Re-Worked Bumper good advice guys
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tepidy, Oct 10, 2011.
  1. Oct 11, 2011 at 4:52 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Not gonna lie, the first version looked like crap. It looked like someone punched your truck and gave it a fat lip. But this one looks awesome! I'd totally rock that on my truck
  2. Oct 11, 2011 at 5:01 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    02 PreRunner DoubleCab TRD
    Bull bar, nerf bars, bed extender, tonneu cover, bug deflector, wish list,....
    I think they both look good. In fact, I think the first one's corners are stronger and will take more abuse.
    Good job!
  3. Oct 11, 2011 at 5:36 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Both are more than I could produce so I give you credit for making your own bumper! That being said, the second one looks much, much better! How come you stopped the sides short and didn't extend them to match the fenders though? Seems if you came down on the right spot you'd miss the plate bumper and land straight on the quarter panel.
  4. Oct 11, 2011 at 6:04 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Nice work.
    You should consider cutting a few holes in the front to allow more air to flow to the radiator.
    Also, you might want to give a little more space between the headlights and the wings. When you flex the truck offroad, the bumper will not move (frame mounted) but the cab will flex on its mounts. You'll end up popping your flares and headlights loose if it becomes a contest of cab vs. bumper.
  5. Oct 11, 2011 at 7:16 AM
    Tepidy
    Tepidy [OP] Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I am still giving that area some thought. I will eventually fabricate an add on to the bumper to cover that area. Thanks bro
  6. Oct 11, 2011 at 7:16 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Thats a good Idea I may do that. I left a half inch between the cab and the bumper so I will keep an eye on things Thanks
  7. Oct 11, 2011 at 7:32 AM
    Pugga
    Massachusetts
    F-150 Mod
    Work in progress, I like it! Still, a lot of work has gone into making that bumper. Looks good, keep up with the tweaks and you'll have a great looking plate bumper. 80 lbs is nothing, I'm surprised it's so light. I think most are about 100.
  8. Oct 11, 2011 at 7:35 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    MUCH better. Props
  9. Oct 11, 2011 at 7:35 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    used 3/16 plate all around.
  10. Oct 11, 2011 at 7:35 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i agree with all of this!
    looks great dude, wish i could make something like that...
