Reading a dipstick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by geochurchi, Dec 19, 2015.
  1. Dec 19, 2015 at 11:48 AM
    geochurchi
    geochurchi [OP] Well-Known Member
    NH
    Tacoma
    Hi All, is it me or do others find it difficult to read the oil level, drained and refilled changed filter poured 5 Qts in spec calls for 6+, start the engine and recheck and oil level always appears high.
  2. Dec 19, 2015 at 11:51 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    V6 requires 5.5 quarts with the filter change.
    You need to let the oil settle in the engine and dipstick tube to get an accurate reading.
  3. Dec 19, 2015 at 12:05 PM
    geochurchi
    NH
    Tacoma
    It's a 4 cylinder and requires 6 Qts with filter, I have let it sit, seem like oil migrates up the stick even after I wipe it down.
  4. Dec 19, 2015 at 12:13 PM
    File IFR
    Central MA
    It seems like that, but the tube is splashed with oil.... it has to settle. Oil won't wick up onto the stick.
  5. Dec 19, 2015 at 12:21 PM
    jibski
    jibski Well-Known Member
    Josh
    Arvada, CO
    2009 Silver 2.7 AC 4X4
    I just changed the oil on my 4 cylinder and had the same exact problem...it read high even after letting it sit for a while. I came across another post that suggested pulling the dip stick out and leaving it out while you let it sit for a while. Then reinsert the stick and read it. When I did this, there was a clear mark right on the upper dimple. And I used almost exactly 5.5 quarts for my oil change FYI. I think the problem is oil doesn't drain out of the dip stick tube very well with the dip stick in place.
    bax, TaCoLoCoMaN and Taco15Bob like this.
  6. Dec 19, 2015 at 12:35 PM
    Tacoma Mike
    Southern Maine
    Oh boy.
    Our dipsticks suck...
    According to my fill gun.
    The 4 cyl takes about 5 1/4.
    The same for the v6.
    All depends on drain time etc.
    6 quarts is way to much . Don't care what it says online.
    Then after start up. Let it sit for a couple of min and start checking.
    Usually after about 7 tries you'll get a good read. The longer you wait the higher the stick will read.
    You need to decide your std oil change procedure. Some wait 2 min. Some wait 10.
    You will get a ton of replies.
  7. Dec 19, 2015 at 12:53 PM
    chunt5
    chunt5 Senior Citizen Member
    chuck
    Cumming, Georgia
    2015 DCSB, Prerunner, SR5, 4.0
    I had one heck of a time reading the dip stick on my last Tacoma, a 2012 I4. The dipstick on my current Tacoma, a 2015 V6, is much easier to read.
  8. Dec 19, 2015 at 1:34 PM
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    I've heard of some people bead or sand blasting the end of the dip stick to make it easier to read.
  9. Dec 19, 2015 at 1:37 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    This is a commonly discussed problem here. The 4 cylinders are especially notorious for this. Manual calls for 6.1, but if you put 6.1 in it will always be past the full mark on the dipstick. The conclusion that I and many others (but not all) have reached is that 6.1 is for a dry engine. When you drain your oil some is still in there sticking to stuff in the engine. I did 5.75 on mine and it brought me right to the full mark. I will have to pull my manual out to confirm this, but I believe it says to go by the dipstick. Nobody seems to have engine problems whether they use 5.5 or 6.1 though.
  10. Dec 19, 2015 at 1:38 PM
    JeffreyB
    Jeff
  11. Dec 19, 2015 at 1:38 PM
    weldo
    Pittsburgh, pa
    Add far as oil level, whenever I change my 4 cyl I usually end up only adding around 4.5 quarts before the dip stick reads full.
  12. Dec 19, 2015 at 1:43 PM
    JeffreyB
    Jeff
    I think it depends heavily on how long you drain it. I had to make 2 trips around town trying to find an oil filter wrench that would get the damn factory one off, so mine drained for about 2 hours.
  13. Dec 19, 2015 at 1:45 PM
    weldo
    Pittsburgh, pa
    True. Mine will drip a steady very thin stream for a while. Usually by the time the filter is off and replaced I seal it back up.
  14. Dec 19, 2015 at 1:53 PM
    JeffreyB
    Jeff
    That is funny, I ended up with about 4 or 5 different kinds including what I already had, and this is exactly the one that did the trick.
  15. Dec 19, 2015 at 2:23 PM
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
    This problem reading dipsticks pops up once in awhile. Someone suggested lightly filing one side, worked for me.
  16. Dec 19, 2015 at 3:14 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    5.5 + .5 that is left in motor = 6. Don't bother with dip stick unless U R checking between OC. Mine doesn't use oil so I don't check - some of the newer one use oil because they are using weaker piston rings to get better MPG for the EPA. I think there is a recall on some because of this.
  17. Dec 19, 2015 at 6:38 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    A little sand paper does the same thing.
  18. Dec 19, 2015 at 9:41 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    This
    I've owned a number of Toyota's and all but one of them reads over the full mark after draining and refilling with the amt. called for in the owners manual. Oil is always drained with engine hot and I allow it to drain for a good long while, therefore there is little or no residual oil left over.
  19. Dec 19, 2015 at 10:17 PM
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    At my next oil change, I plan on doing a little experiment and go quart by quart and see what the dip stick reads, or what it looks like. After so many oil changes and looking at the dip stick, I am starting to see how some could get 6 qts. Last time, just for kicks, I dipped the dip stick in a 5 qt jug of oil just to see how it would look. The pattern left behind was a clear film of oil where it was obvious where the oil level was. Granted, the dipstick didnt have to hit any bends or curves like it does when it is in its tube. What throws me off is that theres no distinct cut off line like in 99% of all the other cars I have ever checked. It just leaves this inconsistent film of oil, which I think is the trick to reading it accurately. At the last oil change, i put in the 6 qts and yes, it went over, but the amount that went over the full mark didn't completely cover the dipstick. The area below that had a solid film. I inspected this under all kinds of lighting just to make sure and it seems consistent. Or maybe I am just being a bit OCD over this. Can you guys confirm?
  20. Dec 19, 2015 at 11:01 PM
    JeffreyB
    Jeff
    I think the bottom line here is that a half quart either way seems to be immaterial since people who do it either way don't have engine problems.
    That is actually one of the reasons I landed on 5.75. Either seems to work fine so splitting the difference should do well. Personally I'd rather run shy of full than over full to avoid blown seals and it will still be in the operating range.
