Read my v8 Evap results - Are they correct?
Discussion in '1st Gen. Tacomas (1995-2004)' started by COMAtized99, Aug 3, 2017.
  1. Aug 3, 2017 at 4:48 PM
    COMAtized99
    COMAtized99 [OP] Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    To keep this simple, Ill just say that I have a 2004 4Runner v8 and drive train in my 1999 Tacoma. I am trying to us the stock 99 Evap box (mounted on the driver inner fender behind the fuse block). The 2004 4runner uses an Evap box that is mounted under the body, by the tank. I am attempting to use the old style evap system to keep from having to swap a pile of parts...
    with that said, I have come up with a system that seems to function. I have the Fleebay version of Toyota's Techstream. With this I have gotten the following results. Teachstream has a 6 step process.
    Step 1: Pressure Equalize
    Vapor Pressure (Gauge) [VP G] : .735
    Vapor Pressure (Absolute)[VP A] : 762.7
    Purge VSV - Closed
    CCV- Open
    Step 2: Purge w/ Can Control VSV open
    VP G : -1.5
    VP A : 760.5
    Purge VSV- Open
    CCV- Open
    Step 3: Pressure Equalize
    VP G : .735
    VP A : 762.7
    Purge VSV- Close
    CCV- open
    Step 4: Sealing System
    VP G : Start .735 then rises past 13
    VP A : Start .762.7 then rises past 775
    Purge VSV- Closed
    CCV- Closed
    step 5: Apply Vacuum
    VP G : -12.3
    VP A : 749.7
    Purge VSV- open
    CCV- Closed
    Step 6: Vacuum Seal
    VP G : rise from -12.3 to 13+
    VP A : rises from 749 to 775+
    Purge VSV - Closed
    CCV- Closed
    To me, I would seem that the Purge VSV, CCV, and Vapor pressure sensor are working. However, the results in step 4 and 6, dont really seem correct to me. I would assume that these numbers mean I have a leak....
    I should also note that that the fuel tank IS full. It says in the instructions that the fuel level should be between 3/4 and 1/4 tank... Maybe this is my problem.
    I have not yet driven then truck yet with this new vacuum hose routing. I plan to in the coming days. I am typing all this in hopes that someone might be familiar with EVAP stuff and be able to tell me what I'm looking at.
  2. Aug 3, 2017 at 5:48 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    yes, fuel needs to be between 3/4 and 1/4. It will not 'ready' unless in that range.
  3. Aug 3, 2017 at 6:31 PM
    Wulf
    Wulf no brain just damage
    rock raisin
  4. Aug 3, 2017 at 6:42 PM
    Glamisman
    Glamisman Well-Known Member
    for the Evap monitor to run complete it requires 2 complete drive cycles, preferably with an over night sit. Coolant temp and air temp have to be within I think 15 degrees of each on a cold start.
    Is she throwing a code?
    mechanicjon and Dalandser like this.
  5. Aug 4, 2017 at 3:47 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    You want a picture of my EVAP box?
    I am familiar with the parameters, I was really just hoping that someone well versed in emmisions monitoring could tell me if the results seemed correct or if I was going to get more codes. I guess I'll just have to wait and see.
    Prior to rerouting some vacuum lines I was getting a P0446, and P0452.
  6. Aug 4, 2017 at 7:18 AM
    thoth
    thoth Well-Known Member
    Culper
    2002 Tacoma SR5 3.4L V6 PreRunner
    no , pics of this v8! that sounds sic.
  7. Aug 4, 2017 at 7:43 AM
    tony2018
    tony2018 Well-Known Member
    Sayin...
  8. Aug 4, 2017 at 10:13 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    I have a build thread in my sig I thought
  9. Aug 4, 2017 at 10:27 AM
    tony2018
    Thread, that lead to another thread.. worst pictures are dead....
    :ded:
    My dreams have died.
  10. Aug 4, 2017 at 12:19 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    Pics should not be dead now. tbob fixed it I thought
  11. Aug 4, 2017 at 12:25 PM
    tony2018
    The issue is with photobucket. They charging people to host images externally.
  12. Aug 4, 2017 at 12:56 PM
    COMAtized99
    North Carolina
    99 DCLB v8
  13. Aug 4, 2017 at 12:58 PM
    tony2018
  14. Aug 4, 2017 at 12:59 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    Oh, that's the one in my sig? Hmmmm. Yea, I haven't been on TTORA for a few years now.... My Tacoma world thread is pretty much current...
  15. Aug 4, 2017 at 2:11 PM
    tony2018
    Well it was in the thread that was in your sig. I believe you said more details were listed at TTORA. But no biggy though.
  16. Aug 4, 2017 at 2:32 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    I updated it. Some stuff was more detailed in the beginning...
    Can I have my thread back now? :anonymous:
  17. Aug 4, 2017 at 2:37 PM
    tony2018
    I never took it LOL. Sorry.
  18. Aug 4, 2017 at 7:15 PM
    thoth
    Culper
    thanks for the effort dude,
  19. Aug 5, 2017 at 5:55 AM
    tony2018
    As for the original question, if you're not throwing any CEL, and your handy dandy ecu tool is giving you readings I'd say you're fine.
  20. Aug 5, 2017 at 6:24 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    I currently have a pending p0446
