Rear 5100's with TSB springs
Discussion in 'Downsouth Motorsports' started by kws129, Aug 22, 2012.
  1. Aug 22, 2012 at 7:52 PM
    kws129
    kws129 [OP] Well-Known Member
    PA
    TRD Off Road Double Cab
    For the rear of the tacos what bilstein part # do we need for 2nd gen's with TSB springs?
  2. Aug 23, 2012 at 6:03 AM
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    Front King 2.5, Coilovers, Camburg UCA, Rear King 2.0 Shocks, Lots of Tinted Windows, Cherry Third Owner
    Good morning,
    The rear shock for a TSB and no other lift in the rear will be a RCD/BE5 C478 T0,
    or the Bilstein BE5-C476-H0 or the new Bilstein # is 24-186728.
    which is the same one you would use for the 1" lift rear non TSB.
    If you are going to install an AAL along with the TSB then you would need to
    let someone know how many inches of lift the AAL will add.
    Hope this helps.
  3. Aug 28, 2012 at 7:03 AM
    Snake~
    Snake~ Big Member
    Blake
    DFW
    2010 DCSB TRD Sport
    Autolumination Yellow fog light bulbs, Dynomax Ultra Flo muffler, AFE Pro Dry S air filter, tailgate security mods, TRD skid plate, DeeZee bed mat, Armor Lid tonneau, OEM roof rack, TRD center caps, Satoshi grille, Sockmonkey tailgate decal
    How about for TSBs + 1.5 AAL?
  4. Aug 28, 2012 at 7:28 AM
    TSB with a 1.5" AAL is in the same boat as the 2" rear guys.
    You are right in between the standard length rear shocks..BE5-C478-T0 or BE5-C476-H0 and the BE5-B110-T5...
    Most likely you will need to run the B110 rear shock, but you will need to modify your bump so that the suspension will bump out before the shock bottoms out.
  5. Aug 29, 2012 at 7:21 AM
    Snake~
    Snake~ Big Member
    Blake
    DFW
    2010 DCSB TRD Sport
    Is there a spacer to put under the bump stops or would something as simple as a few washers do the trick?
  6. Aug 29, 2012 at 7:22 AM
    No best bet would be to have something simple fabbed..
    You need the bump to bump out before the shock bottom out to be on the safe side so the shock does not get damaged.
