Rear 1.5" AAL Installed
Discussion in 'Suspension' started by moondeath, Mar 30, 2012.
  1. Mar 30, 2012 at 9:34 AM
    moondeath
    moondeath [OP] Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I installed some Toytec 1.5" AAl's at the beginning of this week. I'm giving them a little time to see if they settle any before putting my 5100's on. I'm gonna try to level it as much as possible. Initial amount of lift after installing ended up being around 2''.
  2. Mar 30, 2012 at 9:44 AM
    dusman
    dusman Well-Known Member
    Dustin
    Windsor, Maine
    2017 TRD ORDC MGM
    nice, did you install them with TSB or no TSB
  3. Mar 30, 2012 at 10:26 AM
    moondeath
    Pa, Gardners
    No TSB.
  4. Apr 16, 2012 at 8:31 AM
    Tiresize33
    Tiresize33 Well-Known Member
    oregon
    Toyota
    50 series flowmaster all way from the cat duals, afe intake, HID 6K, debaged, leer canopy, roof rack and spare, back up lights, clear protectint on front of truck, tinted windows, weather tech floor mats, amp steps, 6in procomp coil over, badass stereo
    did it settle at all cause i am looking for 2 inches on my tacoma
  5. Apr 16, 2012 at 5:05 PM
    09Tacomania
    09Tacomania Well-Known Member
    Scott
    Little Rhody
    09 Silver Streak Dbl cab 4x4
    Icon CO's, LR UCA's, Icon rear 2.0 rear resi's, Wheelers 1.5" 3 pk aal, blacked out badges, Andre's devil horn's, Extang tonneau. Oem racks
    You cant go wrong with the $179. Wheelers 3 pk aal. FYI. Made my pk smile again and its smooth with the Icon's. I left my overload leaf in as i had the tsb pk and ended up with 2"+. It will settle a little in time. Had a 600 lb load in it yesterday and it barely sagged. Much better. If it last a couple yrs. I'll be happy. Then it will be time for a full pk replacement. The ass ends oem suck on these trucks.
  6. Apr 16, 2012 at 6:24 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I did the same thing with OME shocks all around and OME 886 coils up front. Love it!
  7. Apr 17, 2012 at 4:04 PM
    moondeath
    Pa, Gardners
    I just measured the rear. One side seems to have settled while the other seems to have stayed the same. Rear passenger measures 38" and rear driver 39". (Ground to wheel well center)
    I also installed the bilstein 5100's on the front 2 weeks ago set at 2.5". I still have about an 1" of rake.
    Just some additional info; my truck only has about 25k miles, so I didn't replace any springs just added the 1.5" AAL. No TSB in the rear. Front coil is factory.
  8. Apr 17, 2012 at 7:24 PM
    09Tacomania
    Scott
    Little Rhody
    Looks good!
