re using basically new u bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011trdsportmg, Dec 1, 2023.
  1. Dec 30, 2023 at 8:05 PM
    #41
    bevo2000
    bevo2000 Well-Known Member
    Plano, Texas
    2005 Tacoma DCLB 4.0 4x4
    Thank you for the diagram. Do you have a way to look up the part numbers for the bushes in the diagram? I would like to order those.
  2. Dec 30, 2023 at 8:07 PM
    #42
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
  3. Dec 30, 2023 at 8:09 PM
    #43
    bevo2000
    Plano, Texas
  4. Dec 30, 2023 at 9:17 PM
    #44
    2011trdsportmg
    2011trdsportmg [OP] Member
    Tommy
    CT
    2017 TRD Off Road
    Falken Wildpeak AT4W 265/75R16, Baja Designs Squadron SAE Fog Lights
    Ended up buying these ones, size 6.75”. They worked perfect with my 3rd gen leafs
  5. Dec 30, 2023 at 9:26 PM
    #45
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Good to know. I will measure and order a set tomorrow. Son has 180k on my old 2012 and those springs are way beyond WD-40 squeaky. Got a super low mileage set from a 3rd gen Sport for $100. No brainer. My 2008 has fairly new recall leaf springs and new 3rd gen Off Road coil/strut assemblies. In the spring I am going to find some 3rd gen front strut assemblies for him. I take advantage of every opportunity to teach him to work on vehicles so he can eventually take over servicing the family fleet.
  6. Dec 31, 2023 at 9:36 AM
    #46
    mrproduxn
    steve
    Retired DoD SE VA
    Ordered the wheelers u-bolt kit. Appreciate the input on that. Next question. Best place to buy shackle bushings. With 180k miles I know they are a squeaking contributor and are most likely dry rotted.
  7. Dec 31, 2023 at 9:40 AM
    #47
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
  8. Dec 31, 2023 at 10:28 AM
    #48
    mrproduxn
    steve
    Retired DoD SE VA
    Has anyone used this bare shackle kit. PN 04005-65104. I want this to be a quick process without being tied up with cutting out the sleeves on the old shackles. This kit seems to be a time saver. Also looking to verify PN 90389-A0003 is the correct oem shackle bushing part number. All of these are from toyotapartsdeal.com and I have this stuff in my cart. It is $62 shipped. Cheaper than buying the poly bushing kit and the 2023 leaf springs only have 700 miles on them. No need to replace those 4 bushings and it seems nobody sells only the 4 shackle bushings at a reasonable price.
    NEVERMIND. It took me hours of searching different sites but finally verified the part numbers were correct and ordered oem shackle bodies and oem shackle bushings.
  9. Jan 11, 2025 at 8:54 AM
    #49
    Claytonb
    Claytonb Well-Known Member
    Clayton
    2016 TRD Sport
    6” BDS Lift
    I will be reusing the U-bolt that came on the springs I installed a few months ago, I am adding a half inch spacer which moves the nuts down a half inch so it’s mostly on new threads as opposed to torqued threads.
    I would think if you were not replacing anything in there just putting the nuts back to the position they were in you might be concerned about the threads, I’m pretty certain that there’s a lot of bush fixes out there that I’ve never replaced a U-bolt
  10. Jan 11, 2025 at 10:01 AM
    #50
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    Not sure why?
    Why wouldn’t you have to replace all bolts or studs?
    Look how many times a lug nut is torqued over a vehicle lifetime.
    winkel likes this.
