Rear Diff service 30K ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fxlbalto, Jul 13, 2013.
  1. Jul 13, 2013 at 12:27 AM
    fxlbalto
    fxlbalto [OP] Member
    Hello everyone...... I have question & I know this has been brought up before. I have read the other post but still confused.
    I have a 2011 4x4, crew cab, Tacoma, bought it new. Time for 30k service. Owners manuel calls for "Toyota Genuine Differential Gear Oil LT 75w 85 GL-5". Does not say anything about an additive. According to my window sticker truck has "Limited Slip Differential". Emailed Mobil since I use only Mobil1 for motor oil, there reply was "we have nothing compatible". Contacted Toyota, they said to use the above noted Toyota Fluid. The I fing another Toyota fluid that makes more sense "Toyota Differential Gear Oil LX GW 75w-85" for LSD & transfer. I do all of my own work. My gut tells me to go with the Toyota stuff. But do I add an additive?
    P.S. I also have a 91, extended cab Toyota Pickup with 385K on it....lol
    Any help would be greatly appreciated.....
  2. Jul 13, 2013 at 2:02 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
  3. Jul 13, 2013 at 3:08 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Just use mobil 1 75-90 in it. Thats why they dont have anything compatible b/c they dont make 75-85. Most on here that run mobil 1 use 75-90. There is no Mechanical LSD's after 2009 if im not mistaken.
  4. Jul 13, 2013 at 3:37 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    fuck that shit
    80 90 or 75 90, long as it meets GL-5 specs
  5. Jul 13, 2013 at 3:57 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    No LSD, its not a true limited slip diff. It uses electronics and braking if I remember right. Either way, you don't need addative. You can use Toyota's brand or Mobile 1. Both will work fine. I think you will find at 30K, your diff fluid is going to look pretty new.
  6. Jul 13, 2013 at 8:51 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  7. Jul 13, 2013 at 7:58 PM
    fxlbalto
    Folks,
    I can't THANK YOU enough. I have been beating around with Toyota & Mobil. I too thought Mobil's reply was lame. You folks actually explained it to confirm my thoughts.
    I will probably go with the Mobil since I have been using the oil for years, but going to look at Amsoil.
    Thank you so Much......................
  8. Jul 14, 2013 at 8:45 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    There hasn't been a mechanical limited slip since the 2009 model year when 'AUTO LSD' and 'TRAC' were added to all Tacomas, keeping the mechanical differential 'open'.
    I had Jason (Speed Freek) change the fluids and he recommended changing my rear diff. to Mobil 1 75W-140, and front diff. and transfer case to Mobil 1 75W-90. It was at 40,000 miles... I posted about it. The rear oil had already been changed once, following contamination after a deep water crossing when the truck was just 6 months old. I have since performed the rear differential breather mod, so no more of that nonsense!
