Rear Diff Strength vs Tire Size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TakDwn, May 8, 2010.
  1. May 8, 2010 at 6:39 AM
    TakDwn
    TakDwn [OP] Well-Known Member
    PA
    2010 Tacoma DC V6 Shortbed 4x4
    Bili's all around, front 5100's at 1.75", rear TSB w/AAL, 265x75/16 BFG AT, Wheelers steelies Type B 4" bs, LEER cap, Tinted, Relentless hybrid sliders welded, Cab mount chop, Plastic trimming, Sock retros, Mirror lift, Satoshi with old school emblem, WeatherTechs, Mudlaps gone, RedLine hood struts, Fumoto valve, Tailgate clamped, Console organizer, Mobtown Offroad Front Recovery Bar
    Ok guys I hate to ask but after much searching I'm unable to find the answer.....
    What is the max tire size the rear end can handle? Not in relationship to wheel well clearance but the strength of the rear to handle a larger tire.
    What is the common breaking points when the rear goes - spider gears, ring and pinion, etc-- ??
    I realize there are other factors such as gear ration, having/not having locker, etc...but what is common with Tacomas'?
    Thanks.
  2. May 8, 2010 at 7:07 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
  3. May 8, 2010 at 9:51 AM
    TakDwn
    PA
  4. May 8, 2010 at 9:59 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    runnning 35s on stock gears/axle
  5. May 8, 2010 at 10:06 AM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    '20 Grey TRD Off-Road 6spd
    TC +2 LT, Kings, BAMF Armor, 35s, gears
    I blew my rear axle a month or two ago running 33's. It was the ring and pinion that went. I was doing a steep hill climb though.
  6. May 8, 2010 at 10:10 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Blew my ring and pinion on 32's... and I wasn't locked.
  7. May 8, 2010 at 11:46 AM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    if you busted the rear end with larger tires, please post what you were doing when it went out. Offroading, Commuting, 2h/4hi/4low, pushing the truck because you forgot to put gas in it!
    Would be great info!
  8. May 8, 2010 at 2:19 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    If you beat on it, it will break If you are easy on it, it will break. Its just a matter of time. If mine decides to go I will have my ring and pinion Cryo treated.
