Rear diff Regear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ghost848, Nov 17, 2012.
  1. Nov 17, 2012 at 4:45 PM
    Ghost848
    Ghost848 [OP] Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Hey guys, So I started the front diff IFS thread for a reason, (http://www.tacomaworld.com/forum/2nd-gen-tacomas/248258-front-ifs-diff-locker.html)
    My rear diff started the dredded whine! I did diff fluids today and found this:
    :eek::(
    So Im starting to think regearing is in my near furture.
    Now the list, what all do I need to regear... what spline is my 09 TRD OR 8" elocker diff? do I need a new install kit to make my 3rd member more reliable?
    Please if you know, LMK cause I gots to start shopping now. I will be going to east coast gear supply so links to there store would help ALOT!
    If you cant tell Im new to the regearing side of things, so help would be great.
    all im after is the parts so I can just take everything to a shop and say fix it lol.
  2. Nov 17, 2012 at 4:51 PM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
  3. Nov 17, 2012 at 4:53 PM
    Ghost848
    Tony
    Alberta,Canada
    any idea on what need off that page... Im running 33" may go up to 35, but doubt it
  4. Nov 17, 2012 at 4:59 PM
    SurfInferno
    Dylan
    Littleton, CO
    2001 DC
    Even with 33s you may still be in the clear as far as regear. I have a 5 luck so i can't be positive. If you go 35s you would defiantly need to regear to 4.56. Theres really 4 ways you can do it. You can bring the truck to a shop and have them change the gears, or take the 3rd member off and bring it to them (will save a few hundred in labor), buy a whole new third and install it(easiest way but not the cheapest) or do it yourself, Im not good with gears and getting them to run perfect so i didn't attempt it, but you may be.
    Heres the gear set, I've heard good things about yukon but they are more expensive.
    http://eastcoastgearsupply.com/i-132564-yukon-toyota-v6-turbo-e-locker-8-ring-and-pinion.html
    along with that you will need a rebuild kit if I'm not mistaken
  5. Nov 17, 2012 at 5:01 PM
    SurfInferno
    Dylan
    Littleton, CO
    2001 DC
  6. Nov 17, 2012 at 5:10 PM
    Ghost848
    Tony
    Alberta,Canada
    OK im starting to make sence of all this, what spline whas the yukon gear?
  7. Nov 17, 2012 at 5:16 PM
    SurfInferno
    Dylan
    Littleton, CO
    2001 DC
    I believe its a 29 but I could be wrong, i would need a second opinion.
  8. Nov 17, 2012 at 5:18 PM
    Ghost848
    Tony
    Alberta,Canada
    so you bought a new pinion flang too then
  9. Nov 17, 2012 at 5:22 PM
    SurfInferno
    Dylan
    Littleton, CO
    2001 DC
    i just bought the whole 3rd member, took my stop one out, installed the new one, and sent them my old one. It was maybe 100-200 bucks more but i know it was done right.
  10. Nov 17, 2012 at 5:39 PM
    Ghost848
    Tony
    Alberta,Canada
    actually that seems like the smart way, I was just doing the math. and I would prob save close to 4-500 buck doing the whole asse.
  11. Nov 17, 2012 at 5:44 PM
    jandrews
    '09 FourDubDee TRD OR
    If you're going with ECGS just get a built diff and swap em.
  12. Nov 17, 2012 at 6:01 PM
    Ghost848
    Tony
    Alberta,Canada
    Hey jandrews, have you had to regear your 09 TRD OR yet? what was your cause of failure?
  13. Nov 17, 2012 at 6:11 PM
    jandrews
    Lol.
    The first failure was from wheeling. Replaced it with a boneyard diff. The second failure was from wheeling
    Replaced with nitro 4.56 diffs from ECGS. So far things have held up. If this third gearset shits I'm ripping the whole fucking elocker axle out and putting in a rockjock.
    The truck almost has 28000 miles!
  14. Nov 17, 2012 at 6:15 PM
    Ghost848
    Tony
    Alberta,Canada
    Lol yeah im thinking i should of went with the sport then put lockers in it, but I thought the locker would have been better quality than it is:rolleyes: there I go assuming again.... My bros Land cruiser is a monster, and makes the tacoma look like a tonka toy....his diffs are built to last but mind you his are 8 high pinion lol
  15. Nov 17, 2012 at 6:32 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    The thing that sucks with the TRD and elocker is there isnt a ARB locker made for the rear that I know of. Also for a complete list of what you may or may not need talk to Chase at ECGS he knows his shit...
  16. Nov 17, 2012 at 6:43 PM
    jandrews
    The carrier isn't the problem. The diff housing is weak and deflects under stress.
  17. Nov 17, 2012 at 6:44 PM
    Ghost848
    Tony
    Alberta,Canada
    Will do thanks man, planning on doing my front IFS too so.
  18. Nov 17, 2012 at 6:57 PM
    BradyT88
    BradyT88 Well-Known Member
    I think the ECGS assembled diffs are the way to go. Nobody can put together Toyota diffs as good as those guys, and it is a fairly simple driveway install to swap the assembled diffs. Took me and a friend a few hours to install front and rear.
  19. Nov 17, 2012 at 7:51 PM
    jandrews
    ZUK does an aweso me job but declines to clamshell diffs because its so time consuming. ECGS diffs are definitely the best deal on the market.
  20. Nov 17, 2012 at 7:59 PM
    Ghost848
    Tony
    Alberta,Canada
    How many miles you got on your nitro gears so far, do you wheel alot?
