Rear a Tad Stff: Fox 2.0 with Resi and Icon Progressive AAL
Discussion in 'Suspension' started by Adventure4x4, Dec 9, 2016.
  1. Dec 9, 2016 at 11:40 AM
    Adventure4x4
    Adventure4x4 [OP] Well-Known Member
    Adam
    San Antonio, TX
    2013 TRD off road MT
    I just wanted to make sure and I contacted Falken and you are right, technical support recommended around 30 psi. Doesn't hurt to double check.
  2. Dec 9, 2016 at 11:41 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Let us know what you think after you drop pressure and go for a ride.
    Bonus points if you take a trip around the block first. Drop pressures. Then take the same trip for a direct comparison.
  3. Dec 9, 2016 at 11:46 AM
    Adventure4x4
    Adam
    San Antonio, TX
    I will do that...just about to leave work.
  4. Dec 9, 2016 at 11:57 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Just remember u do psi adjustments COLD
  5. Dec 9, 2016 at 12:01 PM
    Adventure4x4
    Adam
    San Antonio, TX
    So let the truck sit for a while before I adjust the psi?
  6. Dec 9, 2016 at 12:14 PM
    inwood customs
    Dave
    Its dependent on drive distance, and speed...
    i forgot the formula for time, but im sure google will help narrow it down.
    The more u drive, and the faster, the warmer the tires and the air inside so it expands.
  7. Dec 9, 2016 at 1:25 PM
    Adventure4x4
    Adam
    San Antonio, TX
    Yeah I am sure it's some derivation of PV = nRT. An increase in temperature is "x" amount in pressure change...and so on haha. Direct relationship between pressure and temperature is all that matters.
  8. Dec 9, 2016 at 1:26 PM
    T4RFTMFW
    Just drop it to 32 and drive the damn thing. Check it tomorrow morning for accurate cold PSI and adjust as needed.
    Adventure4x4[OP] likes this.
  9. Dec 9, 2016 at 2:22 PM
    Adventure4x4
    Adam
    San Antonio, TX
    So before actually saying I had the tires at 37 psi, I should have checked what they were actually at...35. Probably due to temperature drop lately, but anyways I dropped it to 32. Not much of difference felt, maybe a little. Ughhh...I thought this was going to be the solution.
  10. Dec 9, 2016 at 4:55 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I took the smaller leaf out of my 3-leaf with Icon 2.0 and it made a big difference. No overload either.
  11. Dec 9, 2016 at 4:56 PM
    T4RFTMFW
    Wonder how that effected your payload.
    Without the overload and with the full 3 leaf mini pack, it's a 10% loss.
    Have to figure you're at 15% loss of payload, at least, with that setup.
    inwood customs likes this.
  12. Dec 9, 2016 at 4:58 PM
    Justinlhc
    My kids are still pretty small so I don't worry much about it. It rides much nicer off-road.
    T4RFTMFW[QUOTED] likes this.
  13. Dec 10, 2016 at 6:49 AM
    Adventure4x4
    Adam
    San Antonio, TX
    I'm going to try putting a zip tie on the shock shaft and hit a few potholes and speed bumps to see how much the rear end is compressing. I might be imagining things.
    I should have enough droop too, right? The shocks were meant for 0-1" of lift and technically the truck was only lifted the thickness of the 3 leaf pack minus the overload leaf.
  14. Dec 10, 2016 at 10:09 AM
    Justinlhc
    Plus what the leafs added in the arch. My guess is it's 2"-2.5".
  15. Dec 10, 2016 at 2:23 PM
    #35
    inwood customs
    Dave
    1.5 without oL
    2.0 with OL
    typicals
  16. Dec 10, 2016 at 2:29 PM
    #36
    Justinlhc
    After it settles, yes.
  17. Dec 10, 2016 at 2:37 PM
    #37
    T4RFTMFW
    Say what?
    1" maximum lift height on the shock and you're running a 1.5"-2" (or more) AAL?
  18. Dec 10, 2016 at 2:43 PM
    #38
    Adventure4x4
    Adam
    San Antonio, TX
    Marie from Headstrong Off Road:
    "Rear shocks work a little differently. When sourcing rear shocks it is recommended to know what the extended and collapsed length of the shock is and how that works with the rear lift you are going with. For example the standard length Fox rear shocks are spec’d out for a 0-1” rear lift. However, you can utilize them for lifts outside of that range. It is how you are achieving lift that largely plays into this. Those shocks will work with an 1.5”-2” add-a-leaf lift because the add-a-leaf is only around 1/4”-3/4” thick but it re-arches the factory pack thus providing that much more lift."
  19. Dec 10, 2016 at 2:45 PM
    #39
    T4RFTMFW
    Thanks for the clarification.
  20. Dec 10, 2016 at 2:54 PM
    #40
    Adventure4x4
    Adam
    San Antonio, TX
    I have 4.5" for compression and 4" available for droop. The shocks seem to be compressing about an 1.5" during daily driving and if I do hit a larger pothole, the suspension certainly does compress more based on the zip tie. I'm sure it's all in my head and I am pretty sure I don't want to constantly hit the bump stumps when traveling at higher speeds off road anyways. For now I'm going to leave it. Maybe an entirely new leaf pack would be beneficial.
