Rear Diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aussie08, Mar 31, 2011.
  1. Mar 31, 2011 at 6:52 AM
    Aussie08
    Aussie08 [OP] Member
    Philly
    08 prerunner
    I have an 08 prerunner and was thinking about replacing the rear differential and putting an LSD or locker back there. I was wondering if anyone had any experiance with this type of project?
  2. Mar 31, 2011 at 6:53 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    What are you driving conditions going to be? lots of offroad?
  3. Mar 31, 2011 at 7:18 AM
    Aussie08
    Philly
    08 prerunner
    Not really, I live in Philly and I only have issues when we get snow.
  4. Mar 31, 2011 at 7:42 AM
    Dark Knight
    Jeff
    NC/SC
    Get a limited slip. Will be way cheaper than a locker + you dont want to be locked on the street when driving in snow, it will make your truck fishtail. A little slip is good.
    If I had the money to get my locker right now I would sell you my factory Limited slip. :(
  5. Mar 31, 2011 at 7:52 AM
    Aussie08
    Philly
    08 prerunner
    What do I need to look for in an LSD to ensure the correct fit? I had heard that if I check the VIN # it should tell me the type of diff I have but I can't match any numbers to the form I have.
  6. Mar 31, 2011 at 8:06 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Factory limited slip from 05-08 truck would fit your truck and they are the best thing for the snow.
  7. Mar 31, 2011 at 8:07 AM
    Dark Knight
    Jeff
    NC/SC
    Your PreRunner is a base prerunner right, not TRD? If yes, you have the 8.4" housing/R&P.
  8. Mar 31, 2011 at 8:27 AM
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    I like the factory LSd pretty well but I would like to go over to the gear style LSD to get away from clutches. I have never had any issues with the clutches at all and have had them in three different makes and models. I just like the idea of not having clutches to wear out, or having to deal with adding LSD friction modifier and such. I have not owned the gear style LSd yet but I have heard good things...
  9. Mar 31, 2011 at 8:58 AM
    Aussie08
    Philly
    08 prerunner
    It is a TRD sport. Is it still an 8.4" housing?
  10. Mar 31, 2011 at 9:01 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    05-08 TRD sports already have the mechanical LSD in it.
  11. Mar 31, 2011 at 9:36 AM
    Aussie08
    Philly
    08 prerunner
    If thats the case then my LSD sucks.
  12. Mar 31, 2011 at 9:38 AM
    blacktaco21
    blacktaco21 Crunchy Taco
    AR
    05 TRD Sport DC 6" 325/65R18
    Fabtech 6" Baja Tire Carrier Limo Tint 4.88 Gears Detroit Locker Rear ARB Locker up front Train Horns Pioneer DVD Double Din JL Audio 12w3v3 325/65R18 Baja MTZs 18x10 Classic Locks Powder Coated Flat Black
    Have a used Detroit Truetrac LSD for sale if you are interested. Probably has around 4k on it then I pulled it and swapped back to a full locker. I had no complaints with mine and it was as smooth as stock but a lot stronger!
  13. Mar 31, 2011 at 10:35 AM
    Sleeper362
    Sleeper362 One Convenient Locations ......In Africa
    Corporal
    K-Vegas NC
    06 SR5 4X4 DC Shortbed
    Why has no one tried an Eaton ECTED? Do they not make them for our trucks?
  14. Mar 31, 2011 at 10:42 AM
    BlueT
    NorthEast
    Which is probably easier to fix then invest money in new one.
    How many miles you have on current one and when did you replace gear oil? With what ? and What additive?
    Clutchpacks can be easily replaced if they wear out but considering that now I had seen two factory LSD's with mileage and offroad usage with pretty much no wear, most likely yours are caked with burned gear oil.
  15. Mar 31, 2011 at 10:46 AM
    Dark Knight
    Jeff
    NC/SC
    Mine was a complete turn around when I changed the Diff oil. It works too good on the snow.
  16. Mar 31, 2011 at 11:01 AM
    Sleeper362
    Corporal
    K-Vegas NC
    I need to find an LSD for my truck since it is an SR5 4x4. I don't do any serious off roading, so I don't need it to lock, Just something better than on open diff for the rear.
  17. Mar 31, 2011 at 11:03 AM
    BlueT
    NorthEast
    Almost brand new, what oil did you used on it ?
    BTW its open on my bench :)
    Waiting for Go no Go on plan B ;)
  18. Mar 31, 2011 at 11:27 AM
    Sleeper362
    Corporal
    K-Vegas NC
    What should I be looking for on the sticker, and where on the rear is it located? I just got the truck two weeks ago
  19. Mar 31, 2011 at 12:25 PM
    BlueT
    NorthEast
    x2 There should be white/red sticker on housing that says LSD oil only. You can also take vin number to Toyota and they will tell you if truck came with LSD.
    If you looking at junkyards you need to ask for diff with POSI non-locked.
  20. Mar 31, 2011 at 3:21 PM
    Sleeper362
    Corporal
    K-Vegas NC
    My differential cover has a sticker on it but sadly no LSD oil only sticker. :( Oh well I guess it is off to the aftermarket. What type of shops do you go to to get one installed? I always had my rear end work done by one person on my mustang. I know that someone can screw up a rear end pretty horribly if it is not set up right.
