rear add a leaf to fix tacoma lean?
Discussion in '1st Gen. Tacomas (1995-2004)' started by blakewhisenant, Mar 7, 2013.
  1. Mar 8, 2013 at 1:23 PM
    blakewhisenant
    blakewhisenant [OP] Well-Known Member
    Blake
    Oklahoma
    1995 Toyota Tacoma 4x4 V6
    lots to come...
    @ tacoMX I already am running 3 inch spacers above the coils. This would make it 4 inchs total if I add the toytec top mount 1/4" spacer.
    I was told that is to much. I sugested to toytec to make the passenger side coil spacer a 1/4" less than the driver side.
  2. Mar 8, 2013 at 1:32 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    The spacer to fix taco lean goes on top of the strut, wont raise that side more than half an inch at most.
  3. Mar 8, 2013 at 1:49 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    a single shim (spacer) on the drivers side CO
    should suffice for pre-loading that corner.
    I cannot say what thickness that should be...
    and it could be a trial/error thing.
    IMO... Coil (trim pak) shims are fine...
    external top loader spacers should be avoided.
  4. Mar 8, 2013 at 1:58 PM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    I already have the 3 inch coil spacers. The 1/4 spacer would put me near 4 inches on the right front corner. to much...
    What about rear air bags?
  5. Mar 8, 2013 at 2:56 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    Tho' air bags might work for street duty...
    they'd likely limit compression/droop off road.
    possibly a somewhat stiffer on road feel.
    seems like just another bandaide, for a real fix.
    Air bags are usually installed in support of heavier loads/towing.
    maybe I missed it... or just confused
    When you say 3" coil spacers... You mean:
    3" of total susp. lift ? or an actual 3" spacer ? :eek:
    In coil pak or top loaders ?
  6. Mar 11, 2013 at 1:47 PM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    Top loaders. The lift it self it 1.5 inches tall, I guess some how that gives me three inches total.
    I know its not the best style of lift but this truck is for the Home Depot and possible Zombie out break.
    I am looking into some pro comp rear springs, they say they add 5 inches of lift. I dont really want that. Only looking for three. That price is right on them at 108 a piece...
    Any ideas for rear leafs on a budget?
  7. Mar 11, 2013 at 1:58 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    The 1.5'' spacers give 3'' of lift because they are inline with the shock, and pushes down the coilover, yielding about 3'' at the end of the control arms.
    And there are no such thing as complete leaf springs on a budget.
    I would avoid pro comp, and if they give 5'' of lift, thats way too much.
    The only thing you can do on a budget is use AAL's, or rebuild your leaf pack like the TW member "4WD" did as shown in his thread:
    http://www.tacomaworld.com/forum/suspension/194386-tacoma-spring-refurbishing.html
    Or save your pennies and buy some decent leaf packs like alcan, deaver, all pro, or ome dakars. That option will cost you $400+
  8. Mar 12, 2013 at 7:15 AM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    did he just switch out some of the leafs from the other (s10) pack?
    So dont mess with the rockauto rear leafs?
  9. Mar 12, 2013 at 6:38 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    If you want some lift in the rear the Pro Comps will definitely give it to you. I put some on and it lifted the rear almost 4 inches (by my calculations). I REALLY like the look but the rear is now WAY higher than the front. I could have just brought the front up a little more to match the rear but I decided to take the Pro Comps off and put on some OE leaf springs. If you want to get some gently used Pro Comps let me know.
  10. Mar 12, 2013 at 10:40 PM
    TacoMX
    Jonathan
    Deltona, Florida
    not sure why procomp made springs that gives so much lift...considering on stock front suspension the max you can lift is 3''.
    Unless they are meant to be coupled with a DB lift or straight axle.
  11. Mar 13, 2013 at 11:40 AM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    How much lift was on your front end? 2.5 or 3 inches?
  12. Mar 13, 2013 at 1:01 PM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    I had about 2 inches of lift up front. I probably could have moved the front up a little more to get it closer to level.
  13. Mar 14, 2013 at 11:45 AM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    how much do you want for them? I am considering... Not sure I want to go that tall...
  14. Mar 14, 2013 at 11:49 AM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    They have universal 1/4 inch blocks you can add to the rear blocks, but may tweak all your angles, I don't know if it would be a good thing or bad, I think 4wheel parts should carry them, or a quick search online..
  15. Mar 14, 2013 at 5:54 PM
    #35
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    Shipping would probably be crazy but I would let them go for crazy cheap if you want them. $60 plus shipping. I think that qualifies as crazy cheap. I have only had them on thete for about two months.
