Rear axle alignment off
Discussion in 'Suspension' started by ikataco, Jan 5, 2010.
  1. Jan 5, 2010 at 11:16 PM
    ikataco
    ikataco [OP] Well-Known Member
    06 DC Sport
    I'm posting this for an older friend.
    2005 DC Sport longbed Auto
    2.5 inch lift spacer front
    1 inch iron blocks rear w/o TSB
    17 x 9 rims w/ 285/70/17 Revo2s
    He went camping and when he returned he noticed the rear driver's side axle is much further back than the passenger side(see photos). He works at Firestone tire center. They put his Taco on the alignment rack & sure enough the rear is not within spec. While driving straight, his Taco looks like it is in a constant drift.
    He stated the techs at his work(Firestone) loosen the u-bolts, settled the suspension, & re-torqued. No change. Any ideas on the cause?
    passenger side OK
    Driver's side, axle sits further back.
  2. Jan 6, 2010 at 4:18 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah....The axle wasn't bolted back up correctly after the blocks were installed.
    I had to use a hammer to fix mine.
  3. Jan 6, 2010 at 4:24 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Someone also stole 4 of your blue lugnuts or 2 of your chrome ones from each wheel.........& how much cheaper are blocks than AALs?
  4. Jan 6, 2010 at 8:05 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not sure why this would be the problem, but thought I'd mention it anyway.
    Look at your leaf springs & shackles / position while at rest. They should be relatively in the same position on both sides.
  5. Jan 6, 2010 at 8:06 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    the problem is that the blue lug nuts arent symmetrical
    crashngiggles likes this.
  6. Jan 6, 2010 at 8:14 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Pull the center pins from the leaf packs and inspect. If the ubolts were loose then the pins can bend and even break.
  7. Jan 6, 2010 at 9:03 PM
    ikataco
    06 DC Sport
    Thanks everyone, I've passed on the information to my friend.
  8. Jan 6, 2010 at 9:11 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    First off, tell your friend he needs to get an account here so you don't have to do his problem solving for you!
    Second, I've been in his shoes before...but much more extreme:
    I ran into a giant rock at 25+ mph. It sheared the centering pin and bent up the U-bolts a little bit. Not having enough money to afford the OME Dakar leaf packs, I just unbolted all 4 u-bolts, took apart the problem leaf pack, removed old center pin, used a nut and bolt I had lying around that fit perfect, and then put it back together.
    It still wasn't a perfect 100% aligned job, but it's supposed to be temporary anyways. My steering wheel is still not perfectly center when going in a straight line, but the U-bolts I put back on were still bent.
    Check the centering pin first to see if it's still straight.
    I would then try loosening all u-bolts, and then using ratchet straps hooked to something on the forward part of the truck to bring that side forward.
  9. Jan 7, 2010 at 5:28 PM
    silvertaco82
    silvertaco82 No way, get real
    Bozeman, MT
    2010 AC TRD Sport 4x4
    TRD Seat Covers, Weathertech floor mats, Sockmonkey Decals, Pro Comp 6", 35" Nitto Trail Grapplers, 18x9 XD addicts, 20% tint, Kenwood Dnx 5120, 2 10" Kicker Shallow mount subs
    i went to alignment shop and they said i have the same problem. They said just this that the u bolts must have not been tightened back up all the way after i did the aal
  10. Jan 7, 2010 at 5:36 PM
    ikataco
    06 DC Sport
    Damn! Did the rock hit the wheel, diff, or axle at 25mph?
  11. Jan 7, 2010 at 5:51 PM
    jandrews
    '09 FourDubDee TRD OR
    Ugh, spacers/blocks.
    This is advertisement #1 on why if you're going to lift a vehicle, it needs to be done right with a suspension lift.
  12. Jan 8, 2010 at 11:40 AM
    sachou
    Sam
    Just the wheel! Thank god for my beefy Mud-Terrains, if I had P rated tires they'd probably have punctured.
    If I had hit it just a few inches closer, I'd probably eff up the axle pretty bad...so good thing I only damaged the spring.
    x2
  13. Jan 8, 2010 at 4:04 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    ummm....technically, a spacer/block lift is still suspension...its not a body lift. it may not be the ideal setting, but suspension none the less
  14. Jan 8, 2010 at 4:35 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    And I had to same problem with my AAL...It was easy to fix. As I assume that the OPs problem will be.
  15. Sep 10, 2017 at 7:37 PM
    DylansBase
    DylansBase Well-Known Member
    Dylan
    Murfreesboro TN
    2007 DCSB Taco TRD Off-road
    Bilstein 5100 w/OME 886 All pro expo leafs w/icon 2.0 Relentless Fab plate bumper BFG KO2
    Old thread but how did you fix? Just did a AAL and my driver side is almost half an inch pushed forward
    TTOutsider likes this.
  16. Dec 24, 2018 at 3:12 PM
    thatguymichael
    thatguymichael Well-Known Member
    Texas City, TX
    2005 DC V6 TRD OR INDIGO PEARL
    3/2 Leveling Kit 20” Texas Edition Wheels Custom Grill TacomaBeast Headlights/Tails Chrome Door Handles & Mirrors FlowMaster Super 10 Exhaust Bully Bullbar
    Having the same issue if anyone has a fix after a leveling kit installation
  17. Dec 24, 2018 at 3:25 PM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    Blocks in rear or springs. Sounds like everyone is having issues with centering pin- if you used blocks they may be drilled off center.
  18. Dec 27, 2018 at 11:00 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    You can go to your local hardware store and get2 socket head cap screws (allen head socket drive) that are 3/8" and 4 inches long. I think I got 3.5 inches b/c I just have a standard leaf pack with an aal.
    Get 2 nuts for them and it's much cheaper than buying the centerpins online and paying $10 to get them shipped to you.
    I found my 2 plus nuts for less than $5.00 for both at my local store. PS: home depot and lowes didn't carry them (too short)
