READY-LIFT Leveling kit question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hops, May 23, 2009.
  1. May 23, 2009 at 9:16 AM
    Hops
    Hops [OP] Well-Known Member
    Gabe
    south mississippi
    08 Silver Streak Mica Access Cab 4X4
    Shock and leaf spring TSB, Neoprene seat covers, weathertech digital fit floor mats, vent visors, bug shield, secondary filter removed, K&N drop-in filter, century camper shell, 265/75R16 ATM's...
  2. Jul 28, 2009 at 10:55 AM
    Hops
    Gabe
    south mississippi
    Anyone?
  3. Jul 28, 2009 at 11:00 AM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    I know some people here have had spacers and then taken them off due to ride quality. Plus you can get less expensive ones from Toytec.
  4. Jul 28, 2009 at 11:00 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    you only need to look at the "similar threads" feature at the bottom of the page to see what other ppl think. imo, even if they "guarantee" factory quality ride, you'll find those who had kits like this complain of the harshness and crappy ride quality. search for bilstein 5100s and/or toytec coilovers for better riding options
  5. Jul 28, 2009 at 11:04 AM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    I got the same level lift, but Pro Comp 2.25" level lift and the spidertrax too, thou I use the 265/70-16 for daily driver.
    When I installed it, the truck was level with the TSB leaf pack, but I added a TSB AAL from Toytec and is not level anymore.
    Been a few months now and no problems so far.
    Side note, I had the opportunity to see and compare both Pro Comp and Ready Lift side by side and Pro Comp powder coat is thicker and have more wider and longer welds than the Ready Lift, both have the same specs aside from the welds and powder coating.
  6. Jul 28, 2009 at 11:06 AM
    Hops
    Gabe
    south mississippi
    Yeah i think im gonna go with 5100's, thanks guys...
  7. Jul 28, 2009 at 11:07 AM
    Mandy3206
    San Juan PR
    ^^ Ride is the same since no pre-load is applied to the spring, the only diference I felt was I was riding a little higher than before.
