Rear Diff oil brand/type? Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bordinco90, Nov 11, 2019.
  1. Nov 12, 2019 at 6:14 PM
    #41
    LVYOTA
    LVYOTA Well-Known Member
    2014 TRD Sport MT
    I recently called 2 local Toyota dealerships and they both use NAPA 80w-90. They buy it in bulk 5 gallon jugs. Thought I would use the same stuff Toyota uses in case I would ever have warranty issues. I changed both diffs @ 50k. The service manuals weren’t very specific on intervals.
  2. Nov 12, 2019 at 6:17 PM
    #42
    eon_blue
    Azusa, CA
    It really depends on how you use the truck. If you wheel a lot your diff is going to get a lot hotter than if you just commute around town every day and the oil won't last nearly as long (especially if youre submerging the diff in water without a breather extension). I change mine every 25k because I use it pretty hard but 50 -60k for normal everyday driving is fine
    bordinco90[OP] likes this.
  3. Nov 13, 2019 at 5:00 AM
    #43
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    75w90 or 80w90. I use supertech.
    It's gear oil, really can't f it up.
    op9nf and bordinco90[OP] like this.
  4. Nov 13, 2019 at 11:18 AM
    #44
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I hav
    I have been using this exact stuff for a long long time...it will be fine. My truck still runs like a top.
  5. Nov 13, 2019 at 1:25 PM
    #45
    bordinco90
    bordinco90 [OP] Well-Known Member
    SW Louisiana
    2008 Desert Sand Mica Tacoma Prerunner DCSB
    18 inch Black rims with 265/65/18 AT tires. Bilstein 5100 shocks. Black Halo Headlights and Black LED taillights. Window Tint. Black Aftermarket Grille.
    Good deal I'm glad to hear that. I also bought a set of metal washers for the rear diff and a pump.
    69L46Vert likes this.
  6. Nov 13, 2019 at 1:26 PM
    #46
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I use supertech 80w90 in my rear diff with lsd additive and supertech 75w90 in the t case and front
  7. Nov 27, 2019 at 8:29 PM
    #47
    bordinco90
    SW Louisiana
    Well I got it changed. Super easy and gives me peace of mind. Thanks for your help TW!!!!
    69L46Vert and eon_blue like this.
  8. Apr 27, 2020 at 11:04 AM
    #48
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    What is the ECGS debacle?
    I'm just about to order a 3rd and clamshell from ECGS and am wondering which oil would be best to use. Yes, I've asked ECGS and they said 85W-140 even though I'm far north and don't get too hot in the summer (85-90*F) and can get pretty cold in the winter (-4 to -22F) but I am wondering if it's overkill for my needs. I will have 4.56 gears and Harrop lockers front and rear. Is there that much of a difference between the 80W-90 and 85W-140?
