Rear Diff oil brand/type? Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bordinco90, Nov 11, 2019.
  1. Nov 11, 2019 at 8:00 AM
    bordinco90
    bordinco90 [OP] Well-Known Member
    SW Louisiana
    2008 Desert Sand Mica Tacoma Prerunner DCSB
    18 inch Black rims with 265/65/18 AT tires. Bilstein 5100 shocks. Black Halo Headlights and Black LED taillights. Window Tint. Black Aftermarket Grille.
    Hey guys I have never change my Rear Diff oil on my 2008 tacoma v6 prerunner base 2wd. I was wondering what weight and brand of rear diff oil is the best? Also I looked in my owners manual and it says SAE 90 for the rear diff fluid. I tried looking and am not sure what oil to buy. Also I'm not sure if my tacoma has limited slip. I looked on the rear diff and did not see anything. Can anybody help?
  2. Nov 11, 2019 at 10:04 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  3. Nov 11, 2019 at 10:06 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Stock gears use what they say 75/90 thats what most will recommend and dealer. Lucas is solid. A bunch of people use Mobil1. You will need an additive if you have limited slip but I believe that is only the sport model. Someone will respond but the manual should tell you.
  4. Nov 11, 2019 at 10:16 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Jack up rear and spin one tire by hand. If the other tire rotation is opposite you have an open diff and require no additive.
    Go to Walmart and by the cheapest dinosaur oil close to 90 weight (more won’t hurt) and change it every 30k miles. No benefits from synthetic oils whatsoever unless you like pissing away money. Cue the Amsoil crowd. Lol!
  5. Nov 11, 2019 at 10:17 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    You will need 75wt/90. If that isn't available you can use 80wt/90. Your truck does not have a lsd so you will not need the additives for one.
    I am a cheap bastard and run supertech (Walmart) oil in my rear diff. The front and transfer case gets redline as they dont call for a change as often. Truck has been happy with this for 40,000 miles and counting.
    BillsSR5 likes this.
  6. Nov 11, 2019 at 10:21 AM
    eon_blue
    Azusa, CA
    Only the 05 - 07 Sports since they had a true mechanical limited slip, the 08+ Sports have a pretend one
    Any brand gear oil is fine but I would stay away from synthetic gear oil for the diffs...East Coast Gear Supply recommends not putting synth in them anyway. Something about it not withstanding heat as well as regular if I recall. It's on their website
    Dirtridercrf250 likes this.
  7. Nov 11, 2019 at 10:21 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    This was for my 19 OR:
    ECGS memo can be found over here. When in doubt, go with what the manual calls out. Your truck model number can be found on the door sticker. :notsure: GL!
    captrussia253 likes this.
  8. Nov 11, 2019 at 10:33 AM
    TireFire
    Olympic Peninsula
    I run 85/140 also. Only reason they put the thinner stuff in factory is probably fuel economy
  9. Nov 11, 2019 at 11:02 AM
    bordinco90
    SW Louisiana
    Thanks. I think I need to buy 4 quarts of the stuff. Also what about the washers? I seen an thread on here and someone mentioned the metal washers are on Amazon. Can someone link them please? Does the metal washers need to be replaced on both plugs? Thanks again guys. Also I've owned the truck since new and have never changed the rear diff oil. The truck currently has about 160k.
  10. Nov 11, 2019 at 11:12 AM
    bordinco90
    SW Louisiana
    What are some non-synthetic gears oils to look at? It seems like everything sold online is synthetic.
  11. Nov 11, 2019 at 11:21 AM
    69L46Vert
    69L46Vert Well-Known Member
    Rick
    Maine
    2007 Regular Cab 4x4
    I used these for my 07 w/MT. More than enough for changing all the gear oil. Front diff, Transmission, T/case and rear diff. There were a few left over. Some are crush type. Others are flat/solid. I used Supertech 75/90 in everything but would use something different in the transmission if I did it again.
    https://www.amazon.com/gp/product/B07Q3R7TWG/ref=ppx_yo_dt_b_asin_title_o03_s01?ie=UTF8&psc=1
  12. Nov 11, 2019 at 11:29 AM
    RyanDCLB
    4/19 DCLBOR
  13. Nov 11, 2019 at 11:29 AM
    bordinco90
    SW Louisiana
    Cool thanks! I will definitely buy this! Now time to decide on the oil brand.
  14. Nov 11, 2019 at 11:31 AM
    eon_blue
    Azusa, CA
  15. Nov 11, 2019 at 11:32 AM
    bordinco90
    SW Louisiana
  16. Nov 11, 2019 at 11:33 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    I don’t think we need to do the ECGS debacle again.
    75/90 in whatever brand makes you feel good. Done. Don’t overthink this.
    bax and bordinco90[OP] like this.
  17. Nov 11, 2019 at 11:41 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    GL-5......75-90......
  18. Nov 11, 2019 at 11:44 AM
    69L46Vert
    Rick
    Maine
    The 85/140 is a heavier oil. Heavier than recommended but I wouldn't hesitate to use it if you think you need extra protection ie. severe service, heavy towing, or any uses that may shock the gears more than normal. May decrease your mileage but probably insignificanty.
  19. Nov 11, 2019 at 11:47 AM
    bordinco90
    SW Louisiana
    I've been looking at the mobil 1 but the ones that I have found are the: mobil delvac 1 and mobil 1 LS (I assume thats limited slip, which I'm not sure I'll need). Lucas is another brand I'm looking at.
  20. Nov 11, 2019 at 11:50 AM
    Accipiter13
    California
    '11 DCLB 4x4 Sport
    Is it Gf-5 75/90? Yes? great, it will work.
    The mobil1 “LS” will work fine in your truck. That is what I (and many, many others) use (I’ve used lucas, Valvoline, etc. in other vehicles as well.)
