Rear diff lock button missing???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Acermcgraw, Mar 18, 2013.
  1. Mar 18, 2013 at 3:35 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    One of my favorite movies...
    "What is Posi-Traction?" LOL
  2. Mar 18, 2013 at 3:51 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    :rofl:
  3. Mar 18, 2013 at 6:55 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    despite neither tire having contact, wouldn't power go to just one wheel w/ an open diff? and both when locked?
    haha
  4. Mar 19, 2013 at 9:57 AM
    David K
    When locked BOTH tires rotate the same... 'locked' together.
    The 'open differential' is NOT 'open' when it is 'locked'.
  5. Mar 19, 2013 at 3:22 PM
    TIPICOTACO
    Tyler
    nw nj
    ONLY if the OP has the locker on, if its not locked then only one will spin (passenger side iirc)
    I know how it works.. was just trying to help the OP determine whether his truck is stuck 'locked' or not..
  6. Mar 19, 2013 at 3:46 PM
    Taylor
    Taylor Wants to learn all about his Taco.
    Taylor
    Sterling, Virginia
    03 4x4 TRD SR5 College build
    Extra badges, painted skidplates, grey wire mod, Kenwood double-DIN headunit, pioneer amp, 12 inch MTX sub, playstation 2 under seat, Uniden CB with 5 foot Wilson 1000 antenna, deckplate mod, 4xinnovations sliders, diff breather mod, bilstein 5100s at all 4 corners, OME Dakar Leaves, BAMF BPV bracket, Wheelers greasable shackles,
    Here guys. Jack it up. Put it in NEUTRAL. Turn one wheel with your hand. If the other wheel spins in the OPPOSITE DIRECTION, you have an open diff.
    If the other wheel spins with it, you're somehow connected.
    If you have an LSD I guess it would spin also, albeit at a slower rate.
  7. Mar 19, 2013 at 6:36 PM
    BradyT88
    BradyT88 ┌∩┐(◣_◢)┌∩┐
    Somewhere Offroad
    Mostly Stock '05
    Bingo!^^^ I had both my rear wheels in the air and put the engine in gear and gave it throttle and when the diff was open both wheels would spin forward unless I did something to affect one of them, like grab one or start to depress the e-brake. If both tires can spin with equal force they will. It is when one is harder to spin that they won't both spin together.
    If you were locked 24/7 you would know real quick. You get a lot of wheel hop and jerking around when turning in parking lots and such (ie sharply) impossible to not notice this.
  8. Mar 19, 2013 at 7:05 PM
    Taylor
    Taylor
    Sterling, Virginia
    Fuck yeah. :taco:
  9. Mar 20, 2013 at 2:00 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Woah, sleepy cody is a noob. haha
  10. Mar 20, 2013 at 2:04 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    You were right though Cody. haha. Unless the brakes are rubbing or a bearing is bad or something both wheels will turn.
  11. Mar 20, 2013 at 2:51 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    that's what I thought? idk, unless theres some innate thing about our trucks I didn't know........
    I havent really had my truck on a lift and stepped on a gas to put my theories to the test haha
  12. Mar 20, 2013 at 3:00 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    I have and it would spin both tires unless we interfered with one. I think there is a misconception that open diffs only apply power to one tire all the time. My friend had a nissan frontier that we smoked the rear tires off of. In 1st gear it would roast only the drivers side and in reverse it would only roast the passenger tire (may have been the other way around was several years ago). A lot of vehicles do this (why I don't know actually...) but it leads people to believe that that is always the case. But put the opposite tire in gravel and leave one on pavement and it will spin the gravel one every tire.
  13. Mar 20, 2013 at 7:09 PM
    Acermcgraw
    Acermcgraw [OP] Member
    00 prerunner sr5 stock
    Well guys i went out and jacked up the rear,i did not have the little motor shown and described here. So i feel confident that i do not have have a locking rear end i just have ahole in my dash where they would have put the switch. I do still have double wheel spin n the back im not sure if that means i have lsd or not though as there is nothing on the rear end saying that i can only use lsd fluid.
  14. Mar 20, 2013 at 7:43 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    Do 1st gens even has LSD from the factory?
  15. Mar 21, 2013 at 9:51 AM
    #35
    TIPICOTACO
    Tyler
    nw nj
    I did not know that..
    yep, guess I fell victim to this misconception too, thanks for clearing it up
  16. Mar 21, 2013 at 10:14 AM
    #36
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    even on an open diff... both wheels will leave skid marks on
    pavement or in dirt, as long as the traction is pretty close to
    equal for both wheels when you give it the boot, (and if you are not in
    a turn).... if one was on ice, then the ice wheel will spin up quickly and you'd barely
    start moving
  17. Mar 21, 2013 at 4:56 PM
    #37
    Taylor
    Taylor
    Sterling, Virginia
    Yes.
  18. Mar 21, 2013 at 4:59 PM
    #38
    Taylor
    Taylor
    Sterling, Virginia
    Well, even my Truck with an LSD will only really "spin" one tire. On pavement, I can spin one tire, while the other one spins regular speed.
    What's happening is that one tire is spinning crazy fast (Let's say my right one) until the LSD kicks in. That makes the other (left) tire kick in, due to the LSD. The left tire will be actually propelling the truck, while the one's that spinning and has less traction continues to spin.
  19. Mar 21, 2013 at 5:13 PM
    #39
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    Depends on how the mechanical LSD is setup. There are several different styles.
  20. Mar 30, 2013 at 6:59 PM
    #40
    Taylor
    Taylor
    Sterling, Virginia
    The different types are something I'm well versed in.
    Care to educate me?
