rear differential oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bigrog74, Jun 29, 2010.
  1. Jun 29, 2010 at 8:29 AM
    bigrog74
    bigrog74 [OP] Well-Known Member
    Florence, SC
    08 Tacoma Off Road Rugged Trail
    Coming Soon....real soon
    I'm due for my 30,000 mile service and I notice in my maintenance log I need to change my rear differential oil. Has anyone ever done this? Is it hard to get to? What oil do I replace it with?
    Any help is appreciated.
  2. Jun 29, 2010 at 8:32 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
  3. Jun 29, 2010 at 8:34 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    You have a TRD off road, which means you don't have limited slip. You can use 80w90 or synthetic 75w90.
  4. Jun 29, 2010 at 8:43 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    which would be the best to use? I am gonna change mine out this wknd. And is it the same for the front diff as well?
  5. Jun 29, 2010 at 8:44 AM
    bigrog74
    Florence, SC
    My truck does have thr RR Differential Lock. It is part of the Avalanch Off Road package. Thanks.
  6. Jun 29, 2010 at 8:47 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Since it doesn't cost much more and gives your truck more protection, I would run the synthetic 75w90. However, Toyota used conventional oil at the factory, so if you're on a tight budget, you'll be fine with that too.
  7. Jun 29, 2010 at 8:48 AM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    no, its just part of the Off Road pkg. All TRD Off Roads have the RR Diff Lock.
  8. Jun 29, 2010 at 8:51 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    You only need limited slip additive if you have the 05-08 lsd rear end. The locking diff does not need it.
  9. Jun 29, 2010 at 10:28 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
  10. Jun 29, 2010 at 10:36 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I did mine a little over a month ago but I have a Sport so mine is the LSD. I used 80W-90 for the rear diff and a 4oz. bottle of Redline friction modifier. Now bangs or grinding noises. Then for the front diff and transfer case, I used Redline 75W-90 synthetic gear oil. So far, no issues whatsoever. I know the OP drives an off-road edition but just in case any of you sports guys had questions as well.:rolleyes:
  11. Jun 29, 2010 at 12:20 PM
    MachoTaco10
    MachoTaco10 Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    so 2010 sports dont need the friction modifier? I thought it had limited slip diff, vsc, and traction control? no?
  12. Jun 29, 2010 at 12:51 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    None yet! It's new!
    Like I said above, '09 and newer do not use a mechanical LSD - no clutches in the diff. They use a new system that controls the throttle and brakes to limit slip. It's not inside the diff, so you don't need anything but pure 75W-90. It's this way on my '09 SPORT. Perhaps the Off Road is different, but an O.R. owner that knows, can chime in.
  13. Jun 29, 2010 at 1:19 PM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    Rambo54 likes this.
  14. Jun 29, 2010 at 4:31 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  15. Jun 30, 2010 at 7:33 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    None yet! It's new!
    Personally, I only use Red Line lubes. I've used them for years in everything I own that uses oil... cars, trucks, bikes, generators, tractor. It's over your price break though.
    In the diffs I use Red Line 75W-90. In the tranny and transfer case (6speed) I use Red Line MT-90.
  16. Jun 30, 2010 at 9:00 AM
    night_angel
    night_angel Well-Known Member
    Thomas
    Asuncion-Paraguay
    05 TRD Sport
    ECU FT500, JBA Headers, 100% Offroad
    if my truck is TRD Sport, "LSD", can I use Castrol Syntec 75W90? its GL-5
    Rambo54 likes this.
  17. Jun 30, 2010 at 9:40 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    None yet! It's new!
    What YEAR is your TRD Sport???? If it's an '09 or newer, the LSD is handled with braking and throttle, NOT the differential. Plain 75W-90 should be just fine.
    If it's older than an '09, wolfpack is probably right.
    If it meets the same specs as the gear oil spec in your manual, it is FINE.
    edit - I did just see your sig... if still accurate and you have an '05, listen to wolfpack...
  18. Jun 30, 2010 at 9:42 AM
    night_angel
    Thomas
    Asuncion-Paraguay
    05 TRD Sport
    has to be 80W90 mineral oil then?
  19. Jul 1, 2010 at 8:00 AM
    korslite
    korslite Well-Known Member
    Justin
    Bellingham, WA
    DCLB Sport
    FOX 2.5 RR's, TC UCAs, TC Spindle Gussets, Allpro Expedition leaf pack, Fox 2.O RR w/ Comp adjusters, 17" ATX Artillery, BFG AT 285's, de-scooped, custom sliders, custom bedrack, Brute Force Fab bumpers, Smittybilt XRC8 winch, ARB locked Rear diff
    I just changed my rear diff oil on tuesday and used 3qts of Valvoline's 80w90 LSD gear oil with a 4oz tube of CRC friction modifier and it has worked great for me. My LSD was chattering a lil bit before and it immediately went away with this lube combo. BTW mine is an '08 sport so it has the mechanical LSD...
    Rambo54 likes this.
  20. Dec 4, 2010 at 3:01 PM
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    can mobil one 75w90 LS be used in a trd off road locker diff? how bout in the xfer case?
    Rambo54 likes this.
