rear differential oil 2010 tacoma
Discussion in 'Technical Chat' started by 2010TRD, May 14, 2012.
  1. May 14, 2012 at 11:27 AM
    2010TRD
    2010TRD [OP] Well-Known Member
    Thomas
    Waldo, FL
    2010 MGM trd offroad DCSB
    Billistein 5100 front/rears, Toytec 2" AAL Custom grill, All Pro rear bumper, All Pro sliders, Anytime elocker/foglights, Rear diff vent relocated, W/O seat covers, weathertech mats/visors, nfab tire racK, cobra 75 stealth CB, Custom engine/trans skids 3/8", Hella and HID behind grill, LED bar backup light, LED pods under cab (rocklights)
    What type, and how much oil goes in my rear diff???
    2010 tacoma 4x4 with elocker posi rear.
    Thanks
  2. May 14, 2012 at 11:30 AM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Manual calls for 75w-90 and somewhere around 3 qts IIRC, you can find the amount in your manual. Fill her up level with the fill hole. Don't worry about any special oils, you have an e-locker, not a posi so you need just regular ass oil. Loosen fill plug before drain plug.
  3. May 14, 2012 at 12:44 PM
    2010TRD
    Thomas
    Waldo, FL
    Thanks
  4. May 14, 2012 at 3:49 PM
    2010TRD
    Thomas
    Waldo, FL
    Thanks again guys.
    I wasn't sure if the rear diff locker (elock) made any difference in what/how much fluid.
    3qts of 75w90 will do it ?
  5. May 14, 2012 at 3:50 PM
    2010TRD
    Thomas
    Waldo, FL
    I can't over fill it....? Just go til its at top ??
  6. May 14, 2012 at 4:05 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    85-140 for the rear diff for hard use (i.e. offroad travel or frequent towing). Mileage will suffer a little bit.
    75-90 is fine for the front diff and t-case.
