Rear axle out of square
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crgrey42, Nov 6, 2019.
  1. Nov 6, 2019 at 9:09 AM
    Crgrey42
    Crgrey42 [OP] Well-Known Member
    Cory
    CNY
    Superwhite 13 TXPRO DCSB
    Currently running Dakar cs047R springs on my 2013. I just had new tires put on (285/75/16 ATX) and when doing my alignment we noticed that the rear axle was not square in the wheel well. It sits one inch farther to the rear on the passenger side. Being a leaf spring setup, I am not familiar with a way to fix this, or what is causing it. Some things to note: I have an allpro dual swingout rear with my spare and a rotopax mount (3 3.5 gallon containers), allpro sideplates and hitch, an ARE topper with roof rack, SOS sliders with fill plates, and ~150lbs in the back at all times. I am not sure weight makes a difference, but I would round that to ~500 pound daily carry. I do not have the extra leaf in the dakar springs yet as the ride/ride height is sufficient for what I do. Any ideas on what would be causing this?
  2. Nov 6, 2019 at 11:42 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    someone should correct me if I’m wrong, but I’m certain it’s possible to unbolt the leaf spring, move the axle the desired amount, and re-bolt the spring to the axle.
    When it comes to the root cause being something other than an assembly error in the factory, I’m not sure about that.
  3. Nov 6, 2019 at 11:46 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    No. The leaf spring has pin it the sits in a hole on the axle pad, there’s not nearly that amount of play in it. The axle can not slide back and forth on the leaf spring.
    127.0.0.1 and Muddinfun like this.
  4. Nov 6, 2019 at 11:48 AM
    Athlaos
    Leigh
    Edmonton
    Okay. Makes sense. It’s a strange problem.
  5. Nov 6, 2019 at 11:49 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Perhaps the leaf pack alignment bolt sheared off...
  6. Nov 6, 2019 at 11:49 AM
    Crgrey42
    Cory
    CNY
    yeah, there was no play in the axle when installing the springs. Additionally, the shackles seem to be at the same angle when looking from ride height.
  7. Nov 6, 2019 at 11:49 AM
    gotoman1969
    Make sure the leaf spring pin is in the axle pad hole. I’ve seen guys miss it and tighten down the u bolts and the axle not be seated in the hole. Then I’d loosen all the bolts for the springs and retighten and torque with weight on them. 1” is a lot.
  8. Nov 6, 2019 at 11:49 AM
    gotoman1969
    Oh yeah, that can happen too
    12TRDTacoma and Hobbs[QUOTED] like this.
  9. Nov 6, 2019 at 11:50 AM
    Crgrey42
    Cory
    CNY
    I didn't think of that. Guess it's coming apart this weekend.
    12TRDTacoma likes this.
  10. Nov 6, 2019 at 11:50 AM
    gotoman1969
    Keep us posted, I’m curious to see the cause.
    TnShooter likes this.
  11. Nov 6, 2019 at 11:51 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Just start carefully taking measurements of everything on each side til you figure out where the difference is.
  12. Nov 6, 2019 at 11:56 AM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Isn't there a dimple on the axle that the leaf spring center pin sits in? That's where I'd start looking
    *edit* whoops, apparently I take too long to type as this was suggested many posts back..
  13. Nov 6, 2019 at 12:03 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Have you measured the rear axle in relation to the frame and not just the body? These trucks are notorious for the composite bed coming loose and it’s possible your bed has shifted and not the axle
    whatstcp likes this.
  14. Nov 6, 2019 at 12:05 PM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    Make sure the leafs are in correctly. The front side is longer then the back on my leaf pack about an inch. Could be flipped 180 degrees
  15. Nov 6, 2019 at 12:28 PM
    Eselhengst
    Eselhengst Well-Known Member
    South of Abbotsford
    2011 Access cab TRD Offroad
    Sway-A-Way 2.0 coilovers and rear shocks Wheelers 8 leaf springs and superbumps ARB front bumper Trail Gear sliders RCI aluminum skids URD Spec-U exhaust etc.
    I second checking if the bed has shifted. Even if the bolts aren’t loose, the bed itself can wear around the bolts and move around. Especially if you are hauling a bunch of weight around
  16. Nov 6, 2019 at 12:57 PM
    Muddinfun
    Muddinfun Well-Known Member
    That was my thought when I read the OP.
    Jason TRD OR[QUOTED] likes this.
  17. Nov 6, 2019 at 1:03 PM
    Crgrey42
    Cory
    CNY
    I don't recall, but is there a possibility of them being flipped and still being able to bolt in the E brake cable? I know I bolted both sides in. I will crawl under tonight to verify though.
  18. Nov 6, 2019 at 1:09 PM
    pnw.river.junkie
    pnw.river.junkie Well-Known Member
    PNW
  19. Nov 6, 2019 at 1:18 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
  20. Nov 6, 2019 at 1:21 PM
    Crgrey42
    Cory
    CNY
    Exactly what I was looking for, thanks! I don't remember the install as I had to do 3 sets that day on friends trucks, So I will take it apart and check.
