Rear Differential Lock Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by twfsa, Jun 6, 2010.
  1. Jun 6, 2010 at 6:58 AM
    twfsa
    twfsa [OP] Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Is there a way to test the Rear Differential Lock to see if it is working with out taking the vehicle off road into the mud, my dash light come's on when I turn the switch on. thanks
  2. Jun 6, 2010 at 7:16 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    get one wheel off.....then video tape
  3. Jun 6, 2010 at 7:25 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Chock the front wheels, jack up the rear of the truck. Put it in neutral.
    Spin one wheel by hand. If the opposite wheel spins in the opposite direction, then the locker IS NOT engaged. They should both spin in the same direction.
    Obviously, you've gotta be in 4lo - hopefully the system will allow the locker to stay engaged while you're in neutral.
  4. Jun 6, 2010 at 7:33 AM
    Blumpkinson
    Blumpkinson Fuelled by plutonium and wild animals
    OR
    03 4x4 5spd
    x2
    however do the grey wire mod, then you can use the locker whenever you want:D
  5. Jun 6, 2010 at 7:42 AM
    shift96
    shift96 Well-Known Member
    doesn't it only work in 4W LO?
  6. Jun 6, 2010 at 7:44 AM
    Blumpkinson
    OR
    03 4x4 5spd
  7. Jun 6, 2010 at 7:59 AM
    dhurley
    dhurley Well-Known Member
    Doug
    Colorado Springs, CO
    04 Double Cab TRD SR5 V6
    TRD, Snugtop Super-Sport, bedliner, receiver hitch, alarm mod, deck plate mod, AFE Pro-Dry S, Saddleman camo seat covers, TW decal, grey wire mod w/switch, DRL, LED cupholder mod, Dynomax Super Turbo, aux back-up lights, Devil Horns by Andres, "blue plug" mod for 2LO, shorty antenna, Pro Comp fog & driving lights, receiver shackle, 15% tint front windows, stainless nerf bars, Ultra Gauge, diff breather mod
    ^^^ This is true, the grey wire mod does work. Also, if you have the ignition turned on, but the truck not running, you can put your transfer in 4low, then engage the locker button. Standing outside the vehicle you should be able to hear the locker engage.
  8. Jun 6, 2010 at 8:36 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    This tip worked thanks a bunch, should I be engaging this periodically to keep it from seizeing up like my emergency brake cable did due to the previous owner not useing it?
  9. Jun 6, 2010 at 7:57 PM
    viperfella
    viperfella Well-Known Member
    Bubba
    North carolina
    2000 tacoma trd v6
    15'' mickey tompson bullet hole rims 31.10.50 mickey tompson baja tires
    i wouldnt think that would hurt. tho i do suggest u do the grey wire mod i did it a couple days ago and i love it.
  10. Jun 6, 2010 at 9:24 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    x2. I run the locker through its paces occasionally now in dirt parking lots by doing a doughnut or two.:D:D
