RCLT HD 2.75" - Travel Numbers and Notes
Discussion in 'Long Travel Suspension' started by Tacoma1192, Jul 13, 2022.
  1. Dec 18, 2022 at 3:23 PM
    #501
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Yes.
    Slashaar likes this.
  2. Dec 21, 2022 at 1:18 AM
    #502
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    Sweet..... I'll schedule my mod day
  3. Dec 23, 2022 at 3:07 PM
    #503
    chrisrhere
    chrisrhere Well-Known Member
    2019 Tacoma trd pro
    If anyone is interested in joining a RCLT fb group please do. Figured this could be a great resource without all the “by catches “ not that the banter isn’t funny.
  4. Jan 2, 2023 at 5:54 PM
    #504
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    When you're crawling very slow :turtleride: how's your steering with the Howe pump?
    Thinking of getting one and I'm interested in how it does when crawling or just running low rpms.
  5. Jan 2, 2023 at 6:19 PM
    #505
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    Does the 03-09 4runner high pressure line have the correct fittings for the Tacoma's power steering pump and the LC200 rack?
  6. Jan 3, 2023 at 8:27 AM
    #506
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I have not verified as that is not what I installed, but I believe so based on what I had to change to make the Tundra rack work on my 4runner. The connection at the pump will likely require a different banjo bolt as well, I needed a taco banjo bolt. With the taco line, the 4Runner bolt was too long and bottomed out on the pump.
    TacoEspecial[QUOTED] likes this.
  7. Jan 3, 2023 at 9:17 AM
    #507
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    Since I haven't modified my LC200 rack yet sounds like the Howe pump from JD Fab is the way to go.
    Just called Harry @81Trekker and ordered one :thumbsup:
    There's some more in stock too :rofl:
  8. Jan 9, 2023 at 12:07 PM
    #508
    Tac05
    Tac05 Unknown Member
    2005 Tacoma DCLB
    The pump doesnt work at low RPMS, you need to bump your idle RPM to at least 1100. I made the upgrade because I had to, but I probably wouldn't do it if I didnt need a new pump already. You wont see any improvements in crawling in rocks, but it does make driving over small rocks and bumps smoother because there is less steering feedback.
    The priority should be a solution to the steering rack. Extended use is resulting in bushing / crossmember failure and there is no viable solution yet.
  9. Jan 9, 2023 at 12:37 PM
    #509
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Hopefully someone cool like @81Trekker makes a good kit for a weld in crossmember/Tundra rack.
    Solo's kit was re-designed with aluminum bushings, but heard they don't fit great either, doesn't really fix the crossmember issue either.
    If I'm going through the trouble of doing a Tundra/similar rack, might as well cry once. Cut it all out and make it strong AF.
  10. Jan 9, 2023 at 12:45 PM
    #510
    Tac05
    2005 Tacoma DCLB
    I think JD Fabs approach is better. An upgraded rack does nothing but transfer the stress points to different locations. JD Fab keeps the stock rack, which is fine, and add their swingset, to assist with load and force distribution.
    I don't see a point in an upgraded rack if it just accelerates failures in other areas and offers little other upgrades.
    Slashaar and aturk[QUOTED] like this.
  11. Jan 9, 2023 at 1:09 PM
    #511
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    Maybe adding a couple crawlboxes would help with the steering rack issues.
    Slashaar and whatstcp like this.
  12. Jan 9, 2023 at 1:12 PM
    #512
    Tac05
    2005 Tacoma DCLB
    How so?
  13. Jan 9, 2023 at 1:23 PM
    #513
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    Would think it would make things easier on the truck.
    Slower, more control.
    I was kinda joking but I do have triples and take things easy.
  14. Jan 9, 2023 at 1:25 PM
    #514
    Tac05
    2005 Tacoma DCLB
    Yeah, I am super easy on my truck when in the rocks. With a crawl box there is no need to throttle through things. But my rack / crossmember are still failing.
  15. Jan 9, 2023 at 1:30 PM
    #515
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    Yah, that's a bummer, hope you get it worked out.
    I'm taking notes on what you're trying.
    My RCLT kit is being installed this week and next so I'll have first hand experience soon.
  16. Jan 9, 2023 at 1:35 PM
    #516
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    On mine I just welded the bottom of the stock bung, and did a big weld washer off of that. Same with the top, just added a ton of weld and a big weld washer. Been fine so far with solid bushings on dumb trails and some dunes
    Slashaar and TacoEspecial like this.
  17. Jan 9, 2023 at 1:44 PM
    #517
    Tac05
    2005 Tacoma DCLB
    My concern with your approach is that it addresses the symptoms of the issue, but not the cause. I think the force is going to be transferred to your rack housing itself. Failed bushing or failed housing?
    Besides the stock rack / swingset JD Fab setup, I don't see what we can do besides going hydro, but there arent any kits for that yet.
  18. Jan 9, 2023 at 2:25 PM
    #518
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    hmm I’d be interested to hear from people that have had problems with tundra racks. I haven’t heard many. Sounds more like an RCLT problem.
  19. Jan 9, 2023 at 2:48 PM
    #519
    Tacoma1192
    Tacoma1192 [OP] GD MOTORSPORTS
    Kyle
    Boise, ID
    2015 DCSB Sport
    39's, LT, 4 Link, Spidertrax 9"
    The JD fab is a steering slide not swing set. They are two very, very different things. Swing set settering replace the rack and pinion with a steering box and hydro assist. Swing set steering would solve all of these issues as it replaces the rack and pinion. JD Fab slider only helps with load deflection.
    This is from Kibbe Tech for F150 / Raptor Swing set for reference
    slander likes this.
  20. Jan 9, 2023 at 2:59 PM
    #520
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    The tundra rack is bigger than the lc200 rack so im not worried about it, the bushings are a solid piece of metal, and I'm still running stock tie rods so in theory those should break/bend first, but havent been able to break anything yet lol
    Airdog likes this.
