RCLT HD 2.75" - Travel Numbers and Notes
Discussion in 'Long Travel Suspension' started by Tacoma1192, Jul 13, 2022.
  1. Sep 16, 2022 at 9:00 AM
    #121
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Grease them, they shouldn't be making noise!!
    ovrlndkull[QUOTED] likes this.
  2. Sep 16, 2022 at 9:51 AM
    #122
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Never heard of "maintenance grease schedule" for RCV CV's. I would think they would make that more well known of a thing you need to do if it's that important.
    Obviously if it's leaking grease every now and then you should top it off and make sure there's enough in there, but I can't imagine you would be needing to replace the grease at a scheduled interval if it's not leaking.
  3. Sep 16, 2022 at 11:03 AM
    #123
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Few of those LT kits mentioned...people have successfully RACED on them...more than once even lol. Saying that they're light duty is a flat out lie...to the folks that have never experienced offroad racing it is the most brutal thing you can put a vehicle through. Comparing some of those kits with a kit that's intended to bounce around on big rocks at .1 mph is silly. Yes stuff breaks crawling like tierods and axles but that's usually about it.
  4. Sep 16, 2022 at 11:05 AM
    #124
    Basikbiker
    Trav
    Sooo by that rationale you don't need to change gear oil in the diff if it's not leaking??....grease breaks down too like any other lubricating agent
    ovrlndkull and slander like this.
  5. Sep 16, 2022 at 11:15 AM
    #125
    erok81
    erok81 Well-Known Member
    Imposter
    How often are you pulling your CV’s, pulling the boots, cleaning/replacing grease, and reassembling? That’s a maintenance item I’ve never even thought of.
    whatstcp, Slashaar and EatSleepTacos like this.
  6. Sep 16, 2022 at 11:16 AM
    #126
    slander
    Hickory, NC
    Read up on what you bought.
    https://rcvperformance.com/faq#:~:text=Q: How often should I,of the outer stub shaft.
    And you don't replace grease, you add grease to them. Like u joints, are you cleaning the grease out of your u joints evreytime you service them, no you are adding grease to them. Yes I know it flings out, but I'm talking popping the caps off.....
    T.Barn likes this.
  7. Sep 16, 2022 at 11:34 AM
    #127
    Basikbiker
    Trav
    Once a year, but I also got manual hubs 70% of the time I drive my truck they arnt even spinning. The class 10 car I used to work on here and there, every trip all the cv's get gone thru and repacked...granted that's an extreme situation but still.
    Fancy type CV's are expensive, grease is cheap.
    Pretty standard workin with 930, 934, etc. Type of joints...lot of stuff wiggling around in there, generates heat. If you think about it, makes sense to service em here and there
  8. Sep 16, 2022 at 12:05 PM
    #128
    erok81
    Imposter
    Yeah exactly. It never crossed my mind until your comment then thought I guess that’s true. The grease is going to eventually breakdown.
    I can also say that is definitely not something I would look forward to. I hate packing stuff or really anything with large amounts of grease.
    If I had fancy ones I’d for sure take better care of them as well. I only have the factory ones on mine.
    Slashaar likes this.
  9. Sep 16, 2022 at 12:05 PM
    #129
    betterbuckleup
    Ian
    Concord, CA
    You got me there, just something I never thought of I guess or really read about anywhere.
    Hm didn't see that. Glad I know that now and not like 20k miles down the road with zero maintenance on them.
  10. Sep 16, 2022 at 12:10 PM
    #130
    Basikbiker
    Trav
    Oh it sucks to service em, makes a mess..short story....my aunt is a vet and does like big animals, horses etc. I have robbed some of those gloves that go up past your elbow to mess with CV's I get the grease everywhere lol
    erok81[QUOTED] likes this.
  11. Sep 16, 2022 at 12:17 PM
    #131
    Tac05
    Tac05 Unknown Member
    2005 Tacoma DCLB
    The CVs are from RCV and the warranty only applies to their Ultimate Axles. From what I can tell they only honor the warranty if the shaft breaks. If it is twisted and unusable then there is no warranty.
