Rear Bumpers
Discussion in '1st Gen. Tacomas (1995-2004)' started by xcmiler707, Sep 23, 2010.
  1. Sep 23, 2010 at 7:46 PM
    xcmiler707
    xcmiler707 [OP] Member
    Nor Cal
    04 Limited V6
    debadged, deflapped, flowmaster 40 series, tinted windows, tinted tails, clear corners, black grill surround, deck plate mod, white led's in the dash, black stock rims, pioneer deck
    I'm interested in getting a new rear bumper to replace the OEM chrome bumper I've got now. I was looking at some of the rolled ones but dont know if I would like it or not. I think I want to go more offroad looking. I'm not a hardcore offroader but I do take my truck up to Lake Tahoe to the snow. Any help would be greatly appreciated.
  2. Sep 23, 2010 at 9:09 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    If I was going with a roll bar type bumper, I think I'd go with the 4x Innovations one with the hitch built in. http://4xinnovations.com/p-RB37H.html
    It looks like one of the only ones that the hitch is mounted in properly to actually be able to serve as a hitch. Also, the hitch is built into the bumper, not underneath like most bumpers of that type like to do, allowing you to keep your bumper clearance and not get hooked up on the hitch. It also has the side protection, which is always good.
    If I didn't care about the hitch, just about any other brand would be good, as they all look quite similar. There's really only so many ways you can bend some pipes and add in mounting brackets and recovery points.
    Now, if you want plate style rear bumper, thats a completely different story. They'll be heavier and cost more, but can look quite a bit better and they dont all look the same. It all just depends what you're looking for.
  3. Sep 23, 2010 at 9:38 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
