Rear differntial fluid change on 2008 Tacoma 4X4 off road, plus 60k questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grunt66, Jun 15, 2015.
  1. Jun 15, 2015 at 8:29 AM
    grunt66
    grunt66 [OP] Well-Known Member
    Vista, CA
    08 Tacoma DBL cab 4X4 off road
    I am seeking confirmation on the need to add limited slip additive to the rear differential. I am closing in on 60k and I plan on doing the 60k service myself since the Toyota dealership wants $549 to do the service and that does not include drain and refill of the transmission, transfer case, and front differential.
    Since I have a 2008 Tacoma 4x4 off road with the locking rear differential and I looked at the rear differential and do not see LSD on tag or anywhere on the rear differential I was under the impression no LSD additive is required. However on 60k service quote from dealership they have the LSD additive added to quote. So does my Tacoma require LSD additive and if so what brand should I use? The Toyota part number (TOSL2411) can not be found when I tried to Google it on the internet. Toyota also states a quantity of 2 is required.
    I am going to use Royal Purple 75W-90 gear oil and replace the oil in both differentials and the transfer case. The dealership also stated the transmission does not need to be serviced until 100k miles. Reading on the forum I have read several posts stating Toyota recommends changing the fluids at 60k. What are thoughts of draining and replacing the transmission fluid at 60K? I initially purchased 4 quarts of Toyota ATF WS transmission fluid but I am rethinking doing a full drain and flush which will require more transmission fluid.
  2. Jun 15, 2015 at 8:44 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Yes you need lsd additive i would think it being a 4x4. Some synthetic stuff is used alone but for that extra pillow i put in the separate additive in anyway.
    You do not have a manual for the truck?
  3. Jun 15, 2015 at 8:48 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    No. Its a locking differential. .... No LSD additive needed.
    Regular 80w90 is fine.
  4. Jun 15, 2015 at 8:50 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    I have a locker and in my manual i need it.
    Thats why i asked if he has manual.
  5. Jun 15, 2015 at 8:51 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    But idk because of year difference
    :notsure::boink:
  6. Jun 15, 2015 at 8:59 AM
    1MK
    1MK Desert Explorer
    Southern California
    Any name brand 75-90w will be fine. The rear locker does NOT require the additive, nor does the front diff or transfer case.
    As far as transmission fluid goes, I'd change it. 100k is a lot to ask out of any fluid.
  7. Jun 15, 2015 at 8:59 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Alrighty then.
    If only i could photo shop some ace ventura here. Lol
    Im at work.
  8. Jun 15, 2015 at 9:00 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Nice avatar pic. Looks cozy
  9. Jun 15, 2015 at 9:58 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    I use 80-90 Valvoline limited slip. It says on the container it can be used in conventional or limited slip applications. I haven't had any problems with it.
  10. Jun 15, 2015 at 10:17 AM
    grunt66
    Vista, CA
    I appreciate everyone's input.
  11. Jun 15, 2015 at 10:28 AM
    Gasturbine
    Gasturbine Well-Known Member
    Central Ohio
    2011 Regular Cab 2.7l 5-speed 4WD
    32" BFG KO tires on MT rims, Front lifted 2", N-Fab 12,000lb front pull point w/10,000lb red clevis, mud flap delete, tail pipe delete, 20" LED light bar, 2 Hella 500s, N-Fab light bar mount, tinted windows.
    I didnt think our Tacomas had a mechanical LSD. I thought TRAC "mimics" an LSD, via individual wheel braking?
  12. Jun 15, 2015 at 10:39 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I believe the cut off for mechanical versus brake assisted LSD was 2009. From all I have read the 2008 had a mechanical LSD and needs the additive. That being said just buy the oil with the additive. As far as the tranny the dealer is going by the service intervals in the manual for 2008 and at least through 2009 models. Sometime between 2009 and 2013 Toyota changed the interval to 60k. Also, tell the dealer to pound sand for $549 for 60k service without tranny flush. Even then $549 is too much.
