Rear combination light taking on water
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drcaleb, Apr 10, 2011.
  1. Apr 10, 2011 at 3:56 PM
    drcaleb
    drcaleb [OP] member
    Vermont
    06 Access 4x4 base model
    intermittent wipers, 400w inverter, heated mirrors, illuminated 4wd switch, auxillary reverse lights, oba
    I searched all over but couldn't find anything about this. my driver's side light started taking on water during the last major storm. enough to almost cover the reverse light. i know how to take the assembly off the truck, but does anyone know how to remove the clear lens from the housing so i can dry it out and replace what i'm assuming is a bad gasket? i tried putting a flathead in between the two pieces, but only managed to slightly crack the lens.
  2. Apr 10, 2011 at 6:57 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    It's sealed with glue. I would drill a hole, drain, add silica gel, reseal the entire lens.
  3. Apr 10, 2011 at 11:12 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I'd try similar to the BHLM and bake it ever so slightly.
  4. Apr 11, 2011 at 4:37 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    from seeing details of people doing the black tail light mod, the rear lights cant be baked and seperated. they were seperated via dremel.
