Rear Differential Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by echoxozzy, Aug 6, 2010.
  1. Aug 6, 2010 at 11:59 AM
    echoxozzy
    echoxozzy [OP] Member
    Texas
    08 TRD Rugged Offroad SR5
    Long (somewhat embarrassing) story short I need to remove a short rubber tube that went for a swim in my rear differential.
    I am thinking that it shouldn't be to difficult to take apart the casing and get it out.
    I think I have it planned out for the most part but am not sure how well it will seal back up. Is there a gasket that seals the casing back together or does it use some other type of sealant?
    Any other tips or ideas would be helpful.
    Thanks
  2. Aug 6, 2010 at 12:02 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    A really thin gasket. I didn't use a new one when I put my locker in last weekend. Just used the permatech and it works fine.
  3. Aug 6, 2010 at 12:09 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    You can't just leave it at that... come on what's the story?
    ALso if it involved water... make sure to do the breather relocation mod.
  4. Aug 6, 2010 at 3:05 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    It's a paper gasket, at least when I was changing my diff (LSD) casing that's what I came across. Like Matic I didn't bother replacing it with OEM, I just went with Permatex.
  5. Aug 6, 2010 at 3:38 PM
    mpleitez
    mpleitez Well-Known Member
    valencia
    03 toyota tacoma double cab 4x4
    Rear E-Locker TRD supercharger w/URD 7th injector 3 in. lift (soon) Icon coil overs front (soon) Icon UCA (soon) K&N air intake DT Headers (one day)
    I have an oem one that I can send through USPS for you just PM me your address it is a paper I bought one and never used it. It's got your name on it though if you want it. I just got to make sure it's still in the middle console of my truck.
  6. Aug 8, 2010 at 7:21 AM
    echoxozzy
    Texas
    Did you have to remove the drive-shaft to get the differential casing off or can you just take the nuts off the casing and slide the whole thing off as one piece?
    Also probably a dumb question but what is this permatex stuff? Im assuming its some kind of adhesive/sealant.
  7. Aug 8, 2010 at 9:22 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    come on dude..how did you get a rubber tube into the diff? how long of a tube? you drop it in while filling the thing.
    this would be good info, so the next guy doesnt do the same thing.
    permatex makes a bunch of gasket sealants..some are "form a gaskets"..
  8. Aug 8, 2010 at 9:41 AM
    Matic
    Tricky Dick
    Easley, SC
    What he said.
    You dont really need a gasket. Just run a nice bead of the red permatex gasket silicon. Not super thick. The paper gasket is so thin it most likely is going to tear off.
    Take a rag with some brake cleaner sprayed on it and wipe the diff down.
    And yes....your going to have to remove the 4 bolts that hold the u-joint flange to the diff. No big deal.
    I got a pic I think. I just did mine.
  9. Aug 8, 2010 at 9:45 AM
    Matic
    Tricky Dick
    Easley, SC
    Your going to have to spray the piss out of the diff bolts and the four u-joint bolts and let it sit a while. If the diff has never been touched before....it could be a pita. I had to use a breaker bar on each and every bolt.
  10. Aug 8, 2010 at 10:19 AM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    You're going to have to pull the axles too for the 3rd member to come out.
  11. Aug 8, 2010 at 7:22 PM
    echoxozzy
    Texas
    By popular demand the story is the tube slid in when I was filling differential.
    Thanks for the help guys.
  12. Aug 9, 2010 at 5:09 PM
    echoxozzy
    Texas
    I managed to get the drive-shaft removed. The bolts where a PITA but I drowned them in WD40 last night and by the time I got home from work they weren't too bad.
    I'm at a point where I am not sure if I have removed everything that I need to removed to get the casing off. Ive taken (9) 12mm nuts off the perimeter. My plan is to use a rubber mallet and pry-bar to work the casing off. I don't want to start banging away if I still need to remove something but I don't want to just be removing stuff if it doesn't need to be.
    The two things in particular are what looks like a large bolt head behind where the drive-shaft used to attach and what I think I have seen called the ECD located at the top right.
  13. Aug 9, 2010 at 6:05 PM
    desertdude59
    Your drive axles will have to come out. The whole 3rd member need to be removed. That nut is for the pinion. Probably wont do a bit of good taking it out. There are 4 nuts behind the drums on the rear end that need to be removed so your axles can slide out.
  14. Aug 9, 2010 at 8:18 PM
    echoxozzy
    Texas
    Thanks. I ended up finding another thread explaining it as well. Looks like i got myself in deeper than I originally thought.
  15. Aug 9, 2010 at 8:19 PM
    desertdude59
    No Prob. Hope you get it fixed.
  16. Aug 9, 2010 at 8:36 PM
    IslandBoy71
    IslandBoy71 Well-Known Member
    Reggie
    Lakewood, CA
    06 TRD PreRunner Sport SR5 DC
    TRD Intake,Flowmaster Super 10 exhaust, King 2.5 c/o adjusted to 3inch front and King 2.5 rears w/AAL. Custom bed rack, rock sliders and rear tire carrier.
    how big of a tube?
  17. Aug 13, 2010 at 8:50 AM
    echoxozzy
    Texas
    The tube is about 6 inches long about as big around as my finger.
  18. Aug 13, 2010 at 8:56 AM
    echoxozzy
    Texas
    I've reached the point where I have pulled my axles. I wasnt sure how far I needed to pull them but I have read on here that a couple of inches should work so they are pulled out a couple of inches. It felt like they disengaged from something inside the axle so i think they are far enough.
    At this point how hard should it be to remove the 3rd member. I have removed 9 nuts from the perimeter. They covered the part from about 3 to 12. The top right quadrant (12-3) is covered up by something that I think is my Electronic Locking something or a another.
    The 3rd member doesn't seem to be budging yet is there something else I need to remove. I'm thinking i might have to take off this electronic locking hooyah to remove something that locks it to the rear axle in that top left part.
  19. Aug 13, 2010 at 8:59 AM
    98tacoma27
    Ben
    Not Beech Creek
    As long as the axles are out of the third and all of the nuts are removed, it should come out. You don't have to remove the e-locker actuator. It might just be the gasket holding it fast.
  20. Aug 13, 2010 at 9:57 AM
    echoxozzy
    Texas
    Its not budging and my strategy of prying it open with a pry bar, screw driver and rubber mallet doesn't seem to be working. Anyone else have trouble with this?
