Reading a dipstick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by geochurchi, Dec 19, 2015.
  1. Dec 19, 2015 at 11:55 PM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    This is you and me both - glad someone else had the same problem. I now have 4-5 different oil filter wrenches that I bought trying to get my '15 I-4's stock filter off haha. Took me a few hours, as well. Glad to hear that I'm not just a weakling! Finally got it off, though, and was hooting and hollering all over my garage like a moron.
    Back to the original issue - lots of guys report this. My dipstick sucks to read - I just gave up. I just put in right around 6, as the manual calls for. You'll be good.
  2. Dec 20, 2015 at 8:40 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    I rough up my dipsticks with an engraver, makes it a lot easier to read. Drilling the full mark dimple out with a 1/16 bit helps too.
  3. Dec 20, 2015 at 8:59 AM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    I let mine drain for exactly 1hr, put 6 qrts in and its always right at the full mark and no issues what so ever.
  4. Dec 20, 2015 at 9:01 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I did the same - took a file to the one side. It's not perfect, but it's good enough. I always put the right amount in anyway and let it 'settle' - just as a backup check.
  5. Dec 20, 2015 at 1:07 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    How is that going to blow a seal?
    The manual says 6.1 US Quarts with a filter. I just throw in 6 quarts.
  6. Dec 20, 2015 at 1:27 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Something about a penguin on a motorcycle, a mechanic, and ice cream... ;)
    DoorDing and Jimmyh[QUOTED] like this.
  7. Dec 20, 2015 at 1:28 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    LOL! Haven't heard that one in a while.
  8. Dec 20, 2015 at 1:30 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    One of my favorite old jokes.
  9. Dec 20, 2015 at 1:40 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Just in case someone hasn't heard it:
  10. Dec 20, 2015 at 1:40 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Blowing seals is one of the biggest risks of overfilling on oil. Pressure gets too high, seals blow.
  11. Dec 20, 2015 at 1:47 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No, The oil pump puts out the same pressure regardless of how much oil is in the system.
    The biggest risk of overfilling the oil is if it is high enough for the crankshaft to slap it and cause foaming. The resultant air in the foam causes the oil pump to loose suction. The bearings then get burned from a lack of lubrication.
    High oil levels are not going to blow a seal.
  12. Dec 20, 2015 at 1:57 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    I was about to type this very thing, thanks for doing it for me Jimmyh. :)
    As far as adding 5.75 instead of 6 quarts... get out a 1 cup measure and look at it. Do you really thing that much more oil will blow a seal?? :giggles: Sorry, I can't help it. :D
    Just add oil per the manufacturer. Your engine will be fine.
  13. Dec 20, 2015 at 2:00 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Ed-Zackery what CurtB said!
  14. Dec 20, 2015 at 2:29 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    I never read the dipstick.
    Drain oil. Pour in 5.5 and done.
  15. Feb 21, 2022 at 5:36 AM
    #35
    NoMagicWand
    NoMagicWand New Member
    2005 Blue
    none
    It acts as though the oil is all the way up to the dipstick tube on the inside of the engine. If so then the idea of putting an o-ring on the dipstick end and creating a seal creates a vacuum that sucks oil up the dipstick tube when you extract it to take a look. Now when you go to stick it back in you are soaking it in the oil that is draining back down the tube. Only the first time out after settling a long while stands any chance of a good reading. Test the theory by removing the dipstick o-ring.
  16. Feb 21, 2022 at 7:02 AM
    #36
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    I buy a 5qt jug + 1 qt. I fill it with the 5 qt jug first, start it and let it run for a few minutes and then check it. However: the next day I pull the stick > before starting it after it has sat all night<<<. It's never at the top dot. I slowly add to it over the next day or so until it reaches the top dot. It takes about 1/3 qt to get it there. If I add 1/2 qt it goes over the top dot by quite a bit. Also another issue mine has is the stick really needs a good hard push to get it to seat all the way into the tube. I usually only check the oil when it has sat all day or night before starting it and I check the level before I wipe it off and then again after. They always match.
