Readylift lit kit or Leveling kit???
Discussion in '5 Lug' started by jmtz14690, Mar 7, 2011.
  1. Mar 7, 2011 at 9:27 AM
    jmtz14690
    jmtz14690 [OP] Member
    Josh
    Albuquerque, NM
    06 Tacoma Access Cab 2wd 4cyl 5 speed manual
    Hi guys, so I want to do a mod to my truck which includes larger tires and either a leveling kit or a readylift lift kit and I need some assistance. I am debating between the Readylift 69-5510
    Toyota Tacoma 5-Lug SST Lift Kit, 2005-2011, 2WD - 2.75"F/1.75"R
    http://www.readylift.com/c-107-toyota-tacoma-5-lug-sst-lift-kit-2005-2011-2wd-275f175r.aspx
    or the
    66-5055
    Toyota Tacoma 2005-2011, 4WD & 2WD Prerunner - 2.25"
    http://www.readylift.com/c-83-toyota-tacoma-2005-2011-4wd-2wd-prerunner-225.aspx
    I have an 06 Tacoma 5lug 2wd 4 banger manual. I am trying to see which would be best to invest in for my truck. I want to be able to do some basic offroading and put 31 tires on it. I dont want to lose a lot of power or give up alot of MPGS. Can anyone give me some suggestions?? I would greatly appreciate it.
  2. Mar 7, 2011 at 9:32 AM
    ARC
    ARC Well-Known Member
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
    well of those two the first one because the second one will not fit your truck
  3. Mar 7, 2011 at 9:38 AM
    2010whitetaco
    2010whitetaco Well-Known Member
    Gaston
    Fort Worth
    single cab 5-lug
    ReadyLift 2 3/4 front 1 3/4 rear universal armrest Texas Rangers decal 235/75/15 Goodyear Duratracs Kobalt Slim Line Compact Truck Tool Box Secondary air filter removed TOYOTA decal on tailgate
    x2
    I have the first one that you listed and it was a great improvement over the stock height. Just be sure to get longer shock absorbers for the rear; otherwise when you add the extra leaf the stock rear shock will be overextended on bumps.
  4. Mar 7, 2011 at 9:47 AM
    mcleod90
    mcleod90 150,000 miles and counting
    sean
    modesto ca
    05 double cab
    Look into the fat bobs kit. It's cheaper and comes with a rear shock.
  5. Mar 7, 2011 at 9:57 AM
    ARC
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
  6. Mar 7, 2011 at 10:00 AM
    ARC
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
  7. Mar 7, 2011 at 10:03 AM
    ARC
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
  8. Mar 7, 2011 at 10:06 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    not sure how much bigger you can go with tires with under 3" of lift, you will need new rims or spacers and have to do some trimming i think
  9. Mar 7, 2011 at 1:39 PM
    jmtz14690
    Josh
    Albuquerque, NM
  10. Mar 7, 2011 at 3:49 PM
    Poot Klopp
    Poot Klopp Well-Known Member
    Ben
    New Jersey
    06 5 lug Access Cab
    16x8" American Racing Tactics - Kumho Road Venture SAT KL61 245/70 R16, URD Short Shifter, Wet Okole seat covers, Secondary air filter removed, aFe Pro-Dry S Air Filter, Soft Tonneau Cover, Debadged, Husky Floor Liners, OEM Toyota Bed Mat, GROM-AUX media connector with Bracketron mount, DIY Tailgate Lock
    I just bought the fatbobs today : )
  11. Mar 7, 2011 at 10:47 PM
    ARC
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
    Shocks are not included but I honestly doubt you need them. once it is installed you could measure to see what length you need and get them if you them. Shocks aren't too expensive. 31's should fit fine.
  12. Mar 8, 2011 at 8:29 AM
    jmtz14690
    Josh
    Albuquerque, NM
    Thanks. I just had an unexpected cost come up though so looks like getting a kit right now is a no-go :/
    I can still afford to get a set of tires though- do you think there is anyway a set of 30's would fit w/o mods? Or is the 235/75/15 the absolute max?
  13. Mar 8, 2011 at 9:36 AM
    mcleod90
    sean
    modesto ca
    05 double cab
    I've heard you can fit 245's. I put on 235's then a week later lifted it and now I want bigger tires. But I still think the 235's with an aggressive thread pattern looks really good. Check out my build
  14. Mar 8, 2011 at 10:35 AM
    jmtz14690
    Josh
    Albuquerque, NM
    Thanks! It looks really nice. I decided I am going to go with 235/75/15 Wrangler Duratracs so they should look pretty mean.
  15. Mar 8, 2011 at 4:08 PM
    Poot Klopp
    Ben
    New Jersey
    06 5 lug Access Cab
    lots of people are running 245/70 R16 with no problems fyi
  16. Mar 8, 2011 at 4:33 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    ya but i think he was looking for tires to go on the stock wheels
  17. Mar 8, 2011 at 4:41 PM
    jmtz14690
    Josh
    Albuquerque, NM
    Thanks! I was looking to stick with stock wheels so I went ahead and ordered the 235s awhile ago. They'll be in and on my truck by Friday. I will upload some pics after.
  18. Mar 9, 2011 at 9:48 PM
    dcrawfo1
    dcrawfo1 Active Member
    Donny
    Greenville, SC
    06 Tacoma SR5
    06 tacoma. 3 in fat bobs leveling kit. 235 tires
    i have an 06 5 lugger and im runnin 30x9.5 on stock rims. had them like a year. no rubbing or any issues
  19. Mar 16, 2011 at 10:59 AM
    jmtz14690
    Josh
    Albuquerque, NM
    Got my tires installed on Friday, truck looks much better and ride is significantly nicer as well. Didn't have time to get some pics yet but will ASAP (camera needs batts).
    Thanks for your suggestions!
  20. Mar 16, 2011 at 1:13 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I run 31x10.5x15 with fat bob's lift kit on stock rims. Yes it rubs at full lock, but if you don't do full lock, its fine and looks great IMHO
