Toyota Limited Slip Differential
Discussion in 'Technical Chat' started by BRP27, Mar 9, 2010.
  1. Mar 9, 2010 at 11:26 AM
    BRP27
    BRP27 [OP] When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    I have been looking at ARB lockers, and Lunch Boxes( Power Trax) TRD electric locker and they all have disadvantages. ARB lockers are excellent except for the amount of money they cost and installation, Lunch Boxes are not as good in snow or ice. TRD rear is a full rear assembly replacement $$$ and I have not seen a write up on a sucessful TRD rear end replacement wiring it up success... ect
    I ran across this Limited Slip made for toyota tacomas and it looks like a alternative I had not seen discussed on this site. I know limited slips are not great for off road, but it would be better than an OD. The intallation looks like it will be almost as involved as a ARB ( rear has to be set up by a person who knows rear ends setup) and a Limited Slip is not as good as a manual locker.
    My truck is a 04 Tacoma SR5 4 X 4 with open differentials. I am leaning towards an ARB but before I lay out a couple of grand for parts and labor I want to look at all options.
    Here is the link to the site that sells the TRD Limited Slip "drivetrain.com"
    http://www.drivetrain.com/parts_catalog/positraction/toyota_trd_limited_slip.html
  2. Mar 9, 2010 at 11:29 AM
    Brunes
    Brunes abides.
    Rotorhead
    What are you trying to accomplish by swapping out rear ends?? A trail capable daily driver or a hardcore off road rig??
    I would vote for a ARB...If you are going to have the work done back there....IT's worth it.
  3. Mar 9, 2010 at 11:31 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
  4. Mar 9, 2010 at 11:46 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    In terms of cost & installation.....and ARB & Limited Slip are virtually the same (major install).
    So....you need to decide - do you need offroad capability or onroad traction assistance?
    #1 The ARB is FULL LOCKER. It should primarily be used Offroad and more serious offroad situations (or you get stuck, or predict you will get stuck). The ARB is not intended to use on the roadways.
    #2 The Limited slip is a traction aide and can be used everyday on the roadways and is virtually 'invisible' because you don't engage or disengage it. It's working all the time.
    What's your flavor?
    Are you doing this primarily for offroad usage? Then get the ARB.
  5. Mar 9, 2010 at 11:46 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  6. Mar 9, 2010 at 12:38 PM
    BRP27
    04 4X4 Tacoma SR5
    trail capable daily driver, and I am leaning to ARB
  7. Mar 9, 2010 at 1:06 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Why do you care about snow/ice capability if you live in south Texas?
    I knew a few guys who had lunchbox lockers in their Broncos. They liked them but they do make noise on the road. ARB is easily the best because it's selectable. It's also easily the most expensive. Most people that cough up a bunch of money for LSD usually regret it later down the road and wish they had just gotten a locker.
  8. Mar 9, 2010 at 1:43 PM
    BRP27
    04 4X4 Tacoma SR5
    I like to play in the snow in Colo/New Mexico on ski trips.
  9. Mar 9, 2010 at 1:54 PM
    MikeyD
    MikeyD Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    hey guys i am in the same boat. This summer i want to re gear when i put on some 295/70/17s. I figured while my diff's are open i mine as well throw a locker in it. For the rear i know i want a arb locker. But for the front is a locker safe with ifs. Will i end up tearing my cv's or breaking an axel?
  10. Mar 9, 2010 at 3:32 PM
    Janster
    Jandy
    Lancaster, PA
    EXACTLY!!!
    ARB's are fine in the front diff - IF you know how to use it properly, gently, and responsibly.
    You gotta learn what NOT to do while the ARB is engaged in the front - like, you can't make tight turns. Don't force it to turn when you feel resistance - and many other things I'm probably not mentioning. Those are the biggest issue with lockers/CV joints.
  11. Mar 9, 2010 at 3:56 PM
    MikeyD
    Sayreville NJ
    Thanks for the info. Also since i have a 4cyl since i dont have as much power would that make it less likely that something would break or tear.
  12. Mar 9, 2010 at 4:00 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    I live right in the middle of it!:D he he he
    Sound advice to anyone running a locker on any type of axle. Especially front axles. Especially, especially on IFS.
  13. Mar 9, 2010 at 4:05 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Yes, all else equal, the engine providing less torque will decrease the risk of breakage.
    Buuutttt, smaller engines usually come with smaller (weaker) drivetrains. Essentially balancing out the risk of axle breakage caused by torque. Smaller axles increase the risk of trail caused breakage.
    I don't know if yours has weaker axles or not.:confused:
  14. Mar 9, 2010 at 4:34 PM
    MikeyD
    Sayreville NJ
    yeah i always wondered if the 4cyl have smaller axels then the 6cyl. Does any one know?
  15. Mar 9, 2010 at 5:24 PM
    Janster
    Jandy
    Lancaster, PA
    I'm gonna say No.
    For one thing - you're gonna regear, and that changes things. For another thing - you can't go around assuming just because you have a 4cylinder, that you're gonna be able to use it harder. Engine size doesn't matter when it comes to how the drivetrain acts. You can put yourself in a situation where you can sneeze on the gas pedal and break something regardless if its a 4cylinder or a 6cylinder.
    You have to learn how to use it and to start off with...BABY IT.
    As for drivetrain components being weaker.....that's irrelevant. Again - depending on the situation, you can snap things really easy regardless.
  16. Mar 10, 2010 at 6:44 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Same truck, just different powerplant.
  17. Mar 10, 2010 at 6:51 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    If you have 5-lug wheels it is most definitely not the same drivetrain.
    I'm not certain, but outside of the obvious locked/unlocked/lsd/open, I think there may even be variation within the 6-lugs.
  18. Mar 10, 2010 at 7:02 AM
    SmoothFox
    SmoothFox Well-Known Member
    DFW TEXAS
    2010 TRD OFFROAD 4x4
    CBI Sliders,PIAA Lights, 5100's, 4 leaf pack.
    Buy a TRD off road and be done with it.
  19. Mar 10, 2010 at 7:56 AM
    Janster
    Jandy
    Lancaster, PA
    You can't install an ARB in a 5 lug tacoma because it doesn't have a front diff.
    5 Lug tacomas are only 2WD trucks.
  20. Apr 23, 2010 at 3:46 PM
    HusqyRider
    HusqyRider Well-Known Member
    Adam
    La Mirada, CA
    01 Tacoma Prerunner SR5
    Bilsteins, HD Bakflip G2, Popnlock
    I just got off the phone with the guys at Drivetrain.com and they said the TRD LSD has been discontinued, that the eaton true-trac is a stronger unit, and that if you bought the TRD LSD, you may not be able to find parts for it in coming years (when clutch plates start wearing, etc...
