Rear disc brakes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Boss hoss, Sep 2, 2019.
  1. Sep 3, 2019 at 10:02 AM
    #41
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Something name brand. Like Pearl or Tama. I used to use Spaun, but I don’t think they’re around anymore
    SpeySquatch[QUOTED] likes this.
  2. Sep 3, 2019 at 10:02 AM
    #42
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    4 wheels drums FTW
    Skydvrr likes this.
  3. Sep 3, 2019 at 10:04 AM
    #43
    stun gun
    Aaronski
    Tacomas.
    You’re not wrong. It’s just the expansion doesn’t mess with brake feel or performance, it does however exacerbate failures in worst case scenarios.
  4. Sep 3, 2019 at 10:10 AM
    #44
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    Won't make any difference worth the trouble. Rear braking on a Tacoma is maybe 10-15% when fully loaded and the only scenario where you should see any fade is towing heavy loads on a long downward grade. Even then, you should be taking advantage of engine braking and not riding the brakes or getting a larger pickup if you do such towing regularly.
  5. Sep 3, 2019 at 10:26 AM
    #45
    SpeySquatch
    2016 TRD OR DCSB
    It was more for when I am loaded with gear. I’ve already boiled my breaks once and that was using gears and braking coming down a hill
  6. Sep 3, 2019 at 10:29 AM
    #46
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Probably cooked the fronts too then. Unless you're crazy overloaded, you really shouldn't be feeling the rears.
  7. Sep 3, 2019 at 11:16 AM
    #47
    SpeySquatch
    2016 TRD OR DCSB
    I boiled my fluid to the point the pedal was going to the floor and I could only slow the truck but not stop it. Since then the front have been upgraded as well as fluid from that stock DOT3 garbage to DOT4
  8. Sep 3, 2019 at 11:22 AM
    #48
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Search for it. Someone did an in depth write-up of adding the 4runner brakes to the taco.
  9. Sep 3, 2019 at 11:30 AM
    #49
    TACO_ROCKET
    TACO_ROCKET Well-Known Member
    Tyler
    Black 2019 TRD OR DCSB auto w/ premium tech pkg
    Ok. I guess I'll just take your word for it. The rest of the internet seems to disagree with you, but since you said so; so it must be.
  10. Sep 3, 2019 at 11:35 AM
    #50
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    One of us in this conversation has been a heavy truck brake and suspension technician and wrenched for 8+ years. Be a passive aggressive twat but the internet is not the wealth of knowledge you think it is unless you actually know how to interpret what you're reading. You're taking information on passenger cars and presenting it as universal - it's just not the case.
    rtzx9r and 0xDEADBEEF like this.
  11. Sep 3, 2019 at 11:37 AM
    #51
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Well if you're boiling brake fluid then I think you have bigger issues. The temp improvement of DOT 4 is not very much and if you're boiling fluid in a Tacoma without a trailer, you are either being way to aggressive and/or riding the brakes, are crazy overloaded, or you have a mechanical problem.
    Either way, an extra inch or two on the drums won't fix boiling fluid.
  12. Sep 3, 2019 at 11:38 AM
    #52
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Wagner drums. They don't perform any better than OE but has a black E-coat on non-friction surfaces to prevent rusting.
  13. Sep 3, 2019 at 11:42 AM
    #53
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    And Toyota ignores all this and puts drum brakes in Tacomas because they are $5 cheaper per vehicle. :cookiemonster: Meanwhile 4Runners and Land Cruisers get discs because they are priced higher.
  14. Sep 3, 2019 at 11:42 AM
    #54
    cshrum
    cshrum Well-Known Member
    CO Springs, CO
    17 blue TRD sport DCLB
    Whoa! This Chad takes offense to that!
    Kidding...I'll be ok
    SpeySquatch and stun gun[QUOTED] like this.
  15. Sep 3, 2019 at 11:50 AM
    #55
    TACO_ROCKET
    Tyler
    Which of those articles I listed is referring to passenger cars?
  16. Sep 3, 2019 at 11:53 AM
    #56
    stun gun
    Aaronski
    Tacomas.
    Ahem.
    2... There’s two of us in here. I’m current with all sorts of cards and certs and dangly key things.
  17. Sep 3, 2019 at 11:55 AM
    #57
    stun gun
    Aaronski
    Tacomas.
    Oh my bad. Fuckin auto correct. I meant Chet lol.
    If Chet comes in here I’m flippin tables.
    cshrum[QUOTED] likes this.
  18. Sep 3, 2019 at 11:58 AM
    #58
    stun gun
    Aaronski
    Tacomas.
    Since were battling misinformation and wonky perspectives, would you mind posting the itemized production costs of Toyota’s production caliper suppliers alongside the drum specs?
  19. Sep 3, 2019 at 11:58 AM
    #59
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Install those rear discs, make sure to get slotted/drilled rotors on all four corners also, and paint your calipers red.
    TacoTim16 and stun gun like this.
  20. Sep 3, 2019 at 12:00 PM
    #60
    stun gun
    Aaronski
    Tacomas.
    Add a wing, a spoon sticker, and k swap it. Then you’d be right back to square one before you bought a Toyota pickup.
    coopcooper[QUOTED] likes this.
