Rear brakes changeout?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jepaton, May 2, 2013.
  1. May 2, 2013 at 2:12 PM
    Jepaton
    Jepaton [OP] Well-Known Member
    Josh
    NC
    10 TRD Sport SR5
    K&N CAI, Magnaflow true dual exhaust, Air Raid Throttle body spacer, TRD Supercharger, Wet Okole seat covers, and great audio
    Has anyone heard or done changed their rear brakes with the Four Runner rear braking system on a 2nd Gen Tacoma
  2. May 2, 2013 at 4:04 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    They are pretty much the same as any other Toyota rear drum setup. I see you have a 2011, I wouldn't think you need new rear brakes so soon. Are you having an issue?
    Never mind I misread your post.
    You want to install a Four Runner Rear Brake System on the Tacoma? Why?
  3. May 2, 2013 at 4:08 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    I thought the 4 runners has disk all the way around? Either may i would not put disk in the rear. truck stops very very well, even on wet roads. also has best stopping distance in it’s class.
  4. May 2, 2013 at 4:30 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It would also involve proportioning issues between front and rear brakes.
  5. May 2, 2013 at 6:03 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
  6. May 2, 2013 at 7:35 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    ABS might be plug and play, but the pressure supplied between the rear for disk brakes over what is needed for drum brakes would be a big difference. His post also stated " Without VSC ".
  7. May 2, 2013 at 7:45 PM
    92dlxman
    Kevin
    Visalia, CA
    right but what im getting at is that vsc proportions 4 wheels, independently, to keep from sliding or rolling or whatever. so whatever proportioning valve is used under "normal" conditions can be over-ridden. I believe abs controls the 4wheels independently too, so no matter what, no lockup; even though the rear is more powerful than the valve expected. its over ridden.
    these are questions as much as they are statements. looking for feedback
