ReadyLift SST
Discussion in 'Suspension' started by QuandtPa15, Dec 22, 2019.
  1. Dec 22, 2019 at 1:51 PM
    QuandtPa15
    QuandtPa15 [OP] New Member
    I'm am looking to put in a Lift Kit on my 2019 TRD Off-Road. looking at the ReadyLift SST either 69-5212, 69-5530, or 69-5531. I was hoping to gain some insights about this. A shop that I went to to look into it said that they would recommend get UCA as well? I understand that the lift will change in angle with the ball joint, but how much of an issue is it? Any sort of guidance would be appreciated.
  2. Dec 22, 2019 at 1:57 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    All I can add is why spend over $30,000.00 on a truck to put such a crap lift in it? You can put Bilstein 5100's all around and lift the front for about the same money. I always say " Buy Once and Cry Once. " Spacer Lifts aren't crap, but why not do it right the first time, and UCA's are a must for some and for some not needed.
  3. Dec 22, 2019 at 2:02 PM
    QuandtPa15
    The 69-5531 comes with Bilstein 6112 for the front. why do you say crap lift?
    T4RFTMFW and whatstcp like this.
  4. Dec 22, 2019 at 2:05 PM
    tcjacado
    tcjacado Well-Known Member
  5. Dec 22, 2019 at 2:08 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Hmmmmmm looks like ready lift upped their game a little.
    shane100700 and tcjacado like this.
  6. Dec 22, 2019 at 2:13 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    So how is it lifted? Looks like it's still a spacer on top plus whatever ring you set the 6112's on? And junk blocks in the back. $1100.00 for that? You can do better for that money.
    whatstcp and tcjacado like this.
  7. Dec 22, 2019 at 2:13 PM
    QuandtPa15
    what would you recommend for UCA then?
  8. Dec 22, 2019 at 2:30 PM
    QuandtPa15
    I'm wanting to do ReadyLift because I get discounted pricing because of my work, i would only be spending $850 on that kit. I do like to keep my truck clean, although most of my driving is going to be on paved roads, I will be doing some off-roading as well. I'm sorry I am new to the Forum, what is AAL?
  9. Jan 4, 2020 at 7:53 PM
    GTCOMA
    GTCOMA Well-Known Member
    OH
    New Truck 2019 TRD Sport - Old Truck 05 TRD Sport
    AAL = Add A Leaf
  10. Feb 24, 2020 at 9:03 AM
    sandytaco17
    sandytaco17 Member
    2019 Quicksand Tacoma
    Hey guys, so what’s the verdict on the lifts? I have a 2wd sr5 and want to get a 3 inch lift to fit ko2 285/75/16. What lift do y’all recommend? I appreciate all the help! Total noob here :p
  11. Mar 19, 2020 at 5:01 AM
    Ncpi007
    Ncpi007 Well-Known Member
    Charlotte, NC
    2018 Tacoma TRD Off-Road
    I was at a shop yesterday and they were pushing the ReadyLift with Bilsteins all around, 6112 up front and 5100 in the back. I specifically asked about the block vs aal. They were adamant that aal is not needed unless I plan on hauling a heavy load, rack camper, etc. Installed out the door was around $1000.
    Can I put both the block and an aal?
    This is my weekend toy, typically using it for overlanding/camping once a month. The trails are not hard core.
  12. Mar 19, 2020 at 5:21 AM
    Ncpi007
    Charlotte, NC
    Thank you for the reply —— Funny that you ask, I was just googling UCA’s. In which, I had no clue what they are, not I guess I have some knowledge of them.......
    It looks like a crapshoot with Tacoma’s, off their website:
    ReadyLIFT BK
    · a month ago
    Yes, any rear shock designed for the amount of rear lift achieved can be used with our blocks. In some Tacoma applications Toyota made minor changes to the Tacoma upper control arm suspension geometry. In some cases adding a leveling kit MAY affect the ability to correct the caster alignment to within factory specifications. If you have a 2011-2020 Tacoma with a leveling kit and the caster alignment specs cannot be put back to factory your truck will require an aftermarket Upper Control Arm with adjustable caster/camber.
