Rear diff breather mod, should I have already?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dustinJ, Dec 9, 2014.
  1. Dec 10, 2014 at 7:07 PM
    nd1979
    nd1979 2nd Tacoma
    East Texas
    '15 DC TRD OR 4x4, Super White
    Yep thanks for the post, a nice birthday present for me as today is the day!
  2. Dec 10, 2014 at 7:08 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Your welcome and Happy Birthday
  3. Dec 10, 2014 at 7:11 PM
    darkfader
    darkfader Will this fit without rubbing?
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
  4. Dec 10, 2014 at 7:13 PM
    nd1979
    nd1979 2nd Tacoma
    East Texas
    Thank you.
  5. Dec 10, 2014 at 7:17 PM
    nd1979
    nd1979 2nd Tacoma
    East Texas
    Thanks darkfader, I will mod in the same location as I am waiting on an order for my Tuffy lockbox and do not want to put the tube there.
  6. Dec 10, 2014 at 7:19 PM
    darkfader
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    no prob! i had to go to lowes for the rubber coated clamps in that writeup. everything else was on hand at the autozone besides the factory breather and union.
  7. Dec 11, 2014 at 7:36 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    If it stuck open that would be good, then it would actually breathe. Of course if you go deeper than 18" water crossing is why a breather should be higher up.
    The factory thing is a spring loaded vent that purges excess pressure. However, a breather would let the pressure equalize, preventing a vacuum from being created which is how water is drawn into the differential.
    It happened to me when the truck was only 6 months old, the diff fluid was milky from water, and after that oil change I performed the mod. Never again a problem crossing muddy water!
  8. Dec 11, 2014 at 7:50 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Exactly...emphasis on it not being a breather from the factory, more of a suffocator. Regardless of water crossings or not, doing this will take pressure off the axle seals making them last longer. Putting the new breather that actually lets it breathe is primary and putting it up higher to keep water out of it is secondary because you will always build pressure on the seals driving far or fast enough to build up heat but you will not always be doing water crossings.
  9. Dec 11, 2014 at 9:41 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I suppose you could leave it open or screened but parts are cheap enough to just get the breather. When you have both in your hand you can tell the difference in the 2 by blowing/sucking (yes, I said it that way) on one at a time and see where the original is restrictive in one direction but the replacement breathes freely in both directions. Mine is terminated in the gas door area above the filler, some run theirs into the storage compartments or the cubby over the wheel well. None of these are technically sealed. Having it in a different sealed location would cause same issue as the original setup has. They are protected areas compared to it just being on top of the axle housing but not truly sealed. Not sure where you are going with the first comparison question in your last post........
  10. Dec 11, 2014 at 11:52 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The factory breather is a one way valve. It lets air out but not in.
    When a hot axle with heated air gets dunked, the air within the axle cools, contracting and creates negative pressure (a vacuum). Air can not be sucked in through the factory breather due to its one way nature. Thus the only way for air to come in is through the seals at the pinion or end of the axle shafts, and when dunked instead of sucking in air, it sucks in water.
    So even if you extended the line up tall, and used the factory breather tip, it would defeat the purpose. FYI water does not get in through the factory breather, like stated above it comes in through the seals due to negative pressure.
  11. Dec 11, 2014 at 12:02 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I am wondering if the same part numbers work on a 94 pickup. The 94 diff has a vent on it and not a high mounted tube with a breather.
  12. Dec 11, 2014 at 2:16 PM
    n.gardner
    n.gardner Spacer Hater
    Nick
    Hawaii
    '13 SR5 4x4
    OME 3" 887s + Dakars 1" 4 Crawler BL Pro-Comp Uniballs Nitrochargers + Super Bumps Diff Drop + Drive Shaft Drop
    this escalated quickly
  13. Dec 11, 2014 at 2:49 PM
    dustinJ
    dustinJ [OP] Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5.
    Bilstein 5100 at 2.5 inch OME dakars with the big overload removed 265/75/16 on stock wheels 290,000 miles and counting
    Yes it did, I changed the oil today and it looked pretty good for 90g. No water residue at all. I think I'll leave it until I'm really bored some day.
    Took a little less than 3 qts amsoil 75/90
  14. Dec 11, 2014 at 2:58 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Haha, now that you've said that it's destined to get fuggard!
  15. Dec 11, 2014 at 3:12 PM
    #35
    dustinJ
    Dustin
    Amarillo tx
    Ain't that the truth.
  16. Dec 12, 2014 at 7:26 AM
    #36
    David K
    [I see someone finally got through to you on this since I was last on this thread. My answer, just fyi:]
    *The factory rear breather is the problem, not where it is located.
    *It is not a breather, but a spring loaded vent.
    *The mod uses the same breather Toyota uses on the front differential (a real breather).
    *Being a real breather, it is located higher than any water crossing, at the end of a tube, just like the front one is.
  17. Dec 12, 2014 at 7:36 AM
    #37
    David K
    Have a great day, and stay out of deep water until the mod!
  18. Dec 12, 2014 at 8:01 AM
    #38
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    The OE rear diff breather cap is actually not spring loaded, at least mine on my 06' sport lsd rear was not. I was curious about it when doing my mod and I popped the cap off and it was simply a loose cap held on by the small pinches in the cap.
  19. Dec 12, 2014 at 2:32 PM
    #39
    David K
    Mine was... it stays closed unless pressure (inside the diff) pushed the valve open (held closed by a light tiny spring). The front and mod breather is a simple cap pinched to hold onto the adapter base... essentially just reducing the air flow way to minimize any junk getting in. Obviously a K&N or other brand breather filter would be awesome instead of the Toyota one.
  20. Dec 12, 2014 at 2:36 PM
    #40
    David K
    Yes, I need details too... that's what brought me here in a big way, looking for an explanation on how the traction controls work! The dealer knew little, the manual said little, but TWers were very helpful... but, I had to continue the research and wrote many versions for TWers on how it works. Now, if there's an A-TRAC question, I am expected by some here to show up in those threads! LOL
