Rear diff breather mod, should I have already?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dustinJ, Dec 9, 2014.
  1. Dec 9, 2014 at 7:18 PM
    dustinJ
    dustinJ [OP] Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5.
    Bilstein 5100 at 2.5 inch OME dakars with the big overload removed 265/75/16 on stock wheels 290,000 miles and counting
    Ok, so I have 90,000 on my '12 dcsb. I use it for a work truck in the oil filed, lots of mud and some pretty deep mud holes sometimes. There is definately mud all over the diff. I'm getting a feeling I should check the oil and change then do the mod. It's not a matter of cost its shutting down long enough to do it.
    Thoughts
  2. Dec 9, 2014 at 7:27 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Change the diff fluid and look and see if water is in the old fluid.
    If so then you NEED to do the mod. If no water is in the fluid then you might think about it as a preventive measure.
    BTW, the diff fluid should be changed every 30,000 miles.
    You can't hurt anything by doing it.
  3. Dec 9, 2014 at 7:28 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    The was a thread on here that sent you right to the complete kit for 25.00 don't remember where though
  4. Dec 9, 2014 at 7:30 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  5. Dec 9, 2014 at 7:37 PM
    taco06
    taco06 Well-Known Member
    Alex
    pomona ,California
    06 sprt
    I can't let the wife know
    Do it
  6. Dec 9, 2014 at 7:41 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Just ordered one myself for my 2015.
  7. Dec 9, 2014 at 10:07 PM
    dustinJ
    Dustin
    Amarillo tx
    I'm gonna do it. I'll let you guys know if there's water in the fluid.
  8. Dec 10, 2014 at 6:04 AM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    I just completed this mod last night. Ordered the oem breather plugs from the dealer and bought 6ft of pressure hose and worm clamps from Lowe's. I routed my breather up the wheel well and into the bed side cubby.
  9. Dec 10, 2014 at 7:48 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
  10. Dec 10, 2014 at 7:52 AM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
  11. Dec 10, 2014 at 8:05 AM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    ^That would work as well. I bought a new one because mine was corroded.
  12. Dec 10, 2014 at 8:38 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Okaaaaaaaaaaaaaaaaaaaaay I was just posting a link I found.
  13. Dec 10, 2014 at 9:22 AM
    adrstout
    adrstout Well-Known Member
    Adam
    Indiana
    '12 4cyl SR5 4x4
    2.5" lift, 265/75r16 Cooper AT3, All Pro Front Skid, KBVoodoo bed rack, a bunch of other random stuff
    Good idea to do if you do any amount of driving in slop...plus, its so easy and cheap why not?!
  14. Dec 10, 2014 at 10:27 AM
    n.gardner
    n.gardner Spacer Hater
    Nick
    Hawaii
    '13 SR5 4x4
    OME 3" 887s + Dakars 1" 4 Crawler BL Pro-Comp Uniballs Nitrochargers + Super Bumps Diff Drop + Drive Shaft Drop
    the dealer its only like $12
  15. Dec 10, 2014 at 12:00 PM
    n.gardner
    Nick
    Hawaii
    '13 SR5 4x4
    Lol, yeah, shipping to Hawaii is almost always more than the order itself.
  16. Dec 10, 2014 at 12:31 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Well when is someone gonna post the link to order OEM parts instead of just talking about it?
  17. Dec 10, 2014 at 12:34 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    diff breather for dummies thread
  18. Dec 10, 2014 at 3:50 PM
    David K
    OMG... did you (and so many who also replied) ever read any of the posts on why the stock breather doesn't work!!!???
    1) It is not a breather, but a vent port for gasses. It doesn't let air back in the differential to break the vacuum created inside. The vacuum is what draws in water when you ford deep streams or pools.
    2) We use the true breather that Toyota puts on the front differential... and it is also mounted up high to keep water out, and let clean air in that breaks any vacuum.
  19. Dec 10, 2014 at 6:48 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  20. Dec 10, 2014 at 7:03 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Apparently someone liked it because it just got snagged as soon as it was posted
