Re-painting fenders some disassembly required?
Discussion in 'Detailing' started by BBlank12, Jun 26, 2013.
  1. Jun 26, 2013 at 8:12 AM
    BBlank12
    BBlank12 [OP] Active Member
    Brandon
    Dodge City KS
    01 prerunner 230k stock
    Kicker L7 with rocksford amp controlled by double din pioneer.blacked out grill with red yota emblem and SteelCityAirman Bed decals
    we have all had those wonderful black fenders that turn not so black after years of joyful use. after 12 years my 2001 tacoma needs a some touch up. i have obtained the paint but i would like to see if anyone has some good tips for removing the fenders properly along with some painting tips for the fenders as well.
  2. Jun 26, 2013 at 8:19 AM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
  3. Jun 26, 2013 at 8:19 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    There really is no need to remove the fenders if you can mask off the area around them. If you do wish to remove them anyway you will find a bolt hidden behind the front door opening, as well as 2 bolts underneath the fender at the door. Then remove the clearance light and you will find a few that you can get behind it. Also the small "filler" panel under the headlight needs to be removed to reach a bolt there. Then remove the inner fender liner. After that there are several bolts you will reach from under the hood. Fender should easily come off at this point. I always use a lot of 2 or 4 inch masking tape to tape the door panel because no matter how hard you try, you eventually end up hitting the door slightly, and you don't want to scratch the paint. How are you planning on painting it? Rattle can or 2-stage?
  4. Jun 26, 2013 at 8:21 AM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    he did say "fenders" but i think he meant to say "fender flares". i suppose you could mask off the flares but it's probably ultimately easier to just remove them...
  5. Jun 26, 2013 at 8:43 AM
    BBlank12
    Brandon
    Dodge City KS
    As of now i have removed the front driver side fender i did break off those clips. :( i sanded with 400 then hit it with some rustolem primer a few times then a coat of rustolem black trim paint. it seems to have a few finger prints or something that smugged the paint but i am going to put another coat on today. i have having trouble removing the rear flares also
    *I am refering to the fender flares
  6. Jun 27, 2013 at 3:35 AM
    Mr. Biscuits
    Mr. Biscuits gentleman, scholar, part-time delinquent
    Brennen J
    Bakersfield
    2000 PreRunner TRD V6
    -Bilstein 5100/ Eibach 3" lift -Custom 2" lift rear leaf pack -Crystal clear headlight housings -updated (01-04) rear tail lights -custom front tube bumper -custom rear tube bumper -Deckplate mod -Aero Turbine 2525 exhaust -Kenwood Headunit -Pioneer Speakers -black door handles -Debadged, rebadged black -Ultraguage
    sucks for 01-04 tacos
    the 98-00's are just screwed into the fender. no clips, no breaking!
    repainted mine about two months ago and loved the way it refreshed the look of the truck. painted the front bumper black as well.
  7. Jun 27, 2013 at 10:50 AM
    BBlank12
    Brandon
    Dodge City KS
    i just finished the fronts broke all but 5 clips. im hoping the paint will make it through a few washes...unlike my tool box
