Rear Diff fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBob2008, Feb 8, 2017.
  1. Feb 8, 2017 at 11:41 AM
    TacoBob2008
    TacoBob2008 [OP] Member
    Bob
    New Tecumseth, ON
    2008 V6 SR5 4x4 DBL Cab
    Trailer Brake system, Bilstein 5100 Rear Shocks, Tonneau cover, Toyota replaced rear leafs
    Hey,
    I have a 2008 4x4 V6 SR5 Tacoma and am planning on changing my rear diff oil in the next few days.
    Right now I purchased 3 quarts of 75-W90 Royal Purple Gear oil with limited slip additive.
    The owners manual recommends 80W-90, is the 75W-90 with additive a better oil to use, or should I return it for 80W-90 and add the additive between the first and second quart?
    Thanks for your help Bob.
  2. Feb 8, 2017 at 11:45 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    75w90 is fine, not better or worse than 80w90 and surely good enough, especially since you are using a premium brand. Tons of us here on TW have used 75w90 without issues. Besides, there is virtually no difference in viscosity between 75w90 and 80w90.
    Norton likes this.
  3. Feb 8, 2017 at 11:49 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    75W90 is fine, but you don't need the limited slip additive unless you have a TRD Sport. BTW, welcome to TW!
    Marc70 and Norton like this.
  4. Feb 8, 2017 at 11:55 AM
    TacoBob2008
    Bob
    New Tecumseth, ON
    Ok cool thanks for the quick replies!
  5. Feb 8, 2017 at 11:58 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I run 75W90 Redline GL-5 gear oil (which has limited slip additive) in my truck's transfer case and both axles and 75W90 MT90 GL-4 in my transmission.
  6. Feb 8, 2017 at 12:48 PM
    TacoBob2008
    Bob
    New Tecumseth, ON
    Would using the oil with the limited slip additive cause problems if I don't need it?
  7. Feb 8, 2017 at 12:55 PM
    dkoester89
    dkoester89 Active Member
    David
    Menifee, CA
    Flow master exhaust, tint, Goodyear duratracs, atc camper shell
    How often do you usually change the diff fluid?
  8. Feb 8, 2017 at 12:59 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I'm only aware of two problems with having friction modifiers in gear oil when you don't need it. One is it's usually not compatible with manual transmissions and generally speaking will break down faster than gear lube without it.
  9. Feb 8, 2017 at 1:09 PM
    TacoBob2008
    Bob
    New Tecumseth, ON
    Ok, I will go grab some without it.
    I try to change it every 30 000 km but have gone a bit longer this time around.
  10. Feb 9, 2017 at 11:59 AM
    DGXR
    Friend
    Sacramento, CA
    I change mine every 60,000 miles with synthetic 75w90, but also my truck has a pretty easy life, nothing too severe.
    If I were towing or hauling regularly, I would do 40,000 mile differential service. Mine is an open differential.
    dkoester89[QUOTED] likes this.
  11. Feb 9, 2017 at 12:01 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Lucas 85w140 here. This is recommended by ECGS
    TrdSurgie likes this.
  12. Feb 9, 2017 at 12:03 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Lucas 75w90 here. No problems thus far.
  13. Feb 9, 2017 at 12:05 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    When talking to 4wd parts about what weight to use, they said 85w/140 is what they use to break in the gears and afterwards its okay to use the thinner 75w/90. I wonder if ECGS is thinking along the same lines. ECGS warranties their stuff so of course they are gonna want the heavier stuff in as it offers more protection.
  14. Feb 9, 2017 at 12:10 PM
    DGXR
    Friend
    Sacramento, CA
    This is a perfect example: heavier weight oil does not necessarily mean more protection from wear. Often, thinner oils can provide superior film strength over heavier oils, it all depends on the performance of the oil, high load testing results, etc.
  15. Feb 9, 2017 at 12:14 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Shits like molasses.
  16. Feb 9, 2017 at 1:19 PM
    TacoBob2008
    Bob
    New Tecumseth, ON
    Ok so I returned the Royal Purple And picked up so motomaster 80W-90 GL 5 gear oil.
    I'm a believer that you get what you pay for most of the time and this oil is only $7 a quart.
    So unless I can find 80W-90 synthetic gear oil I'm probably going to get 75W-90 synthetic GL5 and use that.
  17. Feb 11, 2017 at 11:06 AM
    j.claw
    j.claw Active Member
    Baltimore, MD
    07 RC 4x4 5sp
    Question regarding the LS additive and our differentials - are the only two diff options: open with locker, or a limited slip diff? Were there any 4x4 models produced with an open rear diff?
    EDIT: or going off this thread, post 9, are the base 4x4 open? https://www.tacomaworld.com/threads/toyota-limited-slip-differential.79912/
    END EDIT
    I have a 2007 base regular cab 4x4 MT and want to get the right stuff. Owner's manual of limited use as it applies to all models.
  18. Feb 11, 2017 at 3:00 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    A 2007 base 4x4 would have an open diff. 2005 to 2008 TRD Sports have limited slip, TRD Off Roads had an electric locker.
  19. Feb 11, 2017 at 3:06 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Same
  20. Feb 11, 2017 at 3:17 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    Redline 75/85 GL5 rec'd by EBAY
    jkuniverse likes this.
