Rear differential fluid recommendations?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Breaky0self, Feb 27, 2015.
  1. Feb 27, 2015 at 7:57 PM
    Breaky0self
    Breaky0self [OP] Well-Known Member
    Jupiter fl
    2011 Trd Sport metallic grey 2wd
    What's everyone like to use? I saw I was suppose to change it at 30k, unfortunately I didn't know and have approximately 44k, so any opinions/advice would be appreciated. Gonna change it tomorrow. I have a 2011 Trd sport 2wd.
  2. Feb 27, 2015 at 8:10 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
  3. Feb 27, 2015 at 8:19 PM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    I recently used Valvoline durablend synthetic blend gear oil. 80w-90 I believe. A 140 may or may not have ended up in the mix. Nothing has caught fire or exploded.
  4. Feb 27, 2015 at 8:19 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    75w90
  5. Feb 27, 2015 at 8:38 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    My only suggestion is dont go synthectic in your diffs liquid dino is the way to go
  6. Feb 27, 2015 at 8:45 PM
    Breaky0self
    Jupiter fl
    Thanks for the replies guys, do I need to add a LS Diff Additive on my Trd sport? Also where can I pick up some new fill/drain gaskets. And what are the reasons to use or not use synthetic?
  7. Feb 27, 2015 at 8:48 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Why not? Many of us have run synthetic them for years with no issue.
  8. Feb 27, 2015 at 9:11 PM
    Jas
    Jas Space still for sale. I do not accept checks.
    SoCal
    99 4runner Limited
    You don't have mechanical LSD, so you don't need an additive.
  9. Feb 27, 2015 at 9:18 PM
    Breaky0self
    Jupiter fl
    You guys are awesome, so what about the gaskets, where can I pick some new ones? Or should I just reuse the old ones?
  10. Feb 27, 2015 at 9:22 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    For the metal washers, dealer parts guy can look it up. They're cheap. Really though, should be ok to reuse what's on there already.
  11. Feb 27, 2015 at 9:42 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    won't be any issue but it's a waste of money
  12. Feb 27, 2015 at 10:01 PM
    Idaholandho
    I could easily agree with all synthetics. Although, I am guilty and will keep running it. I suspect it just makes me feel good.
    I was curious of why poster was adamant or seemingly against synthetic in the rear diff.
  13. Feb 27, 2015 at 10:25 PM
    PSU Taco85
    optional
    I run synthetic in the engine oil and I'm not sure if MT90 is synthetic or not but I run that in my transmission and t-case. It gives me that wharm feeling inside paying more for mobile 1 engine oil I guess haha. For the diff fluids I use lucas dino oil as recommended by ECGS where I bought the diffs.
    I wouldn't say I am against it but figured as much money as I waste I need to save where I can so a few bucks a quart for dino fluid is a start lol. Not sure why Ghost848 is against synthetic, I'd be interested to hear the response as well.
  14. Feb 27, 2015 at 10:53 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    I run synthetic in everything because I want too. Also run Shell V Power in the fuel since that's the only fuel I can find without ethanol in it. Still running fine. Truck hasn't blown up yet.
  15. Feb 27, 2015 at 10:56 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    A retired racer at work gave me eleven qts. of Redline, so that what i used. If it was Royal Purple or Valoline etc, that's what i would of used.
  16. Feb 27, 2015 at 10:57 PM
    Idaholandho
    Yep, a die hard Mobil One fan myself and have run it in all of my off road vehicles for many years, and hard like you.
    The only argument I have with you is that, smoking crack is a waste of money, you don't waste money. :cheers:
  17. Feb 28, 2015 at 3:38 AM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Why?
    I only have 382k miles on mine, all synthetic.
  18. Feb 28, 2015 at 4:08 AM
    2000TRDTaco
    2000TRDTaco Well-Known Member
    Corey
    Angier, NC
    00 Prerunner
    I have Lucas Oil synthetic 75w90.....changed it about 20k miles ago and no problems
  19. Feb 28, 2015 at 7:26 AM
    Ghost848
    Tony
    Alberta,Canada
    Most synthetics have a tendancy to turn into "water" and loose there lubricating properties vs dino is a more raw fluid and doesnt turn into water as it gets hotter. I used to run synthetic but after research and comparison of fluids beside eachother dino is more slick. My experiences i guess...
  20. Feb 28, 2015 at 7:30 AM
    WeberSarge
    WeberSarge Well-Known Member
    Kevin
    Ohio, Illinois
    '08 SR5 TRD 4X4 Quad Cab , '77 FJ40
    Stock for now...
    Unless you have an odd station or geographic area , Shell V-Power is 10% Ethanol , at least around here and even in the 93 octane flavor .
    Sarge
