re-gear questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomo17, Mar 21, 2021.
  1. Mar 21, 2021 at 8:12 PM
    tacomo17
    tacomo17 [OP] New Member
    Brado
    2017 tacoma sr5 silver
    so far just put on 275/75/17's
    New here, I have the with the v6 6 speed automatic, a 2017 tacoma sr5.
    I put on an plan on keeping 275/70/17s on the stock wheels, and I now am wondering which gearing is best for what I have going on 4.88 or 5.29? if you have questions or thoughts/answers lmk
  2. Mar 21, 2021 at 8:14 PM
    Synergy001
    Synergy001 IG: @pnwx.taco
    PDX
    00 ACLB -Daily, 16 DCSB -Adventure Rig
    My truck felt fine without a re-gear when I had 275/70/17 years ago. I'd say 4.88 will be perfect if you are going to stay with that tire size.
  3. Mar 21, 2021 at 8:56 PM
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
  4. Mar 22, 2021 at 2:00 AM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    I wouldn't overthink things. It's only 150-200 RPM difference at freeway speed between the 2. Either one would be good. If you spend more time driving 70 than city driving then go with 4.88s. If you are on surface streets or keep your speeds limited to 60 and below than 5.29s would probably be better but neither one would be a bad choice and both are a huge bonus over stock gears
  5. Mar 22, 2021 at 3:17 AM
    JEFFRPM
    JEFFRPM Well-Known Member
    Jeff
    2018 inferno Double cab long bed 4x4
    17 x 8.5 KMC wheels, yokohama 285-70-17 geolander, 3" lift, 800 watts of alpine, leer shell, front & rear cloud cameras,
    4:88 is alot stronger than 5:29 (more pinion teeth in contact with ring gear)
    Do the 4:88 If you really think you need it with that tire size
