Rear diff lock not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by broken taco, Jul 21, 2011.
  1. Jul 21, 2011 at 12:50 AM
    broken taco
    broken taco [OP] Well-Known Member
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    Trail gear 3 Link Solid Axle Swap kit, 14 " Fox coil overs with reservoirs up front, Chevy 63 leaf spring swap with ruff stuffs Chevy 63 swap kit, 14 "Fox shocks on the rear, 37" tires, Custom front bumper by Next Venture Motor Sports with a warn winch, glassworks unlimited fender flares, custom rock rails with kickups (modeled after Relentless Fab Rock sliders), rear bumper from streetacos.com (with custom rap around protection for fiberglass fenders and the hitch receiver hidden behind the license plate that is on hinges), HID off road lights on front bumper, rigid pods on rear bumper with red back lighting, high lift mounted in the bed, onboard air, Flowmaster muffler, aftermarket air intake, alarm system, Alpine Deck, Alpine amp, Alpine speakers, JL W6 12" subwoofer, JL amp.
    My rear diff lock is not working. I have an 02 tacoma 2WD. i have pulled the switch out and tested the wires and they work fine and it is all conected. my emergency brake light is also sticking on when it is fully pushed in. could the rr diff lock not be coming on because it thinks the e brake is on?
  2. Jul 21, 2011 at 1:42 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    No don't think so. Turn the key to the "on" position without starting the truck (so electronics work) and push the diff lock button while standing outside the truck. If you hear something from the diff then the actuator is getting power and trying to work, thus your problem will be mechanical not electrical. If you hear no sound then it's most likely an electrical problem. Also if the problem is mechanical the RR diff lock will just stay flashing, while if the problem is electrical than the light may not go on at all.
    Mine was frozen and had dried salt on the inside of the actuator, so I took it apart and rebuilt/regreased the mechanism then sealed it back up with silicone on the outside.
  3. Jul 21, 2011 at 9:33 AM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    As for the parking brake. I had the same problem. When you release the parking brake, and push it in all the way, pull it back out a little bit and twist the handle up then push it back in. I am assuming you have the parking brake kind were you pull on it not push with your foot.
  4. Jul 21, 2011 at 9:36 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    When was the last time you had it locked ? & where in San Diego are you ??
  5. Jul 21, 2011 at 9:46 AM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    as for the e brake, the adjustment spring is under the drivers side next to frame. there are threads on her about adjusting the e brake.
  6. Jul 21, 2011 at 10:15 AM
    tacoma04
    tacoma04 Laissez les bons temps rouler
    Bruce
    Northern Louisiana
    2017 TRD OR DCSB BBP
    Also e brake, make sure you lube that pivot point under the drivers side next to the frame also. Mine was sticking and just needed a little lube and working fine. Lay under the truck at the driver's door and you will see where the cable from the handle comes into a bracket that pivots. Lube that pivot point. Then check adjustment.
  7. Jul 21, 2011 at 10:19 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    maybe its because you have a.....
    BROKEN TACO
  8. Jul 21, 2011 at 11:21 AM
    broken taco
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    i heard no noise so it is most likely electrical. and the light does not come on at all. and how long did it take you to take apart and rebuild the actuator.
    whoareyou133 likes this.
  9. Jul 21, 2011 at 11:26 AM
    broken taco
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    last time i used it was about 3 or 4 months ago. and i live in san carlos close to la mesa
  10. Jul 21, 2011 at 11:34 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Well you live here in a pretty dry climate so I'd prolly rule out corrosion (unless you submerge your diff.) You could get a meter & see if your getting voltage to the actuator.. I know with 4x, sometimes you have to play with it a bit, but you say nothing is lighting up like ABS ,etc;
  11. Jul 21, 2011 at 4:55 PM
    RattleTractor
    Harry
    VT
    '04 Unicorn Tacoma
    An hour maybe?
    Since Toyota calls this a "non-serviceable" part, there is no instruction section in any manuals (at least I haven't found any).
  12. Jul 24, 2011 at 3:44 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Ok so I'm having basically the same problem except mine must be mechanical because i can hear the actuator trying to work... but the light keeps flashing and my abs light does not come on. What kinda mechanical problem is this? something that can be fixed easily or a PITA? I've never had mine actuated i bought the truck like 3 months ago and like an idiot didn't check it until today. Help. :(
  13. Jul 24, 2011 at 7:27 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
  14. Jul 24, 2011 at 7:32 PM
    JayARRGHH
    JayARRGHH Well-Known Member
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    285/75/R16 Eldarado MTZ, Alpine CDE-102 Deck, DIY Snorkel, 2" Spacer Lift, Uniden Bearcat 880 CB, Custom over head console w/ map lights, CB Mount, and external CB speaker, 2 12" Kenwood Subwoofers, 300 Watt Alpine Amp, Alpine 3" lift 500# capacity
    Well this is pretty dumb to say but just to eliminate it, you have it in 4lo right? unless you have the grey wire mod.
  15. Jul 24, 2011 at 8:20 PM
    RattleTractor
    Harry
    VT
    '04 Unicorn Tacoma
    I have already posted the link for the actuator rebuild in this thread. Just follow that. My truck did exactly what you are describing and that's how i fixed the locker.
  16. Jul 24, 2011 at 10:34 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    He's a prerunner,
    if you are sure your hearing the solenoid working, then you'll have to play with it, slow , deliberate left/righthand turns till your gears line up, this can take a while sometimes
  17. Aug 11, 2011 at 9:59 PM
    broken taco
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    i figured it out. I feel really dumb for this but i put in an add-a-fuse and i saw a fuse for 4WD and i thought o.... well i dont have 4WD so i don't need to put that fuse in the back of the add-a-fuse to connect that circuit. but apparently the 4WD fuse is for your rear diff lock. and the fluid for my e brake was low. :p
  18. Aug 11, 2011 at 10:05 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    dont feel dumb... you figured it out on your own instead of taking it to a shop right away...
    :thumbsup:
  19. Aug 11, 2011 at 10:06 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    what.
    and I was just about to say check your fuses, I hate them.
  20. Jun 12, 2020 at 11:45 PM
    whoareyou133
    whoareyou133 Well-Known Member
    Claremont Los Angeles
    02 Prerunner TRD
    No pre runner trim, no mud flaps,no step ups,I do have the Deck plate though. Kings @ 0 and 5100's in rear. stock leafs. Total chaos UCA.
    This is hitting deep rn..
