Rear Bumper Stumper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ianp05, Apr 1, 2015.
  1. Apr 1, 2015 at 11:24 AM
    Ianp05
    Ianp05 [OP] Well-Known Member
    IAN
    DETROIT
    2006 Double Cab 4x4 TRD Sport
    Okay - So i've been doing some research and I'm starting to get stumped. I've done a number on my rear bumper and I'm getting ready to replace it. I have stock suspension and need to keep the hitch, so I'm a little limited on what I can work with. I dont do much extreme off roading, but I am looking for protection from rear ending.
    Basically I'm trying to figure out the weight of the stock bumper to make my decision, but I dont know enough about what goes into this to decide. What I'd like to do is keep the stock bumper and add the Avid Off Road rear bumper guard. The bumper guard only weighs 35lbs, doesnt need any additional suspension work, and is cheaper. What I'm wondering is if the stock bumper + the AOR Guard = more weight than just replacing with a full steel bumper.
    Any advice would be nice. I dont know much about replacing bumpers, what would go into it, etc. etc. but I'm pretty handy with a good set of directions.
  2. Apr 1, 2015 at 11:35 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    If you are trying to save your bumper from damage in a rear end collision then all you will do is transfer the force to the frame, and your physical body, and buckle the frame and end up with serious injuries. Remember it is called a bumper. It is good for a bump not a collision. The stronger the bumper the more the frame and your physical body has to absorb. Remember if the bumper is stronger than the frame it is attached to the frame is what goes and you are in a worst place than you started with.
    As for weight contact the people selling the parts and get the weight of each then you will be sure. However if you are talking parking lot type bumps try this.
    http://www.superbumper.com/
    https://www.youtube.com/watch?v=teqBBnat_Yk
  3. Apr 1, 2015 at 11:45 AM
    Ianp05
    IAN
    DETROIT
    Right, I've got the weight of the specific parts I would replace with, what i'm looking for is the weight of the stock bumper. Honestly the biggest problem with my bumper is that its bent out and acting like a massive air scoop like a flap on an airplane wing. Got caught on a tree stump while being winched. Essentially I'm looking for a bumper I'm only going to need to replace once.
    Thanks for the tip on the superbumper. Those things are pretty cool. Also the thought about the frame.
  4. Apr 1, 2015 at 3:36 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    13 DC TRD OR MG
        CBI Moab 2.0 front bumper CBI Trail Rider 2.0 rear bumper B.A.M.F. sliders Exhaust crossover relocate Icon 2.5 front and 2.0 rear Camburg balljoint UCAs Welded stock alignment tabs Dakar Leaf Springs and 14" x 650 lb. coils Wheeler's SuperBumps (front) Icon Hydro Bumps with U-bolt flip Relentless Fab tailgate plate Total Chaos Bed Stiffeners 265/75R16 BFG T/A KO2 on black TRD faux beadlocks PTR18-35090 Custom Double Cardan Driveshaft from South Bay Driveline 2.5" dia .134" wall front, 3.0" dia .125" wall rear. Spicer 1310 joints, Spicer CB