  12. Sep 16, 2022 at 12:43 PM
    #132
    betterbuckleup
    Ian
    Concord, CA
    I just called RCV to double check that and they said there is no interval you should be changing out that grease in IFS CV axle boots.
    I'm not disagreeing with anyone here or saying that it isn't a good idea to do some precautionary servicing here and there, just stating what they told me.
    The greasing interval definitely holds true for solid axle RCV's though.
  13. Sep 16, 2022 at 3:17 PM
    #133
    Basikbiker
    Trav
    Kinda funny there's an interval for solid axle stuff where the CV only sees spin and turning motion, and not the IFS stuff that sees spin, turn, and up,down motion. The joint sees alot more movement in an IFS application...wierd
    CGoss likes this.
  14. Sep 16, 2022 at 3:43 PM
    #134
    betterbuckleup
    Ian
    Concord, CA
    They must figure that the joints on the solid axles are more exposed to the elements than a sealed boot on the ifs cv's totally encapsulated in grease. Not to mention a much higher volume of grease in the boots.
  15. Sep 16, 2022 at 6:37 PM
    #135
    CGoss
    CGoss Well-Known Member
    Las vegas
    2006 rad red offroad
    Figured that, so that statement about RCLT having an advantage because of the RCVs is moot.
    I can buy RCVs for other LT kits and get the same warranty.
    Slashaar and Basikbiker like this.
  16. Sep 17, 2022 at 4:12 AM
    #136
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Welp yeah... There goes that. Again though, idk what kind of torque you'd have to apply to an RCV to break it that wouldn't utterly destroy the front diff.
  17. Sep 17, 2022 at 7:20 AM
    #137
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    FYI - RCV actually had such a bad run with their 2nd gen Taco axles breaking a few years ago that they stopped production for what seemed like a year or more during a redesign process.
    Slashaar[QUOTED] likes this.
  18. Sep 19, 2022 at 6:34 AM
    #138
    Slashaar
    Josh
    Kansas City, MO
    Ooof.
  19. Sep 25, 2022 at 4:09 PM
    #139
    Trail.ready.designs
    Trail.ready.designs Member
    98 taco 2uz v8 5spd
    LC 9.5 diffs, lockers, dual cases, 5spd R150 linked, Hellfire knuckles, Fox coil overs, ruffstuff front housing, FZJ80 full float rear w discs
    well it would be hard to not destroy stock tacoma racks in short order with 35's if you wheel. Without a stronger rack you are throwing money away. just my 2cents.... based on real personal experience. TRE's will be toast inner/outer in no time as well from trying to move the entire truck against a rock when its off camber.
    I think all of Big Mikes comments need to be considered only in the context of 'rock crawling' as is their claim. If you dont care about rock crawling, then why get the RCLT? OBVIOUSLY other long travel kits DESIGNED for speed will thrive in their specified purpose.
    And none of us REALLY know how well the kit will hold up to actual crawling anyway... sure there's videos of BigMike doing stuff but thats just one skilled driver. Crawlers want rigs that can handle whisky throttle at 2am with one eye open. So until i see someone actually abuse this kit on the trail, even though Im "certified" to install it, all of these arguments are moot to begin with.
    While Im a big fan of math and agree with such explanations, Ive seen 40 yr old 1st gens with stock axles on 40's do impossible feats given their so call mathematical "limitations" ... lets give some real drivers a chance to thrash this shit for a few years a see exactly what happens.
    If someones really beats the hell out of it and doesn't completely destroy it, I would say its a pretty epic improvement to the world of IFS suspension. I've seen top of the line TC LT kits wasted almost all components in just 2 years of aggressive STREET driving ...
    so who's gonna give it the skinny at 2am first and see if its worth the hype :brianr:
    :cheers:
    eimkeith, slander, Ricardo13x and 2 others like this.
  20. Sep 25, 2022 at 4:30 PM
    #140
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Exactly. Bring that shit over here and let some folks beat on it properly. Shit box crawlers only. None of these Instagram trucks. Granted Tacoma and crawler is still kind of hilarious to hear in the same sentence.
    Ricardo13x likes this.
