RCLT HD 2.75" - Travel Numbers and Notes
Discussion in 'Long Travel Suspension' started by Tacoma1192, Jul 13, 2022.
  1. Jan 10, 2023 at 11:22 AM
    #541
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    nDub likes this.
  2. Jan 10, 2023 at 2:59 PM
    #542
    CGoss
    CGoss Well-Known Member
    Las vegas
    2006 rad red offroad
    I still think part of the issue with the other racks is they dont address steering stops. Factory limits it at the knuckle and transfers some load through the LCA.
    TacoEspecial likes this.
  3. Jan 10, 2023 at 3:47 PM
    #543
    Tac05
    Tac05 Unknown Member
    2005 Tacoma DCLB
    That makes sense, since it seems like that would be the primary source of force on the rack. Bumps and what not shouldnt matter because the end links pivot, but extreme force is coming from somewhere, so it must be the constant load of turns plus full lock.
  4. Jan 10, 2023 at 5:49 PM
    #544
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Yeah i still need to extend mine, probably one of those forget it until it breaks things
  5. Mar 1, 2023 at 3:47 PM
    #545
    Ol'gray mare
    Ol'gray mare Well-Known Member
    West, Tx
    2017 MGM DCLB TRD OR Geared, locked and tuned, rear disc brakes. 2018 TRD PRO White boss' bone stock
    Build thread coming soon.
    After reading this whole thread y'all have unequivocally convinced me to stay with my original plan of going with Dana 60's for the ol'graymare.
    essjay, Buttskevin21, kona61 and 3 others like this.
  6. Oct 14, 2023 at 2:41 PM
    #546
    eimkeith
    eimkeith Well-Known Member
    J Keith
    '96 4Runner, '03 Taco
    I'm just posting to state that this made me laugh out loud and is probably the best thing I've ever read on TW. :)
    Cooljohn253, Naveronski, nDub and 2 others like this.
  7. Aug 10, 2024 at 7:19 PM
    #547
    JordanTaco6
    JordanTaco6 Well-Known Member
    Jordan
    Is anyone running both RCLT with both a JD fab pivot kit and a tundra rack? I'm running that setup right now with a camburg LT, that I'm happy with, but still curious if I could get an RCLT to fit in the future.
  8. Aug 11, 2024 at 6:31 AM
    #548
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    No
  9. Aug 11, 2024 at 7:46 AM
    #549
    JordanTaco6
    Jordan
    Care to elaborate? I’ve heard the tundra rack might not work with RCLT, but not clear why.
  10. Aug 11, 2024 at 9:33 AM
    #550
    chrisrhere
    chrisrhere Well-Known Member
    2019 Tacoma trd pro
    the throw is not the same. LC200 rack is specifically used because the RCLT kit is designed around it.
  11. Aug 12, 2024 at 6:47 AM
    #551
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    No :boink:
    Just kidding.
    I suggest you read through Marlins info on the RCLT kit.
    Biggest issue you may run into is whether or not it will work with the JD pivot kit.
    You might want to get Howe ps pump then gusset the spindle.
    Maybe go to the JD fab LT.
    JordanTaco6[QUOTED] likes this.
  12. Aug 12, 2024 at 12:45 PM
    #552
    Tacoma1192
    Tacoma1192 [OP] GD MOTORSPORTS
    Kyle
    Boise, ID
    2015 DCSB Sport
    39's, LT, 4 Link, Spidertrax 9"
    Yes, on the truck, I installed this RCLT and also did the JD Fab Pivot. I set the lower arms all the way in the rear position. There really isn't a reason to combine the two and push the lower arms all the way forward—there are adverse side effects in doing so. The main one is that it reduces wheel travel due to CV bind at full drop. When pushing the hub forward without moving the diff forward, there is always a reduction due to CV bind. The only advantage would be stronger pivots for the lower control arms. Which can also be done a number of other ways outside of the JD Fab pivot kit.
  13. Aug 12, 2024 at 3:16 PM
    #553
    JordanTaco6
    Jordan
    Awesome, appreciate the context, I'd seen the same from 1 other person who said they moved their JD fab pivot adjustment all the way back (most + mine now, are set all the way forward to get tires away from the firewall).
    Good to know though about the LC200 vs tundra rack differences to @chrisrhere 's point above.
    Looks like all-pro is trying to make a kit too and they were also having issues figuring out the right way to go about steering.
  14. Aug 12, 2024 at 6:14 PM
    #554
    Tacoma1192
    Kyle
    Boise, ID
    2015 DCSB Sport
    As someone who has torn both the LC200 rack and the tundra rack, they are the same except for the third mounting point on the LC200 that doesn't get used anyway.
    Airdog likes this.
  15. Aug 13, 2024 at 6:27 AM
    #555
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    I'm using the third mounting point on the LC200.
    Also did the double shear mounts on the other two mounting points.
    Those options came out from Marlin just as I was putting my kit on.
    I also added gussets/reinforcement to the lca and upper coil bucket tower.
    That tundra rack looks so beefy :militarypress: even compared to the LC200.
    I do like that the LC200 doesn't need much modification to work with the RCLT kit.
    The RCLT spindle with it's douple sheared tie rod connections is pretty sweet.
