rear differential
Discussion in '5 Lug' started by frog13, Sep 17, 2011.
  1. Sep 17, 2011 at 6:54 PM
    frog13
    frog13 [OP] Well-Known Member
    Do 5-lug Tacoma's have rear differential issues?.....design error. The FJ's,some 4x4 Tacoma's and I'm not sure if Tundra is having issues or not.
    And,how do 5-lugs REALLY do in the snow with 200--300 lbs in the back and descent snow tires....yes I've read posts after post,after post. If 5-lugs do so well in the snow,why do some folks pony up the $$$$ plus grand for them?.Preference I suppose????. TIA.
  2. Sep 17, 2011 at 9:33 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    The rear ends that have had the most problems seem to be the e-locker rear ends. These are not available on the 5-lug tacomas, only the TRD Off-Road tacomas.
    I can't say too much about snow performance, but mine has done fine with the small amount (2-3") of snow we get where I live and I run AT tires.
