy. I would think 1/2 to 0 forward on the pivot kit with the RCLT
    T.Barn likes this.
  10. Oct 15, 2022 at 5:26 PM
    #330
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    He had it set in the stock position in those photos, and in the original post here to simulate the stock pivot position.
    Tacoma1192[OP] likes this.
  11. Oct 15, 2022 at 5:42 PM
    #331
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    You're right I was looking at it backwards at first. :thumbsup:
  12. Oct 15, 2022 at 7:00 PM
    #332
    Maxx
    Maxx Well-Known Member
    I hear if you run the Marlin kit with the JD tabs in the full forward position, you can run 44’s without having to cut your cab mount. :)
  13. Oct 15, 2022 at 7:22 PM
    #333
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    That’s cuz Marlin invented the 44” tire and pioneered the use of round tires.
    tacotunner06, Mully, bhigbee and 6 others like this.
  14. Oct 15, 2022 at 7:28 PM
    #334
    CGoss
    Las vegas
    I think even all the way back in the jd kit is still 1/4in forward of stock
  15. Oct 15, 2022 at 7:44 PM
    #335
    T.Barn
    T.Barn Well-Known Member
    Todd
    Hampton Roads, Virginia
    2010 AC 4x4 6MT
    Now we’re talking, good findings. Should be good with an 8” bump?
    TacoEspecial and CGoss like this.
  16. Oct 15, 2022 at 8:44 PM
    #336
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    Correct.
  17. Oct 16, 2022 at 11:09 AM
    #337
    Tac05
    2005 Tacoma DCLB
  18. Oct 16, 2022 at 11:37 AM
    #338
    CGoss
    Las vegas
    The additional caster is nice for higher speed driving, and it will increase approach angle. But this will cause you to rub your headlights even more. It depends on if your steering rubs your coilover, how far forward you can run it.
    Ive also had both the marlin gussets and the jd kit, the jd kit braces everything way better, but its also nearly 10x the cost. Your able able to bolt your cams into place.
    Im pretty sure the jd skid plate is higher clearance than other skids on the market. And its easier to handle and replace.
    The kit isnt for everyone though. Its a pain to remove the diff with it installed and for the marlin kit, its even more difficult to remove the steering rack.
    Tac05[QUOTED] likes this.
  19. Oct 18, 2022 at 2:20 PM
    #339
    Ubaderb
    Ubaderb Well-Known Member
    15 Tacoma TRD OR
    Are those the BTF arms that push the lbj forward like 3/4"?
  20. Oct 18, 2022 at 8:27 PM
    #340
    xweslingx
    Wes
    Durham, NC
    Yes
    Ubaderb[QUOTED] likes this.
