Rear differential!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoman00, Aug 27, 2012.
  1. Aug 27, 2012 at 8:01 AM
    tacoman00
    tacoman00 [OP] Your Average Joe
    Hampton Roads, VA
    2021 TRD Off-Road DCSB
    Toytec BOSS 2.0 lift, 18x9 Fuel Rebels, 32” BFG AT K02.
    Just finished changing my rear differential for the first time after 82,500 miles! I know im late but better late than never. I followed the DIY guide by chris4x4! Very helpful! I must say this is a very simple change and you should do it if you havent! It took me 30 minutes only because i was being careful! I used 75w-90 mobil 1 fully synthetic oil with 4 ounces out of a tube of LSD additive. I would recommend getting some type of tubing, because even with the squeeze spout bottles i had, i struggled getting the last 1/8th of the bottle to empty because of the spare Tire being in the way. Anyways, it does feel much smoother now.
  2. Aug 27, 2012 at 9:30 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Last time I did mine I ran some tubing up over the passenger side tire and used a funnel. Quick and easy. Trying to pump it or squeeze the bottles is a huge pain.
  3. Aug 27, 2012 at 10:29 AM
    tacoman00
    Hampton Roads, VA
    Yeah it wont too bad just took time
  4. Aug 27, 2012 at 11:08 AM
    08TacoTrD
    08 TRD Offroad
    Too much time. Plus with a tube and funnel you're standing up next to the truck and not laying down under the truck.
  5. Dec 8, 2012 at 5:31 PM
    canucktacoma
    canucktacoma Active Member
    mike
    gta area, ontario canada
    sr5
    just did mine on my new accustion2008 taco,used a small pump from walmart 15$ keep oil warm goes quick,did tranny as well,next is rad.
  6. Dec 8, 2012 at 5:35 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Rear differential fluid=\=rear differential.
    GJ though. Feels good working on your own vehicle.
  7. Dec 9, 2012 at 6:31 AM
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    Just did mine yesterday after 120k miles and the oil still came out dark red and clean, just fyi. I had no issues while driving before and have none now, ( but I don't off road or pull anything heavy). I used valvoline 80w90 LS as per Toyota Dealer suggested. Now Contemplating doing my tranny fluid or not.
