Rear Diff Lock Anytime Mod 3rd Gen DEVELOPMENT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigWhiteTRD, Mar 8, 2018.
  1. Aug 22, 2023 at 7:11 PM
    #441
    tacomadome
    tacomadome Well-Known Member
    Yeah I think people are missing the point here, engaging the rear locker in 2Hi is for doing sweet drifts on gravel not any sort of practical advanced technical maneuvering.
    gudujarlson likes this.
  2. Aug 22, 2023 at 8:34 PM
    #442
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Well shit! There goes an another $300 and an hour. Another option I do(n’t) need.
  3. Aug 25, 2023 at 7:12 PM
    #443
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    i ordered that plug and play kit if somebody wants to buy the stuff i bought to do this myself. oem fit switch, resistors, and diodes. im keeping the relay/fuse box for myself if i add other accessories later.
  4. Aug 25, 2023 at 11:58 PM
    #444
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    I want it so offramps and on ramps arent boring, and of course on forest roads. I've had spools my whole life, and its completely unnoticeable on the highway. I dont want some computer thinking it knows what it needs lol
    gudujarlson[QUOTED] and kona61 like this.
  5. Aug 26, 2023 at 7:02 AM
    #445
    bizarrocolin
    bizarrocolin Well-Known Member
    Colin
    SoCal
    Blue 2016 TRD OR 4x4 DCLB
  6. Aug 26, 2023 at 7:33 AM
    #446
    devinzz1
    devin
    2023 aclb trd or mt
    bizarrocolin[QUOTED] likes this.
  7. Aug 26, 2023 at 7:35 AM
    #447
    bizarrocolin
    Colin
    SoCal
    I sent them a message too.
  8. Aug 26, 2023 at 7:37 AM
    #448
    devinzz1
    devin
    2023 aclb trd or mt
    he replied and said its not compatible but he is working on a add on his own 2lo mod that adds to this one that is compatible
  9. Aug 26, 2023 at 7:38 AM
    #449
    bizarrocolin
    Colin
    SoCal
    Thanks for the info.
  10. Aug 26, 2023 at 11:32 AM
    #450
    RushT
    North Texas
    Well that’s a bummer, saved me some dollars though. It would be nice if he could have two options, one to support existing 2lo, and one that has it as an option.
    $300 for the anytime, and probably at least another $100 for the 2lo add on… starting to talk about some real change now.
    Toy_Runner likes this.
  11. Aug 26, 2023 at 11:41 AM
    #451
    ExperiMentaltaco
    ExperiMentaltaco Active Member
    Josh
    2023 Tacoma TRD Off-Road
    I tested this product and can tell you there are many benefits to having the ability to lock your diff in 2WD or even 4WD high. So it’s not only for sweet drifts although that part is fun. All our testing was done on stock suspension, tire, and tire pressure. I barely ever needed 4wd if the diff was locked in 2WD, only when i was going up very gravely steep inclines here out in the west coast desert. I did not need 4WD and i still didn’t have to go into LOW gear.
    This is also made for people who don’t want to hack up their harnesses or people who aren’t necessarily good with that type of install. This is very easy to install.
    Thatv8.naks, LOLLY and Spadi_5 like this.
  12. Aug 26, 2023 at 11:45 AM
    #452
    ExperiMentaltaco
    Josh
    No sir, it will not be. It will only be around $20-30 for the add on. And right now the AnyTime Locker with shipping cost is $259.94
  13. Aug 26, 2023 at 1:11 PM
    #453
    ExperiMentaltaco
    Josh
    I guess i should say that i haven’t tested it with the 2Lo mod as i don’t have that mod so it is possible that it works with it.
    If the guy that sells the 2Lo mod wants to work together and see if they work together i will gladly work with him.
  14. Aug 26, 2023 at 2:01 PM
    #454
    RushT
    North Texas
    Well, I’m probably in at that price. Might get a few bucks outa my current setup.
  15. Aug 26, 2023 at 2:52 PM
    #455
    ExperiMentaltaco
    Josh
    I did reach out to the guy that makes the 2Lo mod to see if we can work together and make these work together, so we will see if he wants to or not.
  16. Aug 26, 2023 at 2:57 PM
    #456
    BigWhiteTRD
    BigWhiteTRD [OP] Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    If you shot me (and/or @lapoltba ) a schematic, we can probably determine if it is likely/unlikely to interfere, and which should likely need to be installed into the ECU first.
    (I developed the DIY 2low mod, and @lapoltba developed a commercialized version)
    Before actually testing it of course. Likewise if you looked at the schematic of the 2lo mod (see my signature, you should be able to make some similar educated guesses.
    Note, I think it VERY likely that there will be no interference either way...
  17. Aug 26, 2023 at 3:01 PM
    #457
    ExperiMentaltaco
    Josh
    I sent an email through the website i don’t know if that is the you or the other guy.
  18. Aug 26, 2023 at 3:04 PM
    #458
    BigWhiteTRD
    Ted
    That's @lapoltba
    If you want any input from me, shoot me a dm and I will give you my email (if you want)
  19. Aug 26, 2023 at 5:01 PM
    #459
    ExperiMentaltaco
    Josh
    Okay after looking at the diagrams and the 2Lo harness it looks like we do not use the same pins besides 4 and 10 power and ground. So in theory they should work together. We would see a little voltage drop but not very much.
  20. Aug 26, 2023 at 6:23 PM
    #460
    BigWhiteTRD
    Ted
    Sounds good.
    Just thinking logically about what pins your system is interfacing, I dont think it should matter if it is installed before or after 2lo (most likely without seeing schematics).
